1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/vtkhdf5/hl/src" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/H5DOpublic.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/H5DSpublic.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/H5IMpublic.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/H5LTpublic.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/H5PTpublic.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/H5TBpublic.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/H5LDpublic.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/hdf5_hl.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/hdf5/vtkhdf5/hl/src/vtk_hdf5_hl_mangle.h"
56  )
57 endif()
58
59 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
60  foreach(file
61  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5_hl-pv6.0.so.6.0"
62  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5_hl-pv6.0.so.1"
63  )
64  if(EXISTS "${file}" AND
65  NOT IS_SYMLINK "${file}")
66  file(RPATH_CHECK
67  FILE "${file}"
68  RPATH "\$ORIGIN")
69  endif()
70  endforeach()
71  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
72  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkhdf5_hl-pv6.0.so.6.0"
73  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkhdf5_hl-pv6.0.so.1"
74  )
75  foreach(file
76  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5_hl-pv6.0.so.6.0"
77  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkhdf5_hl-pv6.0.so.1"
78  )
79  if(EXISTS "${file}" AND
80  NOT IS_SYMLINK "${file}")
81  file(RPATH_CHANGE
82  FILE "${file}"
83  OLD_RPATH "\$ORIGIN:"
84  NEW_RPATH "\$ORIGIN")
85  if(CMAKE_INSTALL_DO_STRIP)
86  execute_process(COMMAND "/usr/bin/strip" "${file}")
87  endif()
88  endif()
89  endforeach()
90 endif()
91
92 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
93  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkhdf5_hl-pv6.0.so")
94 endif()
95
