1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/nlohmannjson
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/nlohmannjson/vtknlohmannjson/cmake_install.cmake")
48 endif()
49
50 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensex" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtknlohmannjson" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/nlohmannjson/vtknlohmannjson/LICENSE.MIT")
52 endif()
53
54 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xspdxx" OR NOT CMAKE_INSTALL_COMPONENT)
55  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/nlohmannjson/vtknlohmannjson.spdx")
56 endif()
57
58 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
59  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/nlohmannjson/vtk_nlohmannjson.h")
60 endif()
61
