1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Views/Core 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Core/vtkConvertSelectionDomain.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Core/vtkDataRepresentation.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Core/vtkEmptyRepresentation.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Core/vtkRenderViewBase.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Core/vtkView.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Core/vtkViewTheme.h" 53 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Views/Core/vtkViewsCoreModule.h" 57 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkViewsCore-hierarchy.txt
vtk/hierarchy/ParaView/vtkViewsCore-hierarchy.txt
") 61 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so.5.13
" 64 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so.1
" 66 if(EXISTS "${file}
" AND 67 NOT IS_SYMLINK "${file}
") 70 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 73 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 74 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkViewsCore-pv5.13.so.5.13
" 75 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkViewsCore-pv5.13.so.1
" 78 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so.5.13
" 79 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so.1
" 81 if(EXISTS "${file}
" AND 82 NOT IS_SYMLINK "${file}
") 85 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 86 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 87 if(CMAKE_INSTALL_DO_STRIP) 88 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 94 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 95 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so
" AND 96 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so
") 98 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so
" 99 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 101 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkViewsCore-pv5.13.so
") 102 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so
" AND 103 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so
") 105 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so
" 106 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 107 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 108 if(CMAKE_INSTALL_DO_STRIP) 109 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkViewsCore-pv5.13.so
") 114 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 115 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkViewsCore
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Views/Core/LICENSE
") 118 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xspdxx
" OR NOT CMAKE_INSTALL_COMPONENT) 119 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Views/Core/vtkViewsCore.spdx
