1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Export 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkIOExport-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOExport-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv6.0.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExport-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExport-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOExport-pv6.0.so.1
" 69 if(EXISTS "${file}
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOExport-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 91 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/
vtkExporter.h
" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkGLTFExporter.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/
vtkIVExporter.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkJSONDataSetWriter.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkJSONRenderWindowExporter.h
" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkJSONSceneExporter.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/
vtkRIBLight.h
" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkSVGContextDevice2D.h
" 104 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkSVGExporter.h
" 105 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/vtkSingleVTPExporter.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/
vtkX3D.h
" 115 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 116 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Export/vtkIOExportModule.h
") 119 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 120 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkIOExport
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Export/LICENSE
") 123 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 124 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Export/vtkIOExport.spdx
