1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkIOParallelXML-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOParallelXML-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelXML-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelXML-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv6.0.so.1
" 69 if(EXISTS "${file}
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelXML-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 91 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLCompositeDataSetWriterHelper.h
" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLDataWriterHelper.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPartitionedDataSetCollectionWriter.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPartitionedDataSetWriter.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLWriter2.h
" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPDataObjectWriter.h
" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPHyperTreeGridWriter.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelXML/vtkXMLPTableWriter.h
" 114 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 115 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/ParallelXML/vtkIOParallelXMLModule.h
") 118 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 119 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/ParallelXML/vtkIOParallelXML.spdx
