1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/vtk-m/vtkm/io" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/BOVDataSetReader.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/DecodePNG.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/EncodePNG.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ErrorIO.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/FileUtils.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderBase.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderPNG.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageReaderPNM.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageUtils.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterBase.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterPNG.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/ImageWriterPNM.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/PixelTypes.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetReader.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetReaderBase.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKDataSetWriter.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKPolyDataReader.h" 64 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKRectilinearGridReader.h" 65 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKStructuredGridReader.h" 66 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKStructuredPointsReader.h" 67 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKUnstructuredGridReader.h" 68 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/VTKVisItFileReader.h" 69 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/io/PixelTypes.hxx" 73 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xUnspecifiedx
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/io
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/include/
vtkm/io/vtkm_io_export.h
") 77 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkvtkm/
vtk-m/
vtkm/io
" TYPE FILE FILES 79 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 80 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/io/DecodePNG.h
" 81 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/io/EncodePNG.h
" 82 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/io/ErrorIO.h
" 83 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/io/FileUtils.h
" 84 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 85 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 86 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 87 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 88 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 89 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 90 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 91 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 97 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
" 105 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 107 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2.0
" 108 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2
" 110 if(EXISTS "${file}
" AND 111 NOT IS_SYMLINK "${file}
") 117 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 118 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_io-pv5.13.so.2.2.0
" 119 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_io-pv5.13.so.2.2
" 122 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2.0
" 123 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so.2.2
" 125 if(EXISTS "${file}
" AND 126 NOT IS_SYMLINK "${file}
") 129 OLD_RPATH "\$ORIGIN:
" 131 if(CMAKE_INSTALL_DO_STRIP) 132 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 138 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 139 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so
" AND 140 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so
") 142 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so
" 145 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkm_io-pv5.13.so
") 146 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so
" AND 147 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so
") 149 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so
" 150 OLD_RPATH "\$ORIGIN:
" 152 if(CMAKE_INSTALL_DO_STRIP) 153 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkm_io-pv5.13.so
") 158 if(NOT CMAKE_INSTALL_LOCAL_ONLY) 159 # Include the install script for the subdirectory. 160 include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/
vtkm/vtkvtkm/
vtk-m/
vtkm/io/
internal/cmake_install.cmake
