1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkInteractionWidgets-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkInteractionWidgets-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionWidgets-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionWidgets-pv6.0.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInteractionWidgets-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInteractionWidgets-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionWidgets-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInteractionWidgets-pv6.0.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkInteractionWidgets-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 91 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtk3DCursorRepresentation.h
" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtk3DCursorWidget.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtk3DWidget.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkAbstractSplineRepresentation.h
" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkAffineWidget.h
" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkAngleWidget.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkBalloonWidget.h
" 113 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkBorderWidget.h
" 115 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkBoundedWidgetRepresentation.h
" 117 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkBoxWidget.h
" 118 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkBoxWidget2.h
" 121 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkButtonWidget.h
" 122 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCamera3DRepresentation.h
" 123 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCamera3DWidget.h
" 124 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCameraHandleSource.h
" 125 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCameraOrientationWidget.h
" 126 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCameraOrientationRepresentation.h
" 127 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCameraPathRepresentation.h
" 128 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCameraPathWidget.h
" 130 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkCameraWidget.h
" 132 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkCaptionWidget.h
" 140 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkCompassWidget.h
" 146 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkContourWidget.h
" 147 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCoordinateFrameRepresentation.h
" 148 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkCoordinateFrameWidget.h
" 151 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkDisplaySizedImplicitPlaneWidget.h
" 152 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkDisplaySizedImplicitPlaneRepresentation.h
" 158 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkEqualizerContextItem.h
" 159 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkEvent.h
" 166 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkHandleWidget.h
" 167 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkHoverWidget.h
" 173 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkImplicitAnnulusRepresentation.h
" 174 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkImplicitAnnulusWidget.h
" 175 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkImplicitConeRepresentation.h
" 176 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkImplicitConeWidget.h
" 179 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkImplicitFrustumRepresentation.h
" 180 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkImplicitFrustumWidget.h
" 181 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkImplicitImageRepresentation.h
" 185 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkLightRepresentation.h
" 186 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkLightWidget.h
" 189 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkLineWidget.h
" 190 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkLineWidget2.h
" 192 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkLogoWidget.h
" 193 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkMagnifierRepresentation.h
" 194 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkMagnifierWidget.h
" 195 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkMeasurementCubeHandleRepresentation3D.h
" 196 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkMultiLineRepresentation.h
" 197 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkMultiLineWidget.h
" 199 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkOrientationRepresentation.h
" 200 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkOrientationWidget.h
" 206 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkPlaneWidget.h
" 209 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkPointCloudRepresentation.h
" 210 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkPointCloudWidget.h
" 213 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkPointPlacer.h
" 214 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkPointWidget.h
" 228 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkResliceCursor.h
" 239 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkSeedWidget.h
" 243 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkSliderWidget.h
" 246 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkSphereWidget.h
" 247 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkSphereWidget2.h
" 249 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkSplineWidget.h
" 250 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkSplineWidget2.h
" 253 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkTensorRepresentation.h
" 254 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/vtkTensorWidget.h
" 260 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkTextWidget.h
" 262 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkWidgetEvent.h
" 265 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkWidgetSet.h
" 266 "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/
vtkXYPlotWidget.h
" 270 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 271 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 272 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Interaction/Widgets/vtkInteractionWidgetsModule.h
" 273 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Interaction/Widgets/vtkInteractionWidgetsSerDes.h
" 277 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 278 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkInteractionWidgets
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Interaction/Widgets/LICENSE
") 281 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 282 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Interaction/Widgets/vtkInteractionWidgets.spdx
