1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Core 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkUpdateCellsV8toV9.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkAbstractParticleWriter.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkAbstractPolyDataReader.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkArrayDataReader.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkArrayDataWriter.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkArrayReader.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkArrayWriter.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkASCIITextCodec.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkBase64InputStream.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkBase64OutputStream.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkBase64Utilities.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkDataCompressor.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkDelimitedTextWriter.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkFileResourceStream.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkGlobFileNames.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkInputStream.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkJavaScriptDataWriter.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkLZ4DataCompressor.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkLZMADataCompressor.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkMemoryResourceStream.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkOutputStream.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkResourceParser.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkResourceStream.h" 70 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkSortFileNames.h" 71 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkTextCodec.h" 72 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkTextCodecFactory.h" 73 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkURI.h" 74 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkURILoader.h" 75 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkUTF16TextCodec.h" 76 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkUTF8TextCodec.h" 77 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkWriter.h" 78 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/vtkZLibDataCompressor.h" 79 "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Core/vtkIOCoreModule.h" 83 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 84 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkIOCore-hierarchy.txt
vtk/hierarchy/ParaView/vtkIOCore-hierarchy.txt
") 87 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 89 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so.5.13
" 90 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so.1
" 92 if(EXISTS "${file}
" AND 93 NOT IS_SYMLINK "${file}
") 99 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 100 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOCore-pv5.13.so.5.13
" 101 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOCore-pv5.13.so.1
" 104 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so.5.13
" 105 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so.1
" 107 if(EXISTS "${file}
" AND 108 NOT IS_SYMLINK "${file}
") 111 OLD_RPATH "\$ORIGIN:
" 112 NEW_RPATH "\$ORIGIN
") 113 if(CMAKE_INSTALL_DO_STRIP) 114 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 120 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 121 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so
" AND 122 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so
") 124 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so
" 127 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOCore-pv5.13.so
") 128 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so
" AND 129 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so
") 131 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so
" 132 OLD_RPATH "\$ORIGIN:
" 133 NEW_RPATH "\$ORIGIN
") 134 if(CMAKE_INSTALL_DO_STRIP) 135 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.13.so
") 140 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 141 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkIOCore
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Core/LICENSE
") 144 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xspdxx
" OR NOT CMAKE_INSTALL_COMPONENT) 145 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Core/vtkIOCore.spdx
