1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Views/Context2D
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Context2D/vtkContextInteractorStyle.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Context2D/vtkContextView.h"
49  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Views/Context2D/vtkViewsContext2DModule.h"
50  )
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkViewsContext2D-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkViewsContext2D-hierarchy.txt")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
58  foreach(file
59  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so.5.13"
60  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so.1"
61  )
62  if(EXISTS "${file}" AND
63  NOT IS_SYMLINK "${file}")
64  file(RPATH_CHECK
65  FILE "${file}"
66  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
67  endif()
68  endforeach()
69  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
70  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkViewsContext2D-pv5.13.so.5.13"
71  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkViewsContext2D-pv5.13.so.1"
72  )
73  foreach(file
74  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so.5.13"
75  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so.1"
76  )
77  if(EXISTS "${file}" AND
78  NOT IS_SYMLINK "${file}")
79  file(RPATH_CHANGE
80  FILE "${file}"
81  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
82  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
83  if(CMAKE_INSTALL_DO_STRIP)
84  execute_process(COMMAND "/usr/bin/strip" "${file}")
85  endif()
86  endif()
87  endforeach()
88 endif()
89
90 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
91  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so" AND
92  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so")
93  file(RPATH_CHECK
94  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so"
95  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
96  endif()
97  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkViewsContext2D-pv5.13.so")
98  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so" AND
99  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so")
100  file(RPATH_CHANGE
101  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so"
102  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
103  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
104  if(CMAKE_INSTALL_DO_STRIP)
105  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsContext2D-pv5.13.so")
106  endif()
107  endif()
108 endif()
109
110 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xspdxx" OR NOT CMAKE_INSTALL_COMPONENT)
111  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Views/Context2D/vtkViewsContext2D.spdx")
112 endif()
113
