1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkInteractionStyle-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkInteractionStyle-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionStyle-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionStyle-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInteractionStyle-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInteractionStyle-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionStyle-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionStyle-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInteractionStyle-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleDrawPolygon.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleFlight.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleImage.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleJoystickActor.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleJoystickCamera.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleMultiTouchCamera.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleRubberBand2D.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleRubberBand3D.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleRubberBandPick.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleRubberBandZoom.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleTerrain.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleTrackball.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleTrackballActor.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleTrackballCamera.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleUnicam.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleUser.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkInteractorStyleSwitch.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/vtkParallelCoordinatesInteractorStyle.h"
109  )
110 endif()
111
112 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
113  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
114  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Interaction/Style/vtkInteractionStyleModule.h"
115  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Interaction/Style/vtkInteractionStyleSerDes.h"
116  )
117 endif()
118
119 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
120  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkInteractionStyle" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Style/LICENSE")
121 endif()
122
123 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
124  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Interaction/Style/vtkInteractionStyle.spdx")
125 endif()
126
