1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/vtkmetaio 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
47 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv6.0.so.6.0" 48 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv6.0.so.1" 50 if(EXISTS
"${file}" AND
51 NOT IS_SYMLINK
"${file}")
" TYPE SHARED_LIBRARY FILES 58 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkmetaio-pv6.0.so.6.0
" 59 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkmetaio-pv6.0.so.1
" 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv6.0.so.6.0
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv6.0.so.1
" 65 if(EXISTS "${file}
") 71 if(CMAKE_INSTALL_DO_STRIP) 72 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 79 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkmetaio-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 85 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/
vtkmetaio" TYPE FILE FILES 87 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/localMetaConfiguration.h
" 88 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaArray.h
" 89 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaArrow.h
" 90 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaBlob.h
" 91 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaCommand.h
" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaContour.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaDTITube.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaEllipse.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaEvent.h
" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaFEMObject.h
" 97 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaForm.h
" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaGaussian.h
" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaGroup.h
" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaImage.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaImageTypes.h
" 102 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaImageUtils.h
" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaLandmark.h
" 104 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaLine.h
" 105 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaMesh.h
" 106 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaObject.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaScene.h
" 108 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaSurface.h
" 109 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaTube.h
" 110 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaTransform.h
" 111 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaTubeGraph.h
" 112 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaTypes.h
" 113 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaUtils.h
" 114 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/MetaIO/
vtkmetaio/metaVesselTube.h
" 115 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/MetaIO/
vtkmetaio/metaIOConfig.h
" 119 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
