1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParse.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseAttributes.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseData.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseDepends.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseExtras.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseHierarchy.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMain.h" 54 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMangle.h" 55 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMerge.h" 56 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMethodType.h" 57 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParsePreprocess.h" 58 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseProperties.h" 59 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseString.h" 60 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseSystem.h" 61 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseType.h" 62 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkWrap.h" 63 "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkWrapText.h" 64 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Wrapping/Tools/vtkWrappingToolsModule.h" 68 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 70 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.5.13
" 71 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.1
" 73 if(EXISTS "${file}
" AND 74 NOT IS_SYMLINK "${file}
") 80 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 81 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWrappingTools-pv5.13.so.5.13
" 82 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWrappingTools-pv5.13.so.1
" 85 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.5.13
" 86 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.1
" 88 if(EXISTS "${file}
" AND 89 NOT IS_SYMLINK "${file}
") 94 if(CMAKE_INSTALL_DO_STRIP) 95 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 101 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 102 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so
" AND 103 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so
") 105 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so
" 108 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWrappingTools-pv5.13.so
") 109 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so
" AND 110 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so
") 112 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so
" 114 NEW_RPATH "\$ORIGIN
") 115 if(CMAKE_INSTALL_DO_STRIP) 116 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so
") 121 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xspdxx
" OR NOT CMAKE_INSTALL_COMPONENT) 122 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Wrapping/Tools/vtkWrappingTools.spdx
") 125 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 126 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13
" AND 127 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13
") 129 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13
" 130 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 132 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapHierarchy-pv5.13
") 133 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13
" AND 134 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13
") 136 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13
" 137 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 138 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 139 if(CMAKE_INSTALL_DO_STRIP) 140 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13
") 145 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 146 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13
" AND 147 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13
") 149 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13
" 150 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 152 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapPython-pv5.13
") 153 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13
" AND 154 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13
") 156 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13
" 157 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 158 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 159 if(CMAKE_INSTALL_DO_STRIP) 160 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13
") 165 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 166 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13
" AND 167 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13
") 169 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13
" 170 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 172 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapPythonInit-pv5.13
") 173 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13
" AND 174 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13
") 176 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13
" 177 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 178 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 179 if(CMAKE_INSTALL_DO_STRIP) 180 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13
") 185 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 186 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13
" AND 187 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13
") 189 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13
" 190 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 192 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkParseJava-pv5.13
") 193 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13
" AND 194 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13
") 196 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13
" 197 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 198 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 199 if(CMAKE_INSTALL_DO_STRIP) 200 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13
") 205 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 206 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13
" AND 207 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13
") 209 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13
" 210 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 212 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapJava-pv5.13
") 213 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13
" AND 214 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13
") 216 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13
" 217 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 218 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 219 if(CMAKE_INSTALL_DO_STRIP) 220 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13
") 225 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 226 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13
" AND 227 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13
") 229 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13
" 230 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 232 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapSerDes-pv5.13
") 233 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13
" AND 234 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13
") 236 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13
" 237 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 238 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 239 if(CMAKE_INSTALL_DO_STRIP) 240 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13
