1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py/vtkmpi4py/src
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/__init__.py"
48  "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/__init__.pxd"
49  "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/MPI.pxd"
50  "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/__init__.pyi"
51  "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/MPI.pyi"
52  "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/py.typed"
53  "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/mpi.cfg"
54  )
55 endif()
56
57 if(CMAKE_INSTALL_COMPONENT STREQUAL "Unspecified" OR NOT CMAKE_INSTALL_COMPONENT)
58  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so" AND
59  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so")
60  file(RPATH_CHECK
61  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so"
62  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
63  endif()
64  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so")
65  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so" AND
66  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so")
67  file(RPATH_CHANGE
68  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so"
69  OLD_RPATH "/usr/lib64/openmpi/lib:/builds/gitlab-kitware-sciviz-ci/build/lib64:"
70  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
71  if(CMAKE_INSTALL_DO_STRIP)
72  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/mpi4py/MPI.cpython-313-x86_64-linux-gnu.so")
73  endif()
74  endif()
75 endif()
76
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/vtkmpi4py/mpi4py/" TYPE DIRECTORY FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/mpi4py/vtkmpi4py/src/mpi4py/include/mpi4py/")
79 endif()
80
