1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/octree" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree.txx" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_cursor.txx" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_iterator.txx" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_node.txx" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_path.txx" 55 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
56 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/octree
" TYPE FILE FILES 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree
" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree.h
" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_cursor.h
" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_iterator.h
" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_node.h
" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Utilities/octree/octree/octree_path.h
" 66 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 69 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Utilities/octree/vtkoctree.spdx
