1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/cont/internal" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/include/vtkm/cont/internal/DefaultTypesVTK.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/cont" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/include/vtkm/cont/DefaultTypes.h")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/cont" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/include/vtkm/cont/vtkm_cont_export.h")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/cont" TYPE FILE FILES
59  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Algorithm.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayCopy.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayCopyDevice.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayExtractComponent.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayGetValues.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandle.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleBasic.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleBitField.h"
67  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleCartesianProduct.h"
68  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleCast.h"
69  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleCompositeVector.h"
70  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleConcatenate.h"
71  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleConstant.h"
72  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleCounting.h"
73  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleDecorator.h"
74  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleDiscard.h"
75  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleExtractComponent.h"
76  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleGroupVec.h"
77  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleGroupVecVariable.h"
78  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleImplicit.h"
79  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleIndex.h"
80  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleMultiplexer.h"
81  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleOffsetsToNumComponents.h"
82  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandlePermutation.h"
83  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleRecombineVec.h"
84  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleReverse.h"
85  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleRandomStandardNormal.h"
86  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleRandomUniformBits.h"
87  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleRandomUniformReal.h"
88  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleRuntimeVec.h"
89  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleSOA.h"
90  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleStride.h"
91  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleSwizzle.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleTransform.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleUniformPointCoordinates.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleView.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleXGCCoordinates.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayHandleZip.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayPortal.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayPortalToIterators.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayRangeCompute.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayRangeComputeTemplate.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ArrayRangeComputeTemplateInstantiationsIncludes.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/AssignerPartitionedDataSet.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/AtomicArray.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/BitField.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/BoundsCompute.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/BoundsGlobalCompute.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CastAndCall.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorBoundingIntervalHierarchy.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorChooser.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorGeneral.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorPartitioned.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorRectilinearGrid.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorTwoLevel.h"
114  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorUniformBins.h"
115  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellLocatorUniformGrid.h"
116  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSet.h"
117  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSetExplicit.h"
118  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSetExtrude.h"
119  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSetList.h"
120  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSetPermutation.h"
121  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSetSingleType.h"
122  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSetStructured.h"
123  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ColorTable.h"
124  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ColorTableMap.h"
125  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ColorTableSamples.h"
126  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ConvertNumComponentsToOffsets.h"
127  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CoordinateSystem.h"
128  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DataSet.h"
129  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DataSetBuilderCurvilinear.h"
130  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DataSetBuilderExplicit.h"
131  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DataSetBuilderRectilinear.h"
132  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DataSetBuilderUniform.h"
133  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DeviceAdapter.h"
134  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DeviceAdapterAlgorithm.h"
135  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DeviceAdapterList.h"
136  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DeviceAdapterTag.h"
137  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/DIYMemoryManagement.h"
138  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/EnvironmentTracker.h"
139  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Error.h"
140  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorBadAllocation.h"
141  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorBadDevice.h"
142  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorBadType.h"
143  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorBadValue.h"
144  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorExecution.h"
145  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorFilterExecution.h"
146  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorInternal.h"
147  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ErrorUserAbort.h"
148  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ExecutionAndControlObjectBase.h"
149  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ExecutionObjectBase.h"
150  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Field.h"
151  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/FieldRangeCompute.h"
152  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/FieldRangeGlobalCompute.h"
153  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Initialize.h"
154  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Invoker.h"
155  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Logging.h"
156  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/MergePartitionedDataSet.h"
157  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ParticleArrayCopy.h"
158  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/PartitionedDataSet.h"
159  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/PointLocatorSparseGrid.h"
160  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/RuntimeDeviceInformation.h"
161  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/RuntimeDeviceTracker.h"
162  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Serialization.h"
163  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Storage.h"
164  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/StorageList.h"
165  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Timer.h"
166  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Token.h"
167  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/TryExecute.h"
168  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/SerializableTypeString.h"
169  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/UncertainArrayHandle.h"
170  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/UncertainCellSet.h"
171  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/UnknownArrayHandle.h"
172  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/UnknownCellSet.h"
173  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/Variant.h"
174  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CellSetExplicit.hxx"
175  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/ParticleArrayCopy.hxx"
176  )
177 endif()
178
179 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
180  foreach(file
181  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so.2.2.0"
182  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so.2.2"
183  )
184  if(EXISTS "${file}" AND
185  NOT IS_SYMLINK "${file}")
186  file(RPATH_CHECK
187  FILE "${file}"
188  RPATH "$ORIGIN")
189  endif()
190  endforeach()
191  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
192  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_cont-pv5.13.so.2.2.0"
193  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_cont-pv5.13.so.2.2"
194  )
195  foreach(file
196  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so.2.2.0"
197  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so.2.2"
198  )
199  if(EXISTS "${file}" AND
200  NOT IS_SYMLINK "${file}")
201  file(RPATH_CHANGE
202  FILE "${file}"
203  OLD_RPATH "\$ORIGIN:"
204  NEW_RPATH "$ORIGIN")
205  if(CMAKE_INSTALL_DO_STRIP)
206  execute_process(COMMAND "/usr/bin/strip" "${file}")
207  endif()
208  endif()
209  endforeach()
210 endif()
211
212 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
213  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so" AND
214  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so")
215  file(RPATH_CHECK
216  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so"
217  RPATH "$ORIGIN")
218  endif()
219  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_cont-pv5.13.so")
220  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so" AND
221  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so")
222  file(RPATH_CHANGE
223  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so"
224  OLD_RPATH "\$ORIGIN:"
225  NEW_RPATH "$ORIGIN")
226  if(CMAKE_INSTALL_DO_STRIP)
227  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_cont-pv5.13.so")
228  endif()
229  endif()
230 endif()
231
232 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
233  # Include the install script for the subdirectory.
234  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/internal/cmake_install.cmake")
235 endif()
236
237 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
238  # Include the install script for the subdirectory.
239  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/arg/cmake_install.cmake")
240 endif()
241
vtkm::ListAppend< VTKM_DEFAULT_CELL_SET_LIST_STRUCTURED, VTKM_DEFAULT_CELL_SET_LIST_UNSTRUCTURED > CellSetList
Definition: DefaultTypes.h:71
