1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/IOSS
47  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/IOSS/vtkIOSSReader.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/IOSS/vtkIOSSCellGridReader.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/IOSS/vtkIOSSWriter.h"
50  "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/IOSS/vtkIOIOSSModule.h"
51  )
52 endif()
53
54 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
55  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOIOSS-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOIOSS-hierarchy.txt")
56 endif()
57
58 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
59  foreach(file
60  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so.5.13"
61  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so.1"
62  )
63  if(EXISTS "${file}" AND
64  NOT IS_SYMLINK "${file}")
65  file(RPATH_CHECK
66  FILE "${file}"
67  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
68  endif()
69  endforeach()
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
71  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOIOSS-pv5.13.so.5.13"
72  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOIOSS-pv5.13.so.1"
73  )
74  foreach(file
75  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so.5.13"
76  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so.1"
77  )
78  if(EXISTS "${file}" AND
79  NOT IS_SYMLINK "${file}")
80  file(RPATH_CHANGE
81  FILE "${file}"
82  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
83  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
84  if(CMAKE_INSTALL_DO_STRIP)
85  execute_process(COMMAND "/usr/bin/strip" "${file}")
86  endif()
87  endif()
88  endforeach()
89 endif()
90
91 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
92  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so" AND
93  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so")
94  file(RPATH_CHECK
95  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so"
96  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
97  endif()
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOIOSS-pv5.13.so")
99  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so" AND
100  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so")
101  file(RPATH_CHANGE
102  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so"
103  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
104  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
105  if(CMAKE_INSTALL_DO_STRIP)
106  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOIOSS-pv5.13.so")
107  endif()
108  endif()
109 endif()
110
