1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/mpi4py/vtkmpi4py/cmake_install.cmake")
48 endif()
49
50 if(CMAKE_INSTALL_COMPONENT STREQUAL "license" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkmpi4py" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py/vtkmpi4py/LICENSE.rst")
52 endif()
53
54 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
55  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/mpi4py/vtkmpi4py.spdx")
56 endif()
57
