1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkInfovisCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkInfovisCore-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInfovisCore-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInfovisCore-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInfovisCore-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkAddMembershipArray.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkAdjacencyMatrixToEdgeTable.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkArrayNorm.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkArrayToTable.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkCollapseGraph.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkCollapseVerticesByArray.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkContinuousScatterplot.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkDotProductSimilarity.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkEdgeCenters.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkExpandSelectedGraph.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkExtractSelectedGraph.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkExtractSelectedTree.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkGenerateIndexArray.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkGraphHierarchicalBundleEdges.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkGroupLeafVertices.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkKCoreDecomposition.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMergeColumns.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMergeGraphs.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMergeTables.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkMutableGraphHelper.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkNetworkHierarchy.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkPipelineGraphSource.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkPruneTreeFilter.h"
114  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkRandomGraphSource.h"
115  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkReduceTable.h"
116  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkRemoveHiddenData.h"
117  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkRemoveIsolatedVertices.h"
118  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkSparseArrayToTable.h"
119  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkStreamGraph.h"
120  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkStringToCategory.h"
121  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkStringToNumeric.h"
122  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToArray.h"
123  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToGraph.h"
124  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToSparseArray.h"
125  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTableToTreeFilter.h"
126  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkThresholdGraph.h"
127  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkThresholdTable.h"
128  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTransferAttributes.h"
129  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTransposeMatrix.h"
130  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTreeDifferenceFilter.h"
131  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTreeFieldAggregator.h"
132  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkTreeLevelsFilter.h"
133  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkVertexDegree.h"
134  "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/vtkWordCloud.h"
135  )
136 endif()
137
138 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
139  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Infovis/Core/vtkInfovisCoreModule.h")
140 endif()
141
142 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
143  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkInfovisCore" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Infovis/Core/LICENSE")
144 endif()
145
146 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
147  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Infovis/Core/vtkInfovisCore.spdx")
148 endif()
149
