1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/XML
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOXML-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOXML-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOXML-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOXML-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOXML-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkRTXMLPolyDataReader.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLCompositeDataReader.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLCompositeDataWriter.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLDataObjectWriter.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLDataReader.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLDataSetWriter.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLFileReadTester.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLGenericDataObjectReader.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLHierarchicalBoxDataFileConverter.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLHierarchicalBoxDataReader.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLHierarchicalBoxDataWriter.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLHierarchicalDataReader.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLHyperTreeGridReader.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLHyperTreeGridWriter.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLImageDataReader.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLImageDataWriter.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLMultiBlockDataReader.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLMultiBlockDataWriter.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLMultiGroupDataReader.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPDataObjectReader.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPDataReader.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPHyperTreeGridReader.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPImageDataReader.h"
114  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPPolyDataReader.h"
115  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPRectilinearGridReader.h"
116  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPStructuredDataReader.h"
117  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPStructuredGridReader.h"
118  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPTableReader.h"
119  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPUnstructuredDataReader.h"
120  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPUnstructuredGridReader.h"
121  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPartitionedDataSetCollectionReader.h"
122  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPartitionedDataSetReader.h"
123  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPolyDataReader.h"
124  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLPolyDataWriter.h"
125  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLReader.h"
126  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLRectilinearGridReader.h"
127  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLRectilinearGridWriter.h"
128  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLStructuredDataReader.h"
129  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLStructuredDataWriter.h"
130  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLStructuredGridReader.h"
131  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLStructuredGridWriter.h"
132  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLTableReader.h"
133  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLTableWriter.h"
134  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLUniformGridAMRReader.h"
135  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLUniformGridAMRWriter.h"
136  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLUnstructuredDataReader.h"
137  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLUnstructuredDataWriter.h"
138  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLUnstructuredGridReader.h"
139  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLUnstructuredGridWriter.h"
140  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLWriter.h"
141  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLWriterBase.h"
142  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/XML/vtkXMLWriterC.h"
143  )
144 endif()
145
146 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
147  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/XML/vtkIOXMLModule.h")
148 endif()
149
150 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
151  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/XML/vtkIOXML.spdx")
152 endif()
153
struct vtkXMLWriterC_s vtkXMLWriterC
