1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Web/Python
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/__init__.py")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/_default_proxies.py")
51 endif()
52
53 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/camera.py")
55 endif()
56
57 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/data_converter.py")
59 endif()
60
61 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/data_writer.py")
63 endif()
64
65 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/dataset_builder.py")
67 endif()
68
69 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/decorators.py")
71 endif()
72
73 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/helper.py")
75 endif()
76
77 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/protocols.py")
79 endif()
80
81 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/pv_wslink.py")
83 endif()
84
85 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/test_server.py")
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/vtkjs_helper.py")
91 endif()
92
93 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages/paraview/web" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/venv.py")
95 endif()
96
