1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Compiler.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Hash.h")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Singletons.h")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Token.h")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Type.h")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/TypeContainer.h")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/Manager.h")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token/json" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/json/jsonToken.h")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token/json" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/token/vtktoken/token/json/jsonManager.h")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/Options.h")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/CxxABIConfigure.h")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/token" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/Exports.h")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
94  foreach(file
95  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.5.13"
96  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.1"
97  )
98  if(EXISTS "${file}" AND
99  NOT IS_SYMLINK "${file}")
100  file(RPATH_CHECK
101  FILE "${file}"
102  RPATH "\$ORIGIN")
103  endif()
104  endforeach()
105  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
106  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktoken-pv5.13.so.5.13"
107  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktoken-pv5.13.so.1"
108  )
109  foreach(file
110  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.5.13"
111  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so.1"
112  )
113  if(EXISTS "${file}" AND
114  NOT IS_SYMLINK "${file}")
115  file(RPATH_CHANGE
116  FILE "${file}"
117  OLD_RPATH ":::::::"
118  NEW_RPATH "\$ORIGIN")
119  if(CMAKE_INSTALL_DO_STRIP)
120  execute_process(COMMAND "/usr/bin/strip" "${file}")
121  endif()
122  endif()
123  endforeach()
124 endif()
125
126 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
127  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so" AND
128  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so")
129  file(RPATH_CHECK
130  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so"
131  RPATH "\$ORIGIN")
132  endif()
133  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtktoken-pv5.13.so")
134  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so" AND
135  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so")
136  file(RPATH_CHANGE
137  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so"
138  OLD_RPATH ":::::::"
139  NEW_RPATH "\$ORIGIN")
140  if(CMAKE_INSTALL_DO_STRIP)
141  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtktoken-pv5.13.so")
142  endif()
143  endif()
144 endif()
145
146 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
147  # Include the install script for the subdirectory.
148  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/token/vtktoken/token/testing/cmake_install.cmake")
149 endif()
150
