1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkRenderingVolume-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRenderingVolume-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv6.0.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolume-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolume-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv6.0.so.1
" 69 if(EXISTS "${file}
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingVolume-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 91 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkBlockSortHelper.h
" 105 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkMultiVolume.h
" 106 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkOSPRayVolumeInterface.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/vtkAnariVolumeInterface.h
" 123 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/
vtkVolumeMapper.h
" 125 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/
vtkVolumePicker.h
" 130 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 131 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 132 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Volume/vtkRenderingVolumeModule.h
" 133 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Volume/vtkRenderingVolumeSerDes.h
" 137 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 138 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRenderingVolume
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Volume/LICENSE
") 141 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 142 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Volume/vtkRenderingVolume.spdx
