1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkIOLegacy-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOLegacy-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv6.0.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOLegacy-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOLegacy-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv6.0.so.1
" 69 if(EXISTS "${file}
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOLegacy-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 95 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/
vtkDataReader.h
" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/
vtkDataWriter.h
" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkLegacyCellGridReader.h
" 104 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/vtkLegacyCellGridWriter.h
" 118 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/
vtkTreeReader.h
" 119 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Legacy/
vtkTreeWriter.h
" 125 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 126 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Legacy/vtkIOLegacyModule.h
") 129 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 130 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Legacy/vtkIOLegacy.spdx
