Public Types | Public Member Functions | Static Public Member Functions | Public Attributes | Static Public Attributes | Protected Member Functions | Friends | List of all members
paraview_protobuf::PROTOBUF_FINAL Class Reference
#include <vtkPVMessage.pb.h>
Inherits Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, Message, and Message.
enum  : int {
  kIdtypeFieldNumber = 3, kIntegerFieldNumber = 4, kFloat64FieldNumber = 5, kProxyGlobalIdFieldNumber = 6,
  kPortNumberFieldNumber = 7, kTxtFieldNumber = 8, kBinaryFieldNumber = 9, kTypeFieldNumber = 1
enum  : int { kVariantFieldNumber = 1 }
enum  : int { kItemFieldNumber = 1 }
enum  : int {
  kGlobalIdFieldNumber = 1, kLocationFieldNumber = 2, kShareOnlyFieldNumber = 3, kReqDefFieldNumber = 4,
  kClientIdFieldNumber = 5
enum  : int { kNameFieldNumber = 1, kGlobalIdFieldNumber = 1 }
enum  : int { kKeyFieldNumber = 1, kValueFieldNumber = 2 }
enum  : int { kVariantFieldNumber = 1, kKeyFieldNumber = 1 }
enum  : int { kUserDataFieldNumber = 3, kNameFieldNumber = 1, kValueFieldNumber = 2 }
enum  : int { kGroupFieldNumber = 1, kNameFieldNumber = 1, kGlobalIdFieldNumber = 1 }
enum  : int { kGroupFieldNumber = 1, kNameFieldNumber = 1, kXmlFieldNumber = 3 }
enum  : int { kPropertyNameFieldNumber = 2, kProxyFieldNumber = 1, kDirectionFieldNumber = 3 }
enum  : int {
  kNameFieldNumber = 1, kUserFieldNumber = 1, kIsMasterFieldNumber = 3, kFollowCamFieldNumber = 4,
  kDisableFurtherConnectionsFieldNumber = 5, kConnectIdFieldNumber = 6
typedef Variant_Type Type
typedef ProxyState_SubProxy SubProxy
typedef ProxyState_Annotation Annotation
typedef ProxyState_UserData UserData
typedef ProxyState_Property Property
typedef PXMRegistrationState_Entry Entry
typedef ProxyDefinitionState_ProxyXMLDefinition ProxyXMLDefinition
typedef LinkState_LinkDescription_Direction Direction
typedef LinkState_LinkDescription LinkDescription
typedef MousePointer_Ratio Ratio
typedef ClientsInformation_ClientInfo ClientInfo
typedef QtEvent_QtEventType QtEventType
 Variant ()
virtual ~Variant ()
 Variant (const Variant &from)
 Variant (Variant &&from) noexcept
Variantoperator= (const Variant &from)
Variantoperator= (Variant &&from) noexcept
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & unknown_fields () const
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * mutable_unknown_fields ()
void Swap (Variant *other)
void UnsafeArenaSwap (Variant *other)
VariantNew () const final
VariantNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ::PROTOBUF_NAMESPACE_ID::Message &from) final
void MergeFrom (const ::PROTOBUF_NAMESPACE_ID::Message &from) final
void CopyFrom (const Variant &from)
void MergeFrom (const Variant &from)
PROTOBUF_ATTRIBUTE_REINITIALIZES void Clear () final
bool IsInitialized () const final
size_t ByteSizeLong () const final
const char * _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final
::PROTOBUF_NAMESPACE_ID::uint8 * _InternalSerialize (::PROTOBUF_NAMESPACE_ID::uint8 *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final
int GetCachedSize () const final
::PROTOBUF_NAMESPACE_ID::Metadata GetMetadata () const final
int idtype_size () const
void clear_idtype ()
::PROTOBUF_NAMESPACE_ID::int64 idtype (int index) const
void set_idtype (int index, ::PROTOBUF_NAMESPACE_ID::int64 value)
void add_idtype (::PROTOBUF_NAMESPACE_ID::int64 value)
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int64 > & idtype () const
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int64 > * mutable_idtype ()
int integer_size () const
void clear_integer ()
::PROTOBUF_NAMESPACE_ID::int32 integer (int index) const
void set_integer (int index, ::PROTOBUF_NAMESPACE_ID::int32 value)
void add_integer (::PROTOBUF_NAMESPACE_ID::int32 value)
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 > & integer () const
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 > * mutable_integer ()
int float64_size () const
void clear_float64 ()
double float64 (int index) const
void set_float64 (int index, double value)
void add_float64 (double value)
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< double > & float64 () const
::PROTOBUF_NAMESPACE_ID::RepeatedField< double > * mutable_float64 ()
int proxy_global_id_size () const
void clear_proxy_global_id ()
::PROTOBUF_NAMESPACE_ID::uint64 proxy_global_id (int index) const
void set_proxy_global_id (int index, ::PROTOBUF_NAMESPACE_ID::uint64 value)
void add_proxy_global_id (::PROTOBUF_NAMESPACE_ID::uint64 value)
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::uint64 > & proxy_global_id () const
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::uint64 > * mutable_proxy_global_id ()
int port_number_size () const
void clear_port_number ()
::PROTOBUF_NAMESPACE_ID::int32 port_number (int index) const
void set_port_number (int index, ::PROTOBUF_NAMESPACE_ID::int32 value)
void add_port_number (::PROTOBUF_NAMESPACE_ID::int32 value)
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 > & port_number () const
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 > * mutable_port_number ()
int txt_size () const
void clear_txt ()
const std::stringtxt (int index) const
std::stringmutable_txt (int index)
void set_txt (int index, const std::string &value)
void set_txt (int index, std::string &&value)
void set_txt (int index, const char *value)
void set_txt (int index, const char *value, size_t size)
std::stringadd_txt ()
void add_txt (const std::string &value)
void add_txt (std::string &&value)
void add_txt (const char *value)
void add_txt (const char *value, size_t size)
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > & txt () const
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > * mutable_txt ()
int binary_size () const
void clear_binary ()
const std::stringbinary (int index) const
std::stringmutable_binary (int index)
void set_binary (int index, const std::string &value)
void set_binary (int index, std::string &&value)
void set_binary (int index, const char *value)
void set_binary (int index, const void *value, size_t size)
std::stringadd_binary ()
void add_binary (const std::string &value)
void add_binary (std::string &&value)
void add_binary (const char *value)
void add_binary (const void *value, size_t size)
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > & binary () const
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > * mutable_binary ()
bool has_type () const
void clear_type ()
::paraview_protobuf::Variant_Type type () const
void set_type (::paraview_protobuf::Variant_Type value)
 VariantList ()
virtual ~VariantList ()
 VariantList (const VariantList &from)
 VariantList (VariantList &&from) noexcept
VariantListoperator= (const VariantList &from)
VariantListoperator= (VariantList &&from) noexcept
void Swap (VariantList *other)
void UnsafeArenaSwap (VariantList *other)
VariantListNew () const final
VariantListNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const VariantList &from)
void MergeFrom (const VariantList &from)
int variant_size () const
void clear_variant ()
::paraview_protobuf::Variant * mutable_variant (int index)
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Variant > * mutable_variant ()
const ::paraview_protobuf::Variant & variant (int index) const
::paraview_protobuf::Variant * add_variant ()
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Variant > & variant () const
 MessageCollection ()
virtual ~MessageCollection ()
 MessageCollection (const MessageCollection &from)
 MessageCollection (MessageCollection &&from) noexcept
MessageCollectionoperator= (const MessageCollection &from)
MessageCollectionoperator= (MessageCollection &&from) noexcept
void Swap (MessageCollection *other)
void UnsafeArenaSwap (MessageCollection *other)
MessageCollectionNew () const final
MessageCollectionNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const MessageCollection &from)
void MergeFrom (const MessageCollection &from)
int item_size () const
void clear_item ()
::paraview_protobuf::Message * mutable_item (int index)
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Message > * mutable_item ()
const ::paraview_protobuf::Message & item (int index) const
::paraview_protobuf::Message * add_item ()
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Message > & item () const
 Message ()
virtual ~Message ()
 Message (const Message &from)
 Message (Message &&from) noexcept
Messageoperator= (const Message &from)
Messageoperator= (Message &&from) noexcept
void Swap (Message *other)
void UnsafeArenaSwap (Message *other)
MessageNew () const final
MessageNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const Message &from)
void MergeFrom (const Message &from)
bool has_global_id () const
void clear_global_id ()
::PROTOBUF_NAMESPACE_ID::uint64 global_id () const
void set_global_id (::PROTOBUF_NAMESPACE_ID::uint64 value)
bool has_location () const
void clear_location ()
::PROTOBUF_NAMESPACE_ID::uint32 location () const
void set_location (::PROTOBUF_NAMESPACE_ID::uint32 value)
bool has_share_only () const
void clear_share_only ()
bool share_only () const
void set_share_only (bool value)
bool has_req_def () const
void clear_req_def ()
bool req_def () const
void set_req_def (bool value)
bool has_client_id () const
void clear_client_id ()
::PROTOBUF_NAMESPACE_ID::uint32 client_id () const
void set_client_id (::PROTOBUF_NAMESPACE_ID::uint32 value)
 DefinitionHeader ()
virtual ~DefinitionHeader ()
 DefinitionHeader (const DefinitionHeader &from)
 DefinitionHeader (DefinitionHeader &&from) noexcept
DefinitionHeaderoperator= (const DefinitionHeader &from)
DefinitionHeaderoperator= (DefinitionHeader &&from) noexcept
void Swap (DefinitionHeader *other)
void UnsafeArenaSwap (DefinitionHeader *other)
DefinitionHeaderNew () const final
DefinitionHeaderNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const DefinitionHeader &from)
void MergeFrom (const DefinitionHeader &from)
 ProxyState_SubProxy ()
virtual ~ProxyState_SubProxy ()
 ProxyState_SubProxy (const ProxyState_SubProxy &from)
 ProxyState_SubProxy (ProxyState_SubProxy &&from) noexcept
ProxyState_SubProxyoperator= (const ProxyState_SubProxy &from)
ProxyState_SubProxyoperator= (ProxyState_SubProxy &&from) noexcept
void Swap (ProxyState_SubProxy *other)
void UnsafeArenaSwap (ProxyState_SubProxy *other)
ProxyState_SubProxyNew () const final
ProxyState_SubProxyNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxyState_SubProxy &from)
void MergeFrom (const ProxyState_SubProxy &from)
bool has_name () const
void clear_name ()
const std::stringname () const
void set_name (const std::string &value)
void set_name (std::string &&value)
void set_name (const char *value)
void set_name (const char *value, size_t size)
std::stringmutable_name ()
std::stringrelease_name ()
void set_allocated_name (std::string *name)
::PROTOBUF_NAMESPACE_ID::uint32 global_id () const
void set_global_id (::PROTOBUF_NAMESPACE_ID::uint32 value)
 ProxyState_Annotation ()
virtual ~ProxyState_Annotation ()
 ProxyState_Annotation (const ProxyState_Annotation &from)
 ProxyState_Annotation (ProxyState_Annotation &&from) noexcept
ProxyState_Annotationoperator= (const ProxyState_Annotation &from)
ProxyState_Annotationoperator= (ProxyState_Annotation &&from) noexcept
void Swap (ProxyState_Annotation *other)
void UnsafeArenaSwap (ProxyState_Annotation *other)
ProxyState_AnnotationNew () const final
ProxyState_AnnotationNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxyState_Annotation &from)
void MergeFrom (const ProxyState_Annotation &from)
bool has_key () const
void clear_key ()
const std::stringkey () const
void set_key (const std::string &value)
void set_key (std::string &&value)
void set_key (const char *value)
void set_key (const char *value, size_t size)
std::stringmutable_key ()
std::stringrelease_key ()
void set_allocated_key (std::string *key)
bool has_value () const
void clear_value ()
const std::stringvalue () const
void set_value (const std::string &value)
void set_value (std::string &&value)
void set_value (const char *value)
void set_value (const char *value, size_t size)
std::stringmutable_value ()
std::stringrelease_value ()
void set_allocated_value (std::string *value)
 ProxyState_UserData ()
virtual ~ProxyState_UserData ()
 ProxyState_UserData (const ProxyState_UserData &from)
 ProxyState_UserData (ProxyState_UserData &&from) noexcept
ProxyState_UserDataoperator= (const ProxyState_UserData &from)
ProxyState_UserDataoperator= (ProxyState_UserData &&from) noexcept
void Swap (ProxyState_UserData *other)
void UnsafeArenaSwap (ProxyState_UserData *other)
ProxyState_UserDataNew () const final
ProxyState_UserDataNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxyState_UserData &from)
void MergeFrom (const ProxyState_UserData &from)
void clear_key ()
 ProxyState_Property ()
virtual ~ProxyState_Property ()
 ProxyState_Property (const ProxyState_Property &from)
 ProxyState_Property (ProxyState_Property &&from) noexcept
ProxyState_Propertyoperator= (const ProxyState_Property &from)
ProxyState_Propertyoperator= (ProxyState_Property &&from) noexcept
void Swap (ProxyState_Property *other)
void UnsafeArenaSwap (ProxyState_Property *other)
ProxyState_PropertyNew () const final
ProxyState_PropertyNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxyState_Property &from)
void MergeFrom (const ProxyState_Property &from)
int user_data_size () const
void clear_user_data ()
::paraview_protobuf::ProxyState_UserData * mutable_user_data (int index)
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::ProxyState_UserData > * mutable_user_data ()
const ::paraview_protobuf::ProxyState_UserData & user_data (int index) const
::paraview_protobuf::ProxyState_UserData * add_user_data ()
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::ProxyState_UserData > & user_data () const
void clear_name ()
void clear_value ()
const ::paraview_protobuf::Variant & value () const
::paraview_protobuf::Variant * release_value ()
::paraview_protobuf::Variant * mutable_value ()
void set_allocated_value (::paraview_protobuf::Variant *value)
void unsafe_arena_set_allocated_value (::paraview_protobuf::Variant *value)
::paraview_protobuf::Variant * unsafe_arena_release_value ()
 ProxyState ()
virtual ~ProxyState ()
 ProxyState (const ProxyState &from)
 ProxyState (ProxyState &&from) noexcept
ProxyStateoperator= (const ProxyState &from)
ProxyStateoperator= (ProxyState &&from) noexcept
void Swap (ProxyState *other)
void UnsafeArenaSwap (ProxyState *other)
ProxyStateNew () const final
ProxyStateNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxyState &from)
void MergeFrom (const ProxyState &from)
 PXMRegistrationState_Entry ()
virtual ~PXMRegistrationState_Entry ()
 PXMRegistrationState_Entry (const PXMRegistrationState_Entry &from)
 PXMRegistrationState_Entry (PXMRegistrationState_Entry &&from) noexcept
PXMRegistrationState_Entryoperator= (const PXMRegistrationState_Entry &from)
PXMRegistrationState_Entryoperator= (PXMRegistrationState_Entry &&from) noexcept
void Swap (PXMRegistrationState_Entry *other)
void UnsafeArenaSwap (PXMRegistrationState_Entry *other)
PXMRegistrationState_EntryNew () const final
PXMRegistrationState_EntryNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const PXMRegistrationState_Entry &from)
void MergeFrom (const PXMRegistrationState_Entry &from)
bool has_group () const
void clear_group ()
const std::stringgroup () const
void set_group (const std::string &value)
void set_group (std::string &&value)
void set_group (const char *value)
void set_group (const char *value, size_t size)
std::stringmutable_group ()
std::stringrelease_group ()
void set_allocated_group (std::string *group)
void clear_name ()
 PXMRegistrationState ()
virtual ~PXMRegistrationState ()
 PXMRegistrationState (const PXMRegistrationState &from)
 PXMRegistrationState (PXMRegistrationState &&from) noexcept
PXMRegistrationStateoperator= (const PXMRegistrationState &from)
PXMRegistrationStateoperator= (PXMRegistrationState &&from) noexcept
void Swap (PXMRegistrationState *other)
void UnsafeArenaSwap (PXMRegistrationState *other)
PXMRegistrationStateNew () const final
PXMRegistrationStateNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const PXMRegistrationState &from)
void MergeFrom (const PXMRegistrationState &from)
 ProxyDefinitionState_ProxyXMLDefinition ()
virtual ~ProxyDefinitionState_ProxyXMLDefinition ()
 ProxyDefinitionState_ProxyXMLDefinition (const ProxyDefinitionState_ProxyXMLDefinition &from)
 ProxyDefinitionState_ProxyXMLDefinition (ProxyDefinitionState_ProxyXMLDefinition &&from) noexcept
ProxyDefinitionState_ProxyXMLDefinitionoperator= (const ProxyDefinitionState_ProxyXMLDefinition &from)
ProxyDefinitionState_ProxyXMLDefinitionoperator= (ProxyDefinitionState_ProxyXMLDefinition &&from) noexcept
void Swap (ProxyDefinitionState_ProxyXMLDefinition *other)
void UnsafeArenaSwap (ProxyDefinitionState_ProxyXMLDefinition *other)
ProxyDefinitionState_ProxyXMLDefinitionNew () const final
ProxyDefinitionState_ProxyXMLDefinitionNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxyDefinitionState_ProxyXMLDefinition &from)
void MergeFrom (const ProxyDefinitionState_ProxyXMLDefinition &from)
void clear_group ()
void clear_name ()
bool has_xml () const
void clear_xml ()
const std::stringxml () const
void set_xml (const std::string &value)
void set_xml (std::string &&value)
void set_xml (const char *value)
void set_xml (const char *value, size_t size)
std::stringmutable_xml ()
std::stringrelease_xml ()
void set_allocated_xml (std::string *xml)
 ProxyDefinitionState ()
virtual ~ProxyDefinitionState ()
 ProxyDefinitionState (const ProxyDefinitionState &from)
 ProxyDefinitionState (ProxyDefinitionState &&from) noexcept
ProxyDefinitionStateoperator= (const ProxyDefinitionState &from)
ProxyDefinitionStateoperator= (ProxyDefinitionState &&from) noexcept
void Swap (ProxyDefinitionState *other)
void UnsafeArenaSwap (ProxyDefinitionState *other)
ProxyDefinitionStateNew () const final
ProxyDefinitionStateNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxyDefinitionState &from)
void MergeFrom (const ProxyDefinitionState &from)
 PullRequest ()
virtual ~PullRequest ()
 PullRequest (const PullRequest &from)
 PullRequest (PullRequest &&from) noexcept
PullRequestoperator= (const PullRequest &from)
PullRequestoperator= (PullRequest &&from) noexcept
void Swap (PullRequest *other)
void UnsafeArenaSwap (PullRequest *other)
PullRequestNew () const final
PullRequestNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const PullRequest &from)
void MergeFrom (const PullRequest &from)
 ProxySelectionModelState ()
virtual ~ProxySelectionModelState ()
 ProxySelectionModelState (const ProxySelectionModelState &from)
 ProxySelectionModelState (ProxySelectionModelState &&from) noexcept
ProxySelectionModelStateoperator= (const ProxySelectionModelState &from)
ProxySelectionModelStateoperator= (ProxySelectionModelState &&from) noexcept
void Swap (ProxySelectionModelState *other)
void UnsafeArenaSwap (ProxySelectionModelState *other)
ProxySelectionModelStateNew () const final
ProxySelectionModelStateNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ProxySelectionModelState &from)
void MergeFrom (const ProxySelectionModelState &from)
 LinkState_LinkDescription ()
virtual ~LinkState_LinkDescription ()
 LinkState_LinkDescription (const LinkState_LinkDescription &from)
 LinkState_LinkDescription (LinkState_LinkDescription &&from) noexcept
LinkState_LinkDescriptionoperator= (const LinkState_LinkDescription &from)
LinkState_LinkDescriptionoperator= (LinkState_LinkDescription &&from) noexcept
void Swap (LinkState_LinkDescription *other)
void UnsafeArenaSwap (LinkState_LinkDescription *other)
LinkState_LinkDescriptionNew () const final
LinkState_LinkDescriptionNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const LinkState_LinkDescription &from)
void MergeFrom (const LinkState_LinkDescription &from)
bool has_property_name () const
void clear_property_name ()
const std::stringproperty_name () const
void set_property_name (const std::string &value)
void set_property_name (std::string &&value)
void set_property_name (const char *value)
void set_property_name (const char *value, size_t size)
std::stringmutable_property_name ()
std::stringrelease_property_name ()
void set_allocated_property_name (std::string *property_name)
bool has_proxy () const
void clear_proxy ()
::PROTOBUF_NAMESPACE_ID::uint32 proxy () const
void set_proxy (::PROTOBUF_NAMESPACE_ID::uint32 value)
bool has_direction () const
void clear_direction ()
::paraview_protobuf::LinkState_LinkDescription_Direction direction () const
void set_direction (::paraview_protobuf::LinkState_LinkDescription_Direction value)
 LinkState ()
virtual ~LinkState ()
 LinkState (const LinkState &from)
 LinkState (LinkState &&from) noexcept
LinkStateoperator= (const LinkState &from)
LinkStateoperator= (LinkState &&from) noexcept
void Swap (LinkState *other)
void UnsafeArenaSwap (LinkState *other)
LinkStateNew () const final
LinkStateNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const LinkState &from)
void MergeFrom (const LinkState &from)
 MousePointer ()
virtual ~MousePointer ()
 MousePointer (const MousePointer &from)
 MousePointer (MousePointer &&from) noexcept
MousePointeroperator= (const MousePointer &from)
MousePointeroperator= (MousePointer &&from) noexcept
void Swap (MousePointer *other)
void UnsafeArenaSwap (MousePointer *other)
MousePointerNew () const final
MousePointerNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const MousePointer &from)
void MergeFrom (const MousePointer &from)
 ChartViewBounds ()
virtual ~ChartViewBounds ()
 ChartViewBounds (const ChartViewBounds &from)
 ChartViewBounds (ChartViewBounds &&from) noexcept
ChartViewBoundsoperator= (const ChartViewBounds &from)
ChartViewBoundsoperator= (ChartViewBounds &&from) noexcept
void Swap (ChartViewBounds *other)
void UnsafeArenaSwap (ChartViewBounds *other)
ChartViewBoundsNew () const final
ChartViewBoundsNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ChartViewBounds &from)
void MergeFrom (const ChartViewBounds &from)
 ClientsInformation_ClientInfo ()
virtual ~ClientsInformation_ClientInfo ()
 ClientsInformation_ClientInfo (const ClientsInformation_ClientInfo &from)
 ClientsInformation_ClientInfo (ClientsInformation_ClientInfo &&from) noexcept
ClientsInformation_ClientInfooperator= (const ClientsInformation_ClientInfo &from)
ClientsInformation_ClientInfooperator= (ClientsInformation_ClientInfo &&from) noexcept
void Swap (ClientsInformation_ClientInfo *other)
void UnsafeArenaSwap (ClientsInformation_ClientInfo *other)
ClientsInformation_ClientInfoNew () const final
ClientsInformation_ClientInfoNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ClientsInformation_ClientInfo &from)
void MergeFrom (const ClientsInformation_ClientInfo &from)
void clear_name ()
bool has_user () const
void clear_user ()
::PROTOBUF_NAMESPACE_ID::uint32 user () const
void set_user (::PROTOBUF_NAMESPACE_ID::uint32 value)
bool has_is_master () const
void clear_is_master ()
bool is_master () const
void set_is_master (bool value)
bool has_follow_cam () const
void clear_follow_cam ()
bool follow_cam () const
void set_follow_cam (bool value)
bool has_disable_further_connections () const
void clear_disable_further_connections ()
bool disable_further_connections () const
void set_disable_further_connections (bool value)
bool has_connect_id () const
void clear_connect_id ()
::PROTOBUF_NAMESPACE_ID::uint32 connect_id () const
void set_connect_id (::PROTOBUF_NAMESPACE_ID::uint32 value)
 ClientsInformation ()
virtual ~ClientsInformation ()
 ClientsInformation (const ClientsInformation &from)
 ClientsInformation (ClientsInformation &&from) noexcept
ClientsInformationoperator= (const ClientsInformation &from)
ClientsInformationoperator= (ClientsInformation &&from) noexcept
void Swap (ClientsInformation *other)
void UnsafeArenaSwap (ClientsInformation *other)
ClientsInformationNew () const final
ClientsInformationNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ClientsInformation &from)
void MergeFrom (const ClientsInformation &from)
 ChatMessage ()
virtual ~ChatMessage ()
 ChatMessage (const ChatMessage &from)
 ChatMessage (ChatMessage &&from) noexcept
ChatMessageoperator= (const ChatMessage &from)
ChatMessageoperator= (ChatMessage &&from) noexcept
void Swap (ChatMessage *other)
void UnsafeArenaSwap (ChatMessage *other)
ChatMessageNew () const final
ChatMessageNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const ChatMessage &from)
void MergeFrom (const ChatMessage &from)
 QtEvent ()
virtual ~QtEvent ()
 QtEvent (const QtEvent &from)
 QtEvent (QtEvent &&from) noexcept
QtEventoperator= (const QtEvent &from)
QtEventoperator= (QtEvent &&from) noexcept
void Swap (QtEvent *other)
void UnsafeArenaSwap (QtEvent *other)
QtEventNew () const final
QtEventNew (::PROTOBUF_NAMESPACE_ID::Arena *arena) const final
void CopyFrom (const QtEvent &from)
void MergeFrom (const QtEvent &from)
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * descriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * GetDescriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Reflection * GetReflection ()
static const Variantdefault_instance ()
static void InitAsDefaultInstance ()
static const Variantinternal_default_instance ()
static bool Type_IsValid (int value)
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * Type_descriptor ()
template<typename T >
static const std::stringType_Name (T enum_t_value)
static bool Type_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, Type *value)
static const VariantListdefault_instance ()
static const VariantListinternal_default_instance ()
static const MessageCollectiondefault_instance ()
static const MessageCollectioninternal_default_instance ()
static const Messagedefault_instance ()
static const Messageinternal_default_instance ()
static const DefinitionHeaderdefault_instance ()
static const DefinitionHeaderinternal_default_instance ()
static const ProxyState_SubProxydefault_instance ()
static const ProxyState_SubProxyinternal_default_instance ()
static const ProxyState_Annotationdefault_instance ()
static const ProxyState_Annotationinternal_default_instance ()
static const ProxyState_UserDatadefault_instance ()
static const ProxyState_UserDatainternal_default_instance ()
static const ProxyState_Propertydefault_instance ()
static const ProxyState_Propertyinternal_default_instance ()
static const ProxyStatedefault_instance ()
static const ProxyStateinternal_default_instance ()
static const PXMRegistrationState_Entrydefault_instance ()
static const PXMRegistrationState_Entryinternal_default_instance ()
static const PXMRegistrationStatedefault_instance ()
static const PXMRegistrationStateinternal_default_instance ()
static const ProxyDefinitionState_ProxyXMLDefinitiondefault_instance ()
static const ProxyDefinitionState_ProxyXMLDefinitioninternal_default_instance ()
static const ProxyDefinitionStatedefault_instance ()
static const ProxyDefinitionStateinternal_default_instance ()
static const PullRequestdefault_instance ()
static const PullRequestinternal_default_instance ()
static const ProxySelectionModelStatedefault_instance ()
static const ProxySelectionModelStateinternal_default_instance ()
static const LinkState_LinkDescriptiondefault_instance ()
static const LinkState_LinkDescriptioninternal_default_instance ()
static bool Direction_IsValid (int value)
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * Direction_descriptor ()
static const std::stringDirection_Name (T enum_t_value)
static bool Direction_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, Direction *value)
static const LinkStatedefault_instance ()
static const LinkStateinternal_default_instance ()
static const MousePointerdefault_instance ()
static const MousePointerinternal_default_instance ()
static bool Ratio_IsValid (int value)
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * Ratio_descriptor ()
static const std::stringRatio_Name (T enum_t_value)
static bool Ratio_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, Ratio *value)
static const ChartViewBoundsdefault_instance ()
static const ChartViewBoundsinternal_default_instance ()
static const ClientsInformation_ClientInfodefault_instance ()
static const ClientsInformation_ClientInfointernal_default_instance ()
static const ClientsInformationdefault_instance ()
static const ClientsInformationinternal_default_instance ()
static const ChatMessagedefault_instance ()
static const ChatMessageinternal_default_instance ()
static const QtEventdefault_instance ()
static const QtEventinternal_default_instance ()
static bool QtEventType_IsValid (int value)
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * QtEventType_descriptor ()
static const std::stringQtEventType_Name (T enum_t_value)
static bool QtEventType_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, QtEventType *value)
Public Attributes
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > client_class
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > server_class
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > xml_group
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > xml_name
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > xml_sub_proxy_name
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_Property >, 11, false > property
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_SubProxy >, 11, false > subproxy
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_Annotation >, 11, false > annotation
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > has_annotation
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_UserData >, 11, false > user_data
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > log_name
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > vtk_classname
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::PXMRegistrationState_Entry >, 11, false > registered_proxy
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::PXMRegistrationState_Entry >, 11, false > registered_selection_model
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::PXMRegistrationState_Entry >, 11, false > registered_link
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition >, 11, false > xml_definition_proxy
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition >, 11, false > xml_custom_definition_proxy
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::Variant >, 11, false > arguments
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > current_proxy
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::int32 >, 5, false > current_port
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedPrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > proxy
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedPrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::int32 >, 5, false > port
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > propagate_update
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > enabled
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > sync_interactive_renders
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::LinkState_LinkDescription >, 11, false > link
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedStringTypeTraits, 9, false > exception_property
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > view
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< double >, 1, false > x
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< double >, 1, false > y
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > forceShow
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::EnumTypeTraits< ::paraview_protobuf::MousePointer_Ratio, ::paraview_protobuf::MousePointer_Ratio_IsValid >, 14, false > ratioType
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedPrimitiveTypeTraits< double >, 1, false > range
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ClientsInformation_ClientInfo >, 11, false > user
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > author
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > txt
static ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::EnumTypeTraits< ::paraview_protobuf::QtEvent_QtEventType, ::paraview_protobuf::QtEvent_QtEventType_IsValid >, 14, false > type
static constexpr int kIndexInFileMessages
static constexpr Type INT
static constexpr Type FLOAT64
static constexpr Type IDTYPE
static constexpr Type STRING
static constexpr Type PROXY
static constexpr Type INPUT
static constexpr Type BYTES
static constexpr Type MAP
static constexpr Type Type_MIN
static constexpr Type Type_MAX
static constexpr int Type_ARRAYSIZE
static const int kClientClassFieldNumber = 10
static const int kServerClassFieldNumber = 11
static const int kXmlGroupFieldNumber = 20
static const int kXmlNameFieldNumber = 21
static const int kXmlSubProxyNameFieldNumber = 22
static const int kPropertyFieldNumber = 23
static const int kSubproxyFieldNumber = 24
static const int kAnnotationFieldNumber = 25
static const int kHasAnnotationFieldNumber = 26
static const int kUserDataFieldNumber = 27
static const int kLogNameFieldNumber = 28
static const int kVtkClassnameFieldNumber = 29
static const int kRegisteredProxyFieldNumber = 30
static const int kRegisteredSelectionModelFieldNumber = 31
static const int kRegisteredLinkFieldNumber = 32
static const int kXmlDefinitionProxyFieldNumber = 35
static const int kXmlCustomDefinitionProxyFieldNumber = 36
static const int kArgumentsFieldNumber = 40
static const int kCurrentProxyFieldNumber = 52
static const int kCurrentPortFieldNumber = 53
static const int kProxyFieldNumber = 50
static const int kPortFieldNumber = 51
static constexpr Direction NONE
static constexpr Direction INPUT
static constexpr Direction OUTPUT
static constexpr Direction Direction_MIN
static constexpr Direction Direction_MAX
static constexpr int Direction_ARRAYSIZE
static const int kPropagateUpdateFieldNumber = 60
static const int kEnabledFieldNumber = 61
static const int kSyncInteractiveRendersFieldNumber = 62
static const int kLinkFieldNumber = 63
static const int kExceptionPropertyFieldNumber = 64
static constexpr Ratio BOTH
static constexpr Ratio HEIGHT
static constexpr Ratio WIDTH
static constexpr Ratio Ratio_MIN
static constexpr Ratio Ratio_MAX
static constexpr int Ratio_ARRAYSIZE
static const int kViewFieldNumber = 70
static const int kXFieldNumber = 71
static const int kYFieldNumber = 72
static const int kForceShowFieldNumber = 73
static const int kRatioTypeFieldNumber = 74
static const int kRangeFieldNumber = 76
static const int kUserFieldNumber = 80
static const int kAuthorFieldNumber = 84
static const int kTxtFieldNumber = 85
static constexpr QtEventType CHAT
static constexpr QtEventType OTHER
static constexpr QtEventType QtEventType_MIN
static constexpr QtEventType QtEventType_MAX
static constexpr int QtEventType_ARRAYSIZE
static const int kTypeFieldNumber = 98
 Variant (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 VariantList (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 MessageCollection (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 Message (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 DefinitionHeader (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxyState_SubProxy (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxyState_Annotation (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxyState_UserData (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxyState_Property (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxyState (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 PXMRegistrationState_Entry (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 PXMRegistrationState (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxyDefinitionState_ProxyXMLDefinition (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxyDefinitionState (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 PullRequest (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ProxySelectionModelState (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 LinkState_LinkDescription (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 LinkState (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 MousePointer (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ChartViewBounds (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ClientsInformation_ClientInfo (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ClientsInformation (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 ChatMessage (::PROTOBUF_NAMESPACE_ID::Arena *arena)
 QtEvent (::PROTOBUF_NAMESPACE_ID::Arena *arena)
Friends
class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
struct ::TableStruct_vtkPVMessage_2eproto
void swap (Variant &a, Variant &b)
void swap (VariantList &a, VariantList &b)
void swap (MessageCollection &a, MessageCollection &b)
void swap (Message &a, Message &b)
void swap (DefinitionHeader &a, DefinitionHeader &b)
void swap (ProxyState_SubProxy &a, ProxyState_SubProxy &b)
void swap (ProxyState_Annotation &a, ProxyState_Annotation &b)
void swap (ProxyState_UserData &a, ProxyState_UserData &b)
void swap (ProxyState_Property &a, ProxyState_Property &b)
void swap (ProxyState &a, ProxyState &b)
void swap (PXMRegistrationState_Entry &a, PXMRegistrationState_Entry &b)
void swap (PXMRegistrationState &a, PXMRegistrationState &b)
void swap (ProxyDefinitionState_ProxyXMLDefinition &a, ProxyDefinitionState_ProxyXMLDefinition &b)
void swap (ProxyDefinitionState &a, ProxyDefinitionState &b)
void swap (PullRequest &a, PullRequest &b)
void swap (ProxySelectionModelState &a, ProxySelectionModelState &b)
void swap (LinkState_LinkDescription &a, LinkState_LinkDescription &b)
void swap (LinkState &a, LinkState &b)
void swap (MousePointer &a, MousePointer &b)
void swap (ChartViewBounds &a, ChartViewBounds &b)
void swap (ClientsInformation_ClientInfo &a, ClientsInformation_ClientInfo &b)
void swap (ClientsInformation &a, ClientsInformation &b)
void swap (ChatMessage &a, ChatMessage &b)
void swap (QtEvent &a, QtEvent &b)
Definition at line 262 of file vtkPVMessage.pb.h.
◆ Type
Definition at line 379 of file vtkPVMessage.pb.h.
◆ SubProxy
Definition at line 2129 of file vtkPVMessage.pb.h.
◆ Annotation
Definition at line 2130 of file vtkPVMessage.pb.h.
◆ UserData
Definition at line 2131 of file vtkPVMessage.pb.h.
◆ Property
Definition at line 2132 of file vtkPVMessage.pb.h.
◆ Entry
Definition at line 2501 of file vtkPVMessage.pb.h.
◆ ProxyXMLDefinition
Definition at line 2849 of file vtkPVMessage.pb.h.
◆ Direction
Definition at line 3272 of file vtkPVMessage.pb.h.
◆ LinkDescription
Definition at line 3493 of file vtkPVMessage.pb.h.
◆ Ratio
Definition at line 3646 of file vtkPVMessage.pb.h.
◆ ClientInfo
Definition at line 4199 of file vtkPVMessage.pb.h.
◆ QtEventType
Definition at line 4475 of file vtkPVMessage.pb.h.
◆ anonymous enum
anonymous enum : int
Enumerator
kIdtypeFieldNumber
kIntegerFieldNumber
kFloat64FieldNumber
kTxtFieldNumber
kBinaryFieldNumber
kTypeFieldNumber
Definition at line 423 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kVariantFieldNumber
Definition at line 744 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kItemFieldNumber
Definition at line 897 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kReqDefFieldNumber
Definition at line 1050 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kNameFieldNumber
Definition at line 1404 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kKeyFieldNumber
kValueFieldNumber
Definition at line 1578 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kVariantFieldNumber
kKeyFieldNumber
Definition at line 1759 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kNameFieldNumber
kValueFieldNumber
Definition at line 1935 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kGroupFieldNumber
kNameFieldNumber
Definition at line 2307 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kGroupFieldNumber
kNameFieldNumber
kXmlFieldNumber
Definition at line 2648 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kProxyFieldNumber
Definition at line 3306 of file vtkPVMessage.pb.h.
◆ anonymous enum
Enumerator
kNameFieldNumber
kUserFieldNumber
Definition at line 3970 of file vtkPVMessage.pb.h.
◆ ~Variant()
virtual paraview_protobuf::PROTOBUF_FINAL::~Variant ( )
◆ ~VariantList()
virtual paraview_protobuf::PROTOBUF_FINAL::~VariantList ( )
◆ ~MessageCollection()
virtual paraview_protobuf::PROTOBUF_FINAL::~MessageCollection ( )
◆ ~Message()
virtual paraview_protobuf::PROTOBUF_FINAL::~Message ( )
◆ ~DefinitionHeader()
virtual paraview_protobuf::PROTOBUF_FINAL::~DefinitionHeader ( )
◆ ~ProxyState_SubProxy()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxyState_SubProxy ( )
◆ ~ProxyState_Annotation()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxyState_Annotation ( )
◆ ~ProxyState_UserData()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxyState_UserData ( )
◆ ~ProxyState_Property()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxyState_Property ( )
◆ ~ProxyState()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxyState ( )
◆ ~PXMRegistrationState_Entry()
virtual paraview_protobuf::PROTOBUF_FINAL::~PXMRegistrationState_Entry ( )
◆ ~PXMRegistrationState()
virtual paraview_protobuf::PROTOBUF_FINAL::~PXMRegistrationState ( )
◆ ~ProxyDefinitionState_ProxyXMLDefinition()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxyDefinitionState_ProxyXMLDefinition ( )
◆ ~ProxyDefinitionState()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxyDefinitionState ( )
◆ ~PullRequest()
virtual paraview_protobuf::PROTOBUF_FINAL::~PullRequest ( )
◆ ~ProxySelectionModelState()
virtual paraview_protobuf::PROTOBUF_FINAL::~ProxySelectionModelState ( )
◆ ~LinkState_LinkDescription()
virtual paraview_protobuf::PROTOBUF_FINAL::~LinkState_LinkDescription ( )
◆ ~LinkState()
virtual paraview_protobuf::PROTOBUF_FINAL::~LinkState ( )
◆ ~MousePointer()
virtual paraview_protobuf::PROTOBUF_FINAL::~MousePointer ( )
◆ ~ChartViewBounds()
virtual paraview_protobuf::PROTOBUF_FINAL::~ChartViewBounds ( )
◆ ~ClientsInformation_ClientInfo()
virtual paraview_protobuf::PROTOBUF_FINAL::~ClientsInformation_ClientInfo ( )
◆ ~ClientsInformation()
virtual paraview_protobuf::PROTOBUF_FINAL::~ClientsInformation ( )
◆ ~ChatMessage()
virtual paraview_protobuf::PROTOBUF_FINAL::~ChatMessage ( )
◆ ~QtEvent()
virtual paraview_protobuf::PROTOBUF_FINAL::~QtEvent ( )
◆ Variant() [1/4]
paraview_protobuf::PROTOBUF_FINAL::Variant ( )
inline
Definition at line 265 of file vtkPVMessage.pb.h.
◆ Variant() [2/4]
paraview_protobuf::PROTOBUF_FINAL::Variant ( const Variant &  from)
◆ Variant() [3/4]
paraview_protobuf::PROTOBUF_FINAL::Variant ( Variant &&  from)
inlinenoexcept
Definition at line 269 of file vtkPVMessage.pb.h.
◆ operator=() [1/48]
Variant& paraview_protobuf::PROTOBUF_FINAL::operator= ( const Variant from)
inline
Definition at line 274 of file vtkPVMessage.pb.h.
◆ operator=() [2/48]
Variant& paraview_protobuf::PROTOBUF_FINAL::operator= ( Variant &&  from)
inlinenoexcept
Definition at line 278 of file vtkPVMessage.pb.h.
◆ unknown_fields() [1/24]
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet& paraview_protobuf::PROTOBUF_FINAL::unknown_fields ( ) const
inline
Definition at line 287 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [1/24]
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet* paraview_protobuf::PROTOBUF_FINAL::mutable_unknown_fields ( )
inline
Definition at line 290 of file vtkPVMessage.pb.h.
◆ descriptor() [1/24]
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::PROTOBUF_FINAL::descriptor ( )
inlinestatic
Definition at line 294 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [1/24]
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::PROTOBUF_FINAL::GetDescriptor ( )
inlinestatic
Definition at line 297 of file vtkPVMessage.pb.h.
◆ GetReflection() [1/24]
static const ::PROTOBUF_NAMESPACE_ID::Reflection* paraview_protobuf::PROTOBUF_FINAL::GetReflection ( )
inlinestatic
Definition at line 300 of file vtkPVMessage.pb.h.
◆ default_instance() [1/24]
static const Variant& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [1/24]
static void paraview_protobuf::PROTOBUF_FINAL::InitAsDefaultInstance ( )
◆ internal_default_instance() [1/24]
static const Variant* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 306 of file vtkPVMessage.pb.h.
◆ Swap() [1/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( Variant other)
inline
Definition at line 316 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [1/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( Variant other)
inline
Definition at line 324 of file vtkPVMessage.pb.h.
◆ New() [1/48]
Variant* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 332 of file vtkPVMessage.pb.h.
◆ New() [2/48]
Variant* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 336 of file vtkPVMessage.pb.h.
◆ CopyFrom() [1/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ::PROTOBUF_NAMESPACE_ID::Message &  from)
final
◆ MergeFrom() [1/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ::PROTOBUF_NAMESPACE_ID::Message &  from)
final
◆ CopyFrom() [2/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const Variant from)
◆ MergeFrom() [2/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const Variant from)
◆ Clear() [1/24]
PROTOBUF_ATTRIBUTE_REINITIALIZES void paraview_protobuf::PROTOBUF_FINAL::Clear ( )
final
◆ IsInitialized() [1/24]
bool paraview_protobuf::PROTOBUF_FINAL::IsInitialized ( ) const
final
◆ ByteSizeLong() [1/24]
size_t paraview_protobuf::PROTOBUF_FINAL::ByteSizeLong ( ) const
final
◆ _InternalParse() [1/24]
const char* paraview_protobuf::PROTOBUF_FINAL::_InternalParse ( const char *  ptr,
::PROTOBUF_NAMESPACE_ID::internal::ParseContext *  ctx
final
◆ _InternalSerialize() [1/24]
::PROTOBUF_NAMESPACE_ID::uint8* paraview_protobuf::PROTOBUF_FINAL::_InternalSerialize ( ::PROTOBUF_NAMESPACE_ID::uint8 *  target,
::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *  stream
) const
final
◆ GetCachedSize() [1/24]
int paraview_protobuf::PROTOBUF_FINAL::GetCachedSize ( ) const
inlinefinal
Definition at line 350 of file vtkPVMessage.pb.h.
◆ Variant() [4/4]
paraview_protobuf::PROTOBUF_FINAL::Variant ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [1/24]
::PROTOBUF_NAMESPACE_ID::Metadata paraview_protobuf::PROTOBUF_FINAL::GetMetadata ( ) const
final
◆ Type_IsValid()
static bool paraview_protobuf::PROTOBUF_FINAL::Type_IsValid ( int  value)
inlinestatic
Definition at line 396 of file vtkPVMessage.pb.h.
◆ Type_descriptor()
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::PROTOBUF_FINAL::Type_descriptor ( )
inlinestatic
Definition at line 406 of file vtkPVMessage.pb.h.
◆ Type_Name()
static const std::string& paraview_protobuf::PROTOBUF_FINAL::Type_Name ( enum_t_value)
inlinestatic
Definition at line 410 of file vtkPVMessage.pb.h.
◆ Type_Parse()
static bool paraview_protobuf::PROTOBUF_FINAL::Type_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
Type value
inlinestatic
Definition at line 416 of file vtkPVMessage.pb.h.
◆ idtype_size()
int paraview_protobuf::PROTOBUF_FINAL::idtype_size ( ) const
◆ clear_idtype()
void paraview_protobuf::PROTOBUF_FINAL::clear_idtype ( )
◆ idtype() [1/2]
::PROTOBUF_NAMESPACE_ID::int64 paraview_protobuf::PROTOBUF_FINAL::idtype ( int  index) const
◆ set_idtype()
void paraview_protobuf::PROTOBUF_FINAL::set_idtype ( int  index,
◆ add_idtype()
void paraview_protobuf::PROTOBUF_FINAL::add_idtype ( ::PROTOBUF_NAMESPACE_ID::int64  value)
◆ idtype() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int64 >& paraview_protobuf::PROTOBUF_FINAL::idtype ( ) const
◆ mutable_idtype()
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int64 >* paraview_protobuf::PROTOBUF_FINAL::mutable_idtype ( )
◆ integer_size()
int paraview_protobuf::PROTOBUF_FINAL::integer_size ( ) const
◆ clear_integer()
void paraview_protobuf::PROTOBUF_FINAL::clear_integer ( )
◆ integer() [1/2]
::PROTOBUF_NAMESPACE_ID::int32 paraview_protobuf::PROTOBUF_FINAL::integer ( int  index) const
◆ set_integer()
void paraview_protobuf::PROTOBUF_FINAL::set_integer ( int  index,
◆ add_integer()
void paraview_protobuf::PROTOBUF_FINAL::add_integer ( ::PROTOBUF_NAMESPACE_ID::int32  value)
◆ integer() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 >& paraview_protobuf::PROTOBUF_FINAL::integer ( ) const
◆ mutable_integer()
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 >* paraview_protobuf::PROTOBUF_FINAL::mutable_integer ( )
◆ float64_size()
int paraview_protobuf::PROTOBUF_FINAL::float64_size ( ) const
◆ clear_float64()
void paraview_protobuf::PROTOBUF_FINAL::clear_float64 ( )
◆ float64() [1/2]
double paraview_protobuf::PROTOBUF_FINAL::float64 ( int  index) const
◆ set_float64()
void paraview_protobuf::PROTOBUF_FINAL::set_float64 ( int  index,
double  value
◆ add_float64()
void paraview_protobuf::PROTOBUF_FINAL::add_float64 ( double  value)
◆ float64() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< double >& paraview_protobuf::PROTOBUF_FINAL::float64 ( ) const
◆ mutable_float64()
::PROTOBUF_NAMESPACE_ID::RepeatedField< double >* paraview_protobuf::PROTOBUF_FINAL::mutable_float64 ( )
◆ proxy_global_id_size()
int paraview_protobuf::PROTOBUF_FINAL::proxy_global_id_size ( ) const
◆ clear_proxy_global_id()
void paraview_protobuf::PROTOBUF_FINAL::clear_proxy_global_id ( )
◆ proxy_global_id() [1/2]
::PROTOBUF_NAMESPACE_ID::uint64 paraview_protobuf::PROTOBUF_FINAL::proxy_global_id ( int  index) const
◆ set_proxy_global_id()
void paraview_protobuf::PROTOBUF_FINAL::set_proxy_global_id ( int  index,
◆ add_proxy_global_id()
void paraview_protobuf::PROTOBUF_FINAL::add_proxy_global_id ( ::PROTOBUF_NAMESPACE_ID::uint64  value)
◆ proxy_global_id() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::uint64 >& paraview_protobuf::PROTOBUF_FINAL::proxy_global_id ( ) const
◆ mutable_proxy_global_id()
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::uint64 >* paraview_protobuf::PROTOBUF_FINAL::mutable_proxy_global_id ( )
◆ port_number_size()
int paraview_protobuf::PROTOBUF_FINAL::port_number_size ( ) const
◆ clear_port_number()
void paraview_protobuf::PROTOBUF_FINAL::clear_port_number ( )
◆ port_number() [1/2]
::PROTOBUF_NAMESPACE_ID::int32 paraview_protobuf::PROTOBUF_FINAL::port_number ( int  index) const
◆ set_port_number()
void paraview_protobuf::PROTOBUF_FINAL::set_port_number ( int  index,
◆ add_port_number()
void paraview_protobuf::PROTOBUF_FINAL::add_port_number ( ::PROTOBUF_NAMESPACE_ID::int32  value)
◆ port_number() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 >& paraview_protobuf::PROTOBUF_FINAL::port_number ( ) const
◆ mutable_port_number()
::PROTOBUF_NAMESPACE_ID::RepeatedField< ::PROTOBUF_NAMESPACE_ID::int32 >* paraview_protobuf::PROTOBUF_FINAL::mutable_port_number ( )
◆ txt_size()
int paraview_protobuf::PROTOBUF_FINAL::txt_size ( ) const
◆ clear_txt()
void paraview_protobuf::PROTOBUF_FINAL::clear_txt ( )
◆ txt() [1/2]
const std::string& paraview_protobuf::PROTOBUF_FINAL::txt ( int  index) const
◆ mutable_txt() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_txt ( int  index)
◆ set_txt() [1/4]
void paraview_protobuf::PROTOBUF_FINAL::set_txt ( int  index,
const std::string value
◆ set_txt() [2/4]
std::string &&  value
◆ set_txt() [3/4]
const char *  value
◆ set_txt() [4/4]
const char *  value,
size_t  size
◆ add_txt() [1/5]
std::string* paraview_protobuf::PROTOBUF_FINAL::add_txt ( )
◆ add_txt() [2/5]
void paraview_protobuf::PROTOBUF_FINAL::add_txt ( const std::string value)
◆ add_txt() [3/5]
void paraview_protobuf::PROTOBUF_FINAL::add_txt ( std::string &&  value)
◆ add_txt() [4/5]
void paraview_protobuf::PROTOBUF_FINAL::add_txt ( const char *  value)
◆ add_txt() [5/5]
void paraview_protobuf::PROTOBUF_FINAL::add_txt ( const char *  value,
size_t  size
◆ txt() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField<std::string>& paraview_protobuf::PROTOBUF_FINAL::txt ( ) const
◆ mutable_txt() [2/2]
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField<std::string>* paraview_protobuf::PROTOBUF_FINAL::mutable_txt ( )
◆ binary_size()
int paraview_protobuf::PROTOBUF_FINAL::binary_size ( ) const
◆ clear_binary()
void paraview_protobuf::PROTOBUF_FINAL::clear_binary ( )
◆ binary() [1/2]
const std::string& paraview_protobuf::PROTOBUF_FINAL::binary ( int  index) const
◆ mutable_binary() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_binary ( int  index)
◆ set_binary() [1/4]
void paraview_protobuf::PROTOBUF_FINAL::set_binary ( int  index,
◆ set_binary() [2/4]
◆ set_binary() [3/4]
const char *  value
◆ set_binary() [4/4]
const void *  value,
size_t  size
◆ add_binary() [1/5]
std::string* paraview_protobuf::PROTOBUF_FINAL::add_binary ( )
◆ add_binary() [2/5]
void paraview_protobuf::PROTOBUF_FINAL::add_binary ( const std::string value)
◆ add_binary() [3/5]
void paraview_protobuf::PROTOBUF_FINAL::add_binary ( std::string &&  value)
◆ add_binary() [4/5]
void paraview_protobuf::PROTOBUF_FINAL::add_binary ( const char *  value)
◆ add_binary() [5/5]
void paraview_protobuf::PROTOBUF_FINAL::add_binary ( const void *  value,
size_t  size
◆ binary() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField<std::string>& paraview_protobuf::PROTOBUF_FINAL::binary ( ) const
◆ mutable_binary() [2/2]
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField<std::string>* paraview_protobuf::PROTOBUF_FINAL::mutable_binary ( )
◆ has_type()
bool paraview_protobuf::PROTOBUF_FINAL::has_type ( ) const
◆ clear_type()
void paraview_protobuf::PROTOBUF_FINAL::clear_type ( )
◆ type()
::paraview_protobuf::Variant_Type paraview_protobuf::PROTOBUF_FINAL::type ( ) const
◆ set_type()
void paraview_protobuf::PROTOBUF_FINAL::set_type ( ::paraview_protobuf::Variant_Type  value)
◆ VariantList() [1/4]
paraview_protobuf::PROTOBUF_FINAL::VariantList ( )
inline
Definition at line 628 of file vtkPVMessage.pb.h.
◆ VariantList() [2/4]
paraview_protobuf::PROTOBUF_FINAL::VariantList ( const VariantList &  from)
◆ VariantList() [3/4]
paraview_protobuf::PROTOBUF_FINAL::VariantList ( VariantList &&  from)
inlinenoexcept
Definition at line 632 of file vtkPVMessage.pb.h.
◆ operator=() [3/48]
VariantList& paraview_protobuf::PROTOBUF_FINAL::operator= ( const VariantList from)
inline
Definition at line 637 of file vtkPVMessage.pb.h.
◆ operator=() [4/48]
VariantList& paraview_protobuf::PROTOBUF_FINAL::operator= ( VariantList &&  from)
inlinenoexcept
Definition at line 641 of file vtkPVMessage.pb.h.
◆ unknown_fields() [2/24]
inline
Definition at line 650 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [2/24]
inline
Definition at line 653 of file vtkPVMessage.pb.h.
◆ descriptor() [2/24]
inlinestatic
Definition at line 657 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [2/24]
inlinestatic
Definition at line 660 of file vtkPVMessage.pb.h.
◆ GetReflection() [2/24]
inlinestatic
Definition at line 663 of file vtkPVMessage.pb.h.
◆ default_instance() [2/24]
static const VariantList& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [2/24]
◆ internal_default_instance() [2/24]
static const VariantList* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 669 of file vtkPVMessage.pb.h.
◆ Swap() [2/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( VariantList other)
inline
Definition at line 679 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [2/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( VariantList other)
inline
Definition at line 687 of file vtkPVMessage.pb.h.
◆ New() [3/48]
VariantList* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 695 of file vtkPVMessage.pb.h.
◆ New() [4/48]
VariantList* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 699 of file vtkPVMessage.pb.h.
◆ CopyFrom() [3/48]
final
◆ MergeFrom() [3/48]
final
◆ CopyFrom() [4/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const VariantList from)
◆ MergeFrom() [4/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const VariantList from)
◆ Clear() [2/24]
final
◆ IsInitialized() [2/24]
final
◆ ByteSizeLong() [2/24]
final
◆ _InternalParse() [2/24]
final
◆ _InternalSerialize() [2/24]
) const
final
◆ GetCachedSize() [2/24]
inlinefinal
Definition at line 713 of file vtkPVMessage.pb.h.
◆ VariantList() [4/4]
paraview_protobuf::PROTOBUF_FINAL::VariantList ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [2/24]
final
◆ variant_size() [1/2]
int paraview_protobuf::PROTOBUF_FINAL::variant_size ( ) const
◆ clear_variant() [1/2]
void paraview_protobuf::PROTOBUF_FINAL::clear_variant ( )
◆ mutable_variant() [1/4]
::paraview_protobuf::Variant* paraview_protobuf::PROTOBUF_FINAL::mutable_variant ( int  index)
◆ mutable_variant() [2/4]
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Variant >* paraview_protobuf::PROTOBUF_FINAL::mutable_variant ( )
◆ variant() [1/4]
const ::paraview_protobuf::Variant& paraview_protobuf::PROTOBUF_FINAL::variant ( int  index) const
◆ add_variant() [1/2]
::paraview_protobuf::Variant* paraview_protobuf::PROTOBUF_FINAL::add_variant ( )
◆ variant() [2/4]
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Variant >& paraview_protobuf::PROTOBUF_FINAL::variant ( ) const
◆ MessageCollection() [1/4]
paraview_protobuf::PROTOBUF_FINAL::MessageCollection ( )
inline
Definition at line 781 of file vtkPVMessage.pb.h.
◆ MessageCollection() [2/4]
paraview_protobuf::PROTOBUF_FINAL::MessageCollection ( const MessageCollection &  from)
◆ MessageCollection() [3/4]
paraview_protobuf::PROTOBUF_FINAL::MessageCollection ( MessageCollection &&  from)
inlinenoexcept
Definition at line 785 of file vtkPVMessage.pb.h.
◆ operator=() [5/48]
MessageCollection& paraview_protobuf::PROTOBUF_FINAL::operator= ( const MessageCollection from)
inline
Definition at line 790 of file vtkPVMessage.pb.h.
◆ operator=() [6/48]
MessageCollection& paraview_protobuf::PROTOBUF_FINAL::operator= ( MessageCollection &&  from)
inlinenoexcept
Definition at line 794 of file vtkPVMessage.pb.h.
◆ unknown_fields() [3/24]
inline
Definition at line 803 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [3/24]
inline
Definition at line 806 of file vtkPVMessage.pb.h.
◆ descriptor() [3/24]
inlinestatic
Definition at line 810 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [3/24]
inlinestatic
Definition at line 813 of file vtkPVMessage.pb.h.
◆ GetReflection() [3/24]
inlinestatic
Definition at line 816 of file vtkPVMessage.pb.h.
◆ default_instance() [3/24]
static const MessageCollection& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [3/24]
◆ internal_default_instance() [3/24]
static const MessageCollection* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 822 of file vtkPVMessage.pb.h.
◆ Swap() [3/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( MessageCollection other)
inline
Definition at line 832 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [3/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( MessageCollection other)
inline
Definition at line 840 of file vtkPVMessage.pb.h.
◆ New() [5/48]
MessageCollection* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 848 of file vtkPVMessage.pb.h.
◆ New() [6/48]
MessageCollection* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 852 of file vtkPVMessage.pb.h.
◆ CopyFrom() [5/48]
final
◆ MergeFrom() [5/48]
final
◆ CopyFrom() [6/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const MessageCollection from)
◆ MergeFrom() [6/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const MessageCollection from)
◆ Clear() [3/24]
final
◆ IsInitialized() [3/24]
final
◆ ByteSizeLong() [3/24]
final
◆ _InternalParse() [3/24]
final
◆ _InternalSerialize() [3/24]
) const
final
◆ GetCachedSize() [3/24]
inlinefinal
Definition at line 866 of file vtkPVMessage.pb.h.
◆ MessageCollection() [4/4]
paraview_protobuf::PROTOBUF_FINAL::MessageCollection ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [3/24]
final
◆ item_size()
int paraview_protobuf::PROTOBUF_FINAL::item_size ( ) const
◆ clear_item()
void paraview_protobuf::PROTOBUF_FINAL::clear_item ( )
◆ mutable_item() [1/2]
::paraview_protobuf::Message* paraview_protobuf::PROTOBUF_FINAL::mutable_item ( int  index)
◆ mutable_item() [2/2]
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Message >* paraview_protobuf::PROTOBUF_FINAL::mutable_item ( )
◆ item() [1/2]
const ::paraview_protobuf::Message& paraview_protobuf::PROTOBUF_FINAL::item ( int  index) const
◆ add_item()
::paraview_protobuf::Message* paraview_protobuf::PROTOBUF_FINAL::add_item ( )
◆ item() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Message >& paraview_protobuf::PROTOBUF_FINAL::item ( ) const
◆ Message() [1/4]
paraview_protobuf::PROTOBUF_FINAL::Message ( )
inline
Definition at line 934 of file vtkPVMessage.pb.h.
◆ Message() [2/4]
paraview_protobuf::PROTOBUF_FINAL::Message ( const Message &  from)
◆ Message() [3/4]
paraview_protobuf::PROTOBUF_FINAL::Message ( Message &&  from)
inlinenoexcept
Definition at line 938 of file vtkPVMessage.pb.h.
◆ operator=() [7/48]
Message& paraview_protobuf::PROTOBUF_FINAL::operator= ( const Message from)
inline
Definition at line 943 of file vtkPVMessage.pb.h.
◆ operator=() [8/48]
Message& paraview_protobuf::PROTOBUF_FINAL::operator= ( Message &&  from)
inlinenoexcept
Definition at line 947 of file vtkPVMessage.pb.h.
◆ unknown_fields() [4/24]
inline
Definition at line 956 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [4/24]
inline
Definition at line 959 of file vtkPVMessage.pb.h.
◆ descriptor() [4/24]
inlinestatic
Definition at line 963 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [4/24]
inlinestatic
Definition at line 966 of file vtkPVMessage.pb.h.
◆ GetReflection() [4/24]
inlinestatic
Definition at line 969 of file vtkPVMessage.pb.h.
◆ default_instance() [4/24]
static const Message& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [4/24]
◆ internal_default_instance() [4/24]
static const Message* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 975 of file vtkPVMessage.pb.h.
◆ Swap() [4/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( Message other)
inline
Definition at line 985 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [4/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( Message other)
inline
Definition at line 993 of file vtkPVMessage.pb.h.
◆ New() [7/48]
Message* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 1001 of file vtkPVMessage.pb.h.
◆ New() [8/48]
Message* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 1005 of file vtkPVMessage.pb.h.
◆ CopyFrom() [7/48]
final
◆ MergeFrom() [7/48]
final
◆ CopyFrom() [8/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const Message from)
◆ MergeFrom() [8/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const Message from)
◆ Clear() [4/24]
final
◆ IsInitialized() [4/24]
final
◆ ByteSizeLong() [4/24]
final
◆ _InternalParse() [4/24]
final
◆ _InternalSerialize() [4/24]
) const
final
◆ GetCachedSize() [4/24]
inlinefinal
Definition at line 1019 of file vtkPVMessage.pb.h.
◆ Message() [4/4]
paraview_protobuf::PROTOBUF_FINAL::Message ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [4/24]
final
◆ has_global_id() [1/3]
bool paraview_protobuf::PROTOBUF_FINAL::has_global_id ( ) const
◆ clear_global_id() [1/3]
void paraview_protobuf::PROTOBUF_FINAL::clear_global_id ( )
◆ global_id() [1/3]
::PROTOBUF_NAMESPACE_ID::uint64 paraview_protobuf::PROTOBUF_FINAL::global_id ( ) const
◆ set_global_id() [1/3]
void paraview_protobuf::PROTOBUF_FINAL::set_global_id ( ::PROTOBUF_NAMESPACE_ID::uint64  value)
◆ has_location()
bool paraview_protobuf::PROTOBUF_FINAL::has_location ( ) const
◆ clear_location()
void paraview_protobuf::PROTOBUF_FINAL::clear_location ( )
◆ location()
::PROTOBUF_NAMESPACE_ID::uint32 paraview_protobuf::PROTOBUF_FINAL::location ( ) const
◆ set_location()
void paraview_protobuf::PROTOBUF_FINAL::set_location ( ::PROTOBUF_NAMESPACE_ID::uint32  value)
◆ has_share_only()
bool paraview_protobuf::PROTOBUF_FINAL::has_share_only ( ) const
◆ clear_share_only()
void paraview_protobuf::PROTOBUF_FINAL::clear_share_only ( )
◆ share_only()
bool paraview_protobuf::PROTOBUF_FINAL::share_only ( ) const
◆ set_share_only()
void paraview_protobuf::PROTOBUF_FINAL::set_share_only ( bool  value)
◆ has_req_def()
bool paraview_protobuf::PROTOBUF_FINAL::has_req_def ( ) const
◆ clear_req_def()
void paraview_protobuf::PROTOBUF_FINAL::clear_req_def ( )
◆ req_def()
bool paraview_protobuf::PROTOBUF_FINAL::req_def ( ) const
◆ set_req_def()
void paraview_protobuf::PROTOBUF_FINAL::set_req_def ( bool  value)
◆ has_client_id()
bool paraview_protobuf::PROTOBUF_FINAL::has_client_id ( ) const
◆ clear_client_id()
void paraview_protobuf::PROTOBUF_FINAL::clear_client_id ( )
◆ client_id()
::PROTOBUF_NAMESPACE_ID::uint32 paraview_protobuf::PROTOBUF_FINAL::client_id ( ) const
◆ set_client_id()
void paraview_protobuf::PROTOBUF_FINAL::set_client_id ( ::PROTOBUF_NAMESPACE_ID::uint32  value)
◆ DefinitionHeader() [1/4]
paraview_protobuf::PROTOBUF_FINAL::DefinitionHeader ( )
inline
Definition at line 1149 of file vtkPVMessage.pb.h.
◆ DefinitionHeader() [2/4]
paraview_protobuf::PROTOBUF_FINAL::DefinitionHeader ( const DefinitionHeader &  from)
◆ DefinitionHeader() [3/4]
paraview_protobuf::PROTOBUF_FINAL::DefinitionHeader ( DefinitionHeader &&  from)
inlinenoexcept
Definition at line 1153 of file vtkPVMessage.pb.h.
◆ operator=() [9/48]
DefinitionHeader& paraview_protobuf::PROTOBUF_FINAL::operator= ( const DefinitionHeader from)
inline
Definition at line 1158 of file vtkPVMessage.pb.h.
◆ operator=() [10/48]
DefinitionHeader& paraview_protobuf::PROTOBUF_FINAL::operator= ( DefinitionHeader &&  from)
inlinenoexcept
Definition at line 1162 of file vtkPVMessage.pb.h.
◆ unknown_fields() [5/24]
inline
Definition at line 1171 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [5/24]
inline
Definition at line 1174 of file vtkPVMessage.pb.h.
◆ descriptor() [5/24]
inlinestatic
Definition at line 1178 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [5/24]
inlinestatic
Definition at line 1181 of file vtkPVMessage.pb.h.
◆ GetReflection() [5/24]
inlinestatic
Definition at line 1184 of file vtkPVMessage.pb.h.
◆ default_instance() [5/24]
static const DefinitionHeader& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [5/24]
◆ internal_default_instance() [5/24]
static const DefinitionHeader* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 1190 of file vtkPVMessage.pb.h.
◆ Swap() [5/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( DefinitionHeader other)
inline
Definition at line 1200 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [5/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( DefinitionHeader other)
inline
Definition at line 1208 of file vtkPVMessage.pb.h.
◆ New() [9/48]
DefinitionHeader* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 1216 of file vtkPVMessage.pb.h.
◆ New() [10/48]
DefinitionHeader* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 1220 of file vtkPVMessage.pb.h.
◆ CopyFrom() [9/48]
final
◆ MergeFrom() [9/48]
final
◆ CopyFrom() [10/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const DefinitionHeader from)
◆ MergeFrom() [10/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const DefinitionHeader from)
◆ Clear() [5/24]
final
◆ IsInitialized() [5/24]
final
◆ ByteSizeLong() [5/24]
final
◆ _InternalParse() [5/24]
final
◆ _InternalSerialize() [5/24]
) const
final
◆ GetCachedSize() [5/24]
inlinefinal
Definition at line 1234 of file vtkPVMessage.pb.h.
◆ DefinitionHeader() [4/4]
paraview_protobuf::PROTOBUF_FINAL::DefinitionHeader ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [5/24]
final
◆ ProxyState_SubProxy() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_SubProxy ( )
inline
Definition at line 1288 of file vtkPVMessage.pb.h.
◆ ProxyState_SubProxy() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_SubProxy ( const ProxyState_SubProxy &  from)
◆ ProxyState_SubProxy() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_SubProxy ( ProxyState_SubProxy &&  from)
inlinenoexcept
Definition at line 1292 of file vtkPVMessage.pb.h.
◆ operator=() [11/48]
ProxyState_SubProxy& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxyState_SubProxy from)
inline
Definition at line 1297 of file vtkPVMessage.pb.h.
◆ operator=() [12/48]
ProxyState_SubProxy& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxyState_SubProxy &&  from)
inlinenoexcept
Definition at line 1301 of file vtkPVMessage.pb.h.
◆ unknown_fields() [6/24]
inline
Definition at line 1310 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [6/24]
inline
Definition at line 1313 of file vtkPVMessage.pb.h.
◆ descriptor() [6/24]
inlinestatic
Definition at line 1317 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [6/24]
inlinestatic
Definition at line 1320 of file vtkPVMessage.pb.h.
◆ GetReflection() [6/24]
inlinestatic
Definition at line 1323 of file vtkPVMessage.pb.h.
◆ default_instance() [6/24]
static const ProxyState_SubProxy& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [6/24]
◆ internal_default_instance() [6/24]
static const ProxyState_SubProxy* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 1329 of file vtkPVMessage.pb.h.
◆ Swap() [6/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxyState_SubProxy other)
inline
Definition at line 1339 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [6/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxyState_SubProxy other)
inline
Definition at line 1347 of file vtkPVMessage.pb.h.
◆ New() [11/48]
ProxyState_SubProxy* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 1355 of file vtkPVMessage.pb.h.
◆ New() [12/48]
ProxyState_SubProxy* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 1359 of file vtkPVMessage.pb.h.
◆ CopyFrom() [11/48]
final
◆ MergeFrom() [11/48]
final
◆ CopyFrom() [12/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxyState_SubProxy from)
◆ MergeFrom() [12/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxyState_SubProxy from)
◆ Clear() [6/24]
final
◆ IsInitialized() [6/24]
final
◆ ByteSizeLong() [6/24]
final
◆ _InternalParse() [6/24]
final
◆ _InternalSerialize() [6/24]
) const
final
◆ GetCachedSize() [6/24]
inlinefinal
Definition at line 1373 of file vtkPVMessage.pb.h.
◆ ProxyState_SubProxy() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_SubProxy ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [6/24]
final
◆ has_name() [1/5]
bool paraview_protobuf::PROTOBUF_FINAL::has_name ( ) const
◆ clear_name() [1/5]
void paraview_protobuf::PROTOBUF_FINAL::clear_name ( )
◆ name() [1/5]
const std::string& paraview_protobuf::PROTOBUF_FINAL::name ( ) const
◆ set_name() [1/20]
void paraview_protobuf::PROTOBUF_FINAL::set_name ( const std::string value)
◆ set_name() [2/20]
void paraview_protobuf::PROTOBUF_FINAL::set_name ( std::string &&  value)
◆ set_name() [3/20]
void paraview_protobuf::PROTOBUF_FINAL::set_name ( const char *  value)
◆ set_name() [4/20]
void paraview_protobuf::PROTOBUF_FINAL::set_name ( const char *  value,
size_t  size
◆ mutable_name() [1/5]
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_name ( )
◆ release_name() [1/5]
std::string* paraview_protobuf::PROTOBUF_FINAL::release_name ( )
◆ set_allocated_name() [1/5]
void paraview_protobuf::PROTOBUF_FINAL::set_allocated_name ( std::string name)
◆ has_global_id() [2/3]
◆ clear_global_id() [2/3]
◆ global_id() [2/3]
::PROTOBUF_NAMESPACE_ID::uint32 paraview_protobuf::PROTOBUF_FINAL::global_id ( ) const
◆ set_global_id() [2/3]
void paraview_protobuf::PROTOBUF_FINAL::set_global_id ( ::PROTOBUF_NAMESPACE_ID::uint32  value)
◆ ProxyState_Annotation() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Annotation ( )
inline
Definition at line 1462 of file vtkPVMessage.pb.h.
◆ ProxyState_Annotation() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Annotation ( const ProxyState_Annotation &  from)
◆ ProxyState_Annotation() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Annotation ( ProxyState_Annotation &&  from)
inlinenoexcept
Definition at line 1466 of file vtkPVMessage.pb.h.
◆ operator=() [13/48]
ProxyState_Annotation& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxyState_Annotation from)
inline
Definition at line 1471 of file vtkPVMessage.pb.h.
◆ operator=() [14/48]
ProxyState_Annotation& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxyState_Annotation &&  from)
inlinenoexcept
Definition at line 1475 of file vtkPVMessage.pb.h.
◆ unknown_fields() [7/24]
inline
Definition at line 1484 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [7/24]
inline
Definition at line 1487 of file vtkPVMessage.pb.h.
◆ descriptor() [7/24]
inlinestatic
Definition at line 1491 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [7/24]
inlinestatic
Definition at line 1494 of file vtkPVMessage.pb.h.
◆ GetReflection() [7/24]
inlinestatic
Definition at line 1497 of file vtkPVMessage.pb.h.
◆ default_instance() [7/24]
static const ProxyState_Annotation& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [7/24]
◆ internal_default_instance() [7/24]
static const ProxyState_Annotation* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 1503 of file vtkPVMessage.pb.h.
◆ Swap() [7/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxyState_Annotation other)
inline
Definition at line 1513 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [7/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxyState_Annotation other)
inline
Definition at line 1521 of file vtkPVMessage.pb.h.
◆ New() [13/48]
ProxyState_Annotation* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 1529 of file vtkPVMessage.pb.h.
◆ New() [14/48]
ProxyState_Annotation* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 1533 of file vtkPVMessage.pb.h.
◆ CopyFrom() [13/48]
final
◆ MergeFrom() [13/48]
final
◆ CopyFrom() [14/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxyState_Annotation from)
◆ MergeFrom() [14/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxyState_Annotation from)
◆ Clear() [7/24]
final
◆ IsInitialized() [7/24]
final
◆ ByteSizeLong() [7/24]
final
◆ _InternalParse() [7/24]
final
◆ _InternalSerialize() [7/24]
) const
final
◆ GetCachedSize() [7/24]
inlinefinal
Definition at line 1547 of file vtkPVMessage.pb.h.
◆ ProxyState_Annotation() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Annotation ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [7/24]
final
◆ has_key() [1/2]
bool paraview_protobuf::PROTOBUF_FINAL::has_key ( ) const
◆ clear_key() [1/2]
void paraview_protobuf::PROTOBUF_FINAL::clear_key ( )
◆ key() [1/2]
const std::string& paraview_protobuf::PROTOBUF_FINAL::key ( ) const
◆ set_key() [1/8]
void paraview_protobuf::PROTOBUF_FINAL::set_key ( const std::string value)
◆ set_key() [2/8]
void paraview_protobuf::PROTOBUF_FINAL::set_key ( std::string &&  value)
◆ set_key() [3/8]
void paraview_protobuf::PROTOBUF_FINAL::set_key ( const char *  value)
◆ set_key() [4/8]
void paraview_protobuf::PROTOBUF_FINAL::set_key ( const char *  value,
size_t  size
◆ mutable_key() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_key ( )
◆ release_key() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::release_key ( )
◆ set_allocated_key() [1/2]
void paraview_protobuf::PROTOBUF_FINAL::set_allocated_key ( std::string key)
◆ has_value() [1/2]
bool paraview_protobuf::PROTOBUF_FINAL::has_value ( ) const
◆ clear_value() [1/2]
void paraview_protobuf::PROTOBUF_FINAL::clear_value ( )
◆ value() [1/2]
const std::string& paraview_protobuf::PROTOBUF_FINAL::value ( ) const
◆ set_value() [1/4]
void paraview_protobuf::PROTOBUF_FINAL::set_value ( const std::string value)
◆ set_value() [2/4]
void paraview_protobuf::PROTOBUF_FINAL::set_value ( std::string &&  value)
◆ set_value() [3/4]
void paraview_protobuf::PROTOBUF_FINAL::set_value ( const char *  value)
◆ set_value() [4/4]
void paraview_protobuf::PROTOBUF_FINAL::set_value ( const char *  value,
size_t  size
◆ mutable_value() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_value ( )
◆ release_value() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::release_value ( )
◆ set_allocated_value() [1/2]
void paraview_protobuf::PROTOBUF_FINAL::set_allocated_value ( std::string value)
◆ ProxyState_UserData() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_UserData ( )
inline
Definition at line 1643 of file vtkPVMessage.pb.h.
◆ ProxyState_UserData() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_UserData ( const ProxyState_UserData &  from)
◆ ProxyState_UserData() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_UserData ( ProxyState_UserData &&  from)
inlinenoexcept
Definition at line 1647 of file vtkPVMessage.pb.h.
◆ operator=() [15/48]
ProxyState_UserData& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxyState_UserData from)
inline
Definition at line 1652 of file vtkPVMessage.pb.h.
◆ operator=() [16/48]
ProxyState_UserData& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxyState_UserData &&  from)
inlinenoexcept
Definition at line 1656 of file vtkPVMessage.pb.h.
◆ unknown_fields() [8/24]
inline
Definition at line 1665 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [8/24]
inline
Definition at line 1668 of file vtkPVMessage.pb.h.
◆ descriptor() [8/24]
inlinestatic
Definition at line 1672 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [8/24]
inlinestatic
Definition at line 1675 of file vtkPVMessage.pb.h.
◆ GetReflection() [8/24]
inlinestatic
Definition at line 1678 of file vtkPVMessage.pb.h.
◆ default_instance() [8/24]
static const ProxyState_UserData& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [8/24]
◆ internal_default_instance() [8/24]
static const ProxyState_UserData* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 1684 of file vtkPVMessage.pb.h.
◆ Swap() [8/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxyState_UserData other)
inline
Definition at line 1694 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [8/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxyState_UserData other)
inline
Definition at line 1702 of file vtkPVMessage.pb.h.
◆ New() [15/48]
ProxyState_UserData* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 1710 of file vtkPVMessage.pb.h.
◆ New() [16/48]
ProxyState_UserData* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 1714 of file vtkPVMessage.pb.h.
◆ CopyFrom() [15/48]
final
◆ MergeFrom() [15/48]
final
◆ CopyFrom() [16/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxyState_UserData from)
◆ MergeFrom() [16/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxyState_UserData from)
◆ Clear() [8/24]
final
◆ IsInitialized() [8/24]
final
◆ ByteSizeLong() [8/24]
final
◆ _InternalParse() [8/24]
final
◆ _InternalSerialize() [8/24]
) const
final
◆ GetCachedSize() [8/24]
inlinefinal
Definition at line 1728 of file vtkPVMessage.pb.h.
◆ ProxyState_UserData() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_UserData ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [8/24]
final
◆ variant_size() [2/2]
◆ clear_variant() [2/2]
◆ mutable_variant() [3/4]
◆ mutable_variant() [4/4]
◆ variant() [3/4]
◆ add_variant() [2/2]
◆ variant() [4/4]
◆ has_key() [2/2]
◆ clear_key() [2/2]
◆ key() [2/2]
◆ set_key() [5/8]
◆ set_key() [6/8]
◆ set_key() [7/8]
◆ set_key() [8/8]
size_t  size
◆ mutable_key() [2/2]
◆ release_key() [2/2]
◆ set_allocated_key() [2/2]
◆ ProxyState_Property() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Property ( )
inline
Definition at line 1819 of file vtkPVMessage.pb.h.
◆ ProxyState_Property() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Property ( const ProxyState_Property &  from)
◆ ProxyState_Property() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Property ( ProxyState_Property &&  from)
inlinenoexcept
Definition at line 1823 of file vtkPVMessage.pb.h.
◆ operator=() [17/48]
ProxyState_Property& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxyState_Property from)
inline
Definition at line 1828 of file vtkPVMessage.pb.h.
◆ operator=() [18/48]
ProxyState_Property& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxyState_Property &&  from)
inlinenoexcept
Definition at line 1832 of file vtkPVMessage.pb.h.
◆ unknown_fields() [9/24]
inline
Definition at line 1841 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [9/24]
inline
Definition at line 1844 of file vtkPVMessage.pb.h.
◆ descriptor() [9/24]
inlinestatic
Definition at line 1848 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [9/24]
inlinestatic
Definition at line 1851 of file vtkPVMessage.pb.h.
◆ GetReflection() [9/24]
inlinestatic
Definition at line 1854 of file vtkPVMessage.pb.h.
◆ default_instance() [9/24]
static const ProxyState_Property& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [9/24]
◆ internal_default_instance() [9/24]
static const ProxyState_Property* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 1860 of file vtkPVMessage.pb.h.
◆ Swap() [9/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxyState_Property other)
inline
Definition at line 1870 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [9/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxyState_Property other)
inline
Definition at line 1878 of file vtkPVMessage.pb.h.
◆ New() [17/48]
ProxyState_Property* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 1886 of file vtkPVMessage.pb.h.
◆ New() [18/48]
ProxyState_Property* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 1890 of file vtkPVMessage.pb.h.
◆ CopyFrom() [17/48]
final
◆ MergeFrom() [17/48]
final
◆ CopyFrom() [18/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxyState_Property from)
◆ MergeFrom() [18/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxyState_Property from)
◆ Clear() [9/24]
final
◆ IsInitialized() [9/24]
final
◆ ByteSizeLong() [9/24]
final
◆ _InternalParse() [9/24]
final
◆ _InternalSerialize() [9/24]
) const
final
◆ GetCachedSize() [9/24]
inlinefinal
Definition at line 1904 of file vtkPVMessage.pb.h.
◆ ProxyState_Property() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState_Property ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [9/24]
final
◆ user_data_size()
int paraview_protobuf::PROTOBUF_FINAL::user_data_size ( ) const
◆ clear_user_data()
void paraview_protobuf::PROTOBUF_FINAL::clear_user_data ( )
◆ mutable_user_data() [1/2]
::paraview_protobuf::ProxyState_UserData* paraview_protobuf::PROTOBUF_FINAL::mutable_user_data ( int  index)
◆ mutable_user_data() [2/2]
::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::ProxyState_UserData >* paraview_protobuf::PROTOBUF_FINAL::mutable_user_data ( )
◆ user_data() [1/2]
const ::paraview_protobuf::ProxyState_UserData& paraview_protobuf::PROTOBUF_FINAL::user_data ( int  index) const
◆ add_user_data()
::paraview_protobuf::ProxyState_UserData* paraview_protobuf::PROTOBUF_FINAL::add_user_data ( )
◆ user_data() [2/2]
const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::ProxyState_UserData >& paraview_protobuf::PROTOBUF_FINAL::user_data ( ) const
◆ has_name() [2/5]
◆ clear_name() [2/5]
◆ name() [2/5]
◆ set_name() [5/20]
◆ set_name() [6/20]
◆ set_name() [7/20]
◆ set_name() [8/20]
size_t  size
◆ mutable_name() [2/5]
◆ release_name() [2/5]
◆ set_allocated_name() [2/5]
◆ has_value() [2/2]
◆ clear_value() [2/2]
◆ value() [2/2]
const ::paraview_protobuf::Variant& paraview_protobuf::PROTOBUF_FINAL::value ( ) const
◆ release_value() [2/2]
::paraview_protobuf::Variant* paraview_protobuf::PROTOBUF_FINAL::release_value ( )
◆ mutable_value() [2/2]
::paraview_protobuf::Variant* paraview_protobuf::PROTOBUF_FINAL::mutable_value ( )
◆ set_allocated_value() [2/2]
void paraview_protobuf::PROTOBUF_FINAL::set_allocated_value ( ::paraview_protobuf::Variant *  value)
◆ unsafe_arena_set_allocated_value()
void paraview_protobuf::PROTOBUF_FINAL::unsafe_arena_set_allocated_value ( ::paraview_protobuf::Variant *  value)
◆ unsafe_arena_release_value()
::paraview_protobuf::Variant* paraview_protobuf::PROTOBUF_FINAL::unsafe_arena_release_value ( )
◆ ProxyState() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState ( )
inline
Definition at line 2015 of file vtkPVMessage.pb.h.
◆ ProxyState() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState ( const ProxyState &  from)
◆ ProxyState() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState ( ProxyState &&  from)
inlinenoexcept
Definition at line 2019 of file vtkPVMessage.pb.h.
◆ operator=() [19/48]
ProxyState& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxyState from)
inline
Definition at line 2024 of file vtkPVMessage.pb.h.
◆ operator=() [20/48]
ProxyState& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxyState &&  from)
inlinenoexcept
Definition at line 2028 of file vtkPVMessage.pb.h.
◆ unknown_fields() [10/24]
inline
Definition at line 2037 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [10/24]
inline
Definition at line 2040 of file vtkPVMessage.pb.h.
◆ descriptor() [10/24]
inlinestatic
Definition at line 2044 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [10/24]
inlinestatic
Definition at line 2047 of file vtkPVMessage.pb.h.
◆ GetReflection() [10/24]
inlinestatic
Definition at line 2050 of file vtkPVMessage.pb.h.
◆ default_instance() [10/24]
static const ProxyState& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [10/24]
◆ internal_default_instance() [10/24]
static const ProxyState* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 2056 of file vtkPVMessage.pb.h.
◆ Swap() [10/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxyState other)
inline
Definition at line 2066 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [10/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxyState other)
inline
Definition at line 2074 of file vtkPVMessage.pb.h.
◆ New() [19/48]
ProxyState* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 2082 of file vtkPVMessage.pb.h.
◆ New() [20/48]
ProxyState* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 2086 of file vtkPVMessage.pb.h.
◆ CopyFrom() [19/48]
final
◆ MergeFrom() [19/48]
final
◆ CopyFrom() [20/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxyState from)
◆ MergeFrom() [20/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxyState from)
◆ Clear() [10/24]
final
◆ IsInitialized() [10/24]
final
◆ ByteSizeLong() [10/24]
final
◆ _InternalParse() [10/24]
final
◆ _InternalSerialize() [10/24]
) const
final
◆ GetCachedSize() [10/24]
inlinefinal
Definition at line 2100 of file vtkPVMessage.pb.h.
◆ ProxyState() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyState ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [10/24]
final
◆ PXMRegistrationState_Entry() [1/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState_Entry ( )
inline
Definition at line 2191 of file vtkPVMessage.pb.h.
◆ PXMRegistrationState_Entry() [2/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState_Entry ( const PXMRegistrationState_Entry &  from)
◆ PXMRegistrationState_Entry() [3/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState_Entry ( PXMRegistrationState_Entry &&  from)
inlinenoexcept
Definition at line 2195 of file vtkPVMessage.pb.h.
◆ operator=() [21/48]
PXMRegistrationState_Entry& paraview_protobuf::PROTOBUF_FINAL::operator= ( const PXMRegistrationState_Entry from)
inline
Definition at line 2200 of file vtkPVMessage.pb.h.
◆ operator=() [22/48]
PXMRegistrationState_Entry& paraview_protobuf::PROTOBUF_FINAL::operator= ( PXMRegistrationState_Entry &&  from)
inlinenoexcept
Definition at line 2204 of file vtkPVMessage.pb.h.
◆ unknown_fields() [11/24]
inline
Definition at line 2213 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [11/24]
inline
Definition at line 2216 of file vtkPVMessage.pb.h.
◆ descriptor() [11/24]
inlinestatic
Definition at line 2220 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [11/24]
inlinestatic
Definition at line 2223 of file vtkPVMessage.pb.h.
◆ GetReflection() [11/24]
inlinestatic
Definition at line 2226 of file vtkPVMessage.pb.h.
◆ default_instance() [11/24]
static const PXMRegistrationState_Entry& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [11/24]
◆ internal_default_instance() [11/24]
static const PXMRegistrationState_Entry* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 2232 of file vtkPVMessage.pb.h.
◆ Swap() [11/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( PXMRegistrationState_Entry other)
inline
Definition at line 2242 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [11/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( PXMRegistrationState_Entry other)
inline
Definition at line 2250 of file vtkPVMessage.pb.h.
◆ New() [21/48]
PXMRegistrationState_Entry* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 2258 of file vtkPVMessage.pb.h.
◆ New() [22/48]
PXMRegistrationState_Entry* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 2262 of file vtkPVMessage.pb.h.
◆ CopyFrom() [21/48]
final
◆ MergeFrom() [21/48]
final
◆ CopyFrom() [22/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const PXMRegistrationState_Entry from)
◆ MergeFrom() [22/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const PXMRegistrationState_Entry from)
◆ Clear() [11/24]
final
◆ IsInitialized() [11/24]
final
◆ ByteSizeLong() [11/24]
final
◆ _InternalParse() [11/24]
final
◆ _InternalSerialize() [11/24]
) const
final
◆ GetCachedSize() [11/24]
inlinefinal
Definition at line 2276 of file vtkPVMessage.pb.h.
◆ PXMRegistrationState_Entry() [4/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState_Entry ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [11/24]
final
◆ has_group() [1/2]
bool paraview_protobuf::PROTOBUF_FINAL::has_group ( ) const
◆ clear_group() [1/2]
void paraview_protobuf::PROTOBUF_FINAL::clear_group ( )
◆ group() [1/2]
const std::string& paraview_protobuf::PROTOBUF_FINAL::group ( ) const
◆ set_group() [1/8]
void paraview_protobuf::PROTOBUF_FINAL::set_group ( const std::string value)
◆ set_group() [2/8]
void paraview_protobuf::PROTOBUF_FINAL::set_group ( std::string &&  value)
◆ set_group() [3/8]
void paraview_protobuf::PROTOBUF_FINAL::set_group ( const char *  value)
◆ set_group() [4/8]
void paraview_protobuf::PROTOBUF_FINAL::set_group ( const char *  value,
size_t  size
◆ mutable_group() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_group ( )
◆ release_group() [1/2]
std::string* paraview_protobuf::PROTOBUF_FINAL::release_group ( )
◆ set_allocated_group() [1/2]
void paraview_protobuf::PROTOBUF_FINAL::set_allocated_group ( std::string group)
◆ has_name() [3/5]
◆ clear_name() [3/5]
◆ name() [3/5]
◆ set_name() [9/20]
◆ set_name() [10/20]
◆ set_name() [11/20]
◆ set_name() [12/20]
size_t  size
◆ mutable_name() [3/5]
◆ release_name() [3/5]
◆ set_allocated_name() [3/5]
◆ has_global_id() [3/3]
◆ clear_global_id() [3/3]
◆ global_id() [3/3]
◆ set_global_id() [3/3]
◆ PXMRegistrationState() [1/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState ( )
inline
Definition at line 2387 of file vtkPVMessage.pb.h.
◆ PXMRegistrationState() [2/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState ( const PXMRegistrationState &  from)
◆ PXMRegistrationState() [3/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState ( PXMRegistrationState &&  from)
inlinenoexcept
Definition at line 2391 of file vtkPVMessage.pb.h.
◆ operator=() [23/48]
PXMRegistrationState& paraview_protobuf::PROTOBUF_FINAL::operator= ( const PXMRegistrationState from)
inline
Definition at line 2396 of file vtkPVMessage.pb.h.
◆ operator=() [24/48]
PXMRegistrationState& paraview_protobuf::PROTOBUF_FINAL::operator= ( PXMRegistrationState &&  from)
inlinenoexcept
Definition at line 2400 of file vtkPVMessage.pb.h.
◆ unknown_fields() [12/24]
inline
Definition at line 2409 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [12/24]
inline
Definition at line 2412 of file vtkPVMessage.pb.h.
◆ descriptor() [12/24]
inlinestatic
Definition at line 2416 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [12/24]
inlinestatic
Definition at line 2419 of file vtkPVMessage.pb.h.
◆ GetReflection() [12/24]
inlinestatic
Definition at line 2422 of file vtkPVMessage.pb.h.
◆ default_instance() [12/24]
static const PXMRegistrationState& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [12/24]
◆ internal_default_instance() [12/24]
static const PXMRegistrationState* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 2428 of file vtkPVMessage.pb.h.
◆ Swap() [12/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( PXMRegistrationState other)
inline
Definition at line 2438 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [12/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( PXMRegistrationState other)
inline
Definition at line 2446 of file vtkPVMessage.pb.h.
◆ New() [23/48]
PXMRegistrationState* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 2454 of file vtkPVMessage.pb.h.
◆ New() [24/48]
PXMRegistrationState* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 2458 of file vtkPVMessage.pb.h.
◆ CopyFrom() [23/48]
final
◆ MergeFrom() [23/48]
final
◆ CopyFrom() [24/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const PXMRegistrationState from)
◆ MergeFrom() [24/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const PXMRegistrationState from)
◆ Clear() [12/24]
final
◆ IsInitialized() [12/24]
final
◆ ByteSizeLong() [12/24]
final
◆ _InternalParse() [12/24]
final
◆ _InternalSerialize() [12/24]
) const
final
◆ GetCachedSize() [12/24]
inlinefinal
Definition at line 2472 of file vtkPVMessage.pb.h.
◆ PXMRegistrationState() [4/4]
paraview_protobuf::PROTOBUF_FINAL::PXMRegistrationState ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [12/24]
final
◆ ProxyDefinitionState_ProxyXMLDefinition() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState_ProxyXMLDefinition ( )
inline
Definition at line 2532 of file vtkPVMessage.pb.h.
◆ ProxyDefinitionState_ProxyXMLDefinition() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState_ProxyXMLDefinition ( const ProxyDefinitionState_ProxyXMLDefinition &  from)
◆ ProxyDefinitionState_ProxyXMLDefinition() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState_ProxyXMLDefinition ( ProxyDefinitionState_ProxyXMLDefinition &&  from)
inlinenoexcept
Definition at line 2536 of file vtkPVMessage.pb.h.
◆ operator=() [25/48]
ProxyDefinitionState_ProxyXMLDefinition& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxyDefinitionState_ProxyXMLDefinition from)
inline
Definition at line 2541 of file vtkPVMessage.pb.h.
◆ operator=() [26/48]
ProxyDefinitionState_ProxyXMLDefinition& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxyDefinitionState_ProxyXMLDefinition &&  from)
inlinenoexcept
Definition at line 2545 of file vtkPVMessage.pb.h.
◆ unknown_fields() [13/24]
inline
Definition at line 2554 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [13/24]
inline
Definition at line 2557 of file vtkPVMessage.pb.h.
◆ descriptor() [13/24]
inlinestatic
Definition at line 2561 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [13/24]
inlinestatic
Definition at line 2564 of file vtkPVMessage.pb.h.
◆ GetReflection() [13/24]
inlinestatic
Definition at line 2567 of file vtkPVMessage.pb.h.
◆ default_instance() [13/24]
static const ProxyDefinitionState_ProxyXMLDefinition& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [13/24]
◆ internal_default_instance() [13/24]
static const ProxyDefinitionState_ProxyXMLDefinition* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 2573 of file vtkPVMessage.pb.h.
◆ Swap() [13/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxyDefinitionState_ProxyXMLDefinition other)
inline
Definition at line 2583 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [13/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxyDefinitionState_ProxyXMLDefinition other)
inline
Definition at line 2591 of file vtkPVMessage.pb.h.
◆ New() [25/48]
ProxyDefinitionState_ProxyXMLDefinition* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 2599 of file vtkPVMessage.pb.h.
◆ New() [26/48]
ProxyDefinitionState_ProxyXMLDefinition* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 2603 of file vtkPVMessage.pb.h.
◆ CopyFrom() [25/48]
final
◆ MergeFrom() [25/48]
final
◆ CopyFrom() [26/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxyDefinitionState_ProxyXMLDefinition from)
◆ MergeFrom() [26/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxyDefinitionState_ProxyXMLDefinition from)
◆ Clear() [13/24]
final
◆ IsInitialized() [13/24]
final
◆ ByteSizeLong() [13/24]
final
◆ _InternalParse() [13/24]
final
◆ _InternalSerialize() [13/24]
) const
final
◆ GetCachedSize() [13/24]
inlinefinal
Definition at line 2617 of file vtkPVMessage.pb.h.
◆ ProxyDefinitionState_ProxyXMLDefinition() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState_ProxyXMLDefinition ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [13/24]
final
◆ has_group() [2/2]
◆ clear_group() [2/2]
◆ group() [2/2]
◆ set_group() [5/8]
◆ set_group() [6/8]
◆ set_group() [7/8]
◆ set_group() [8/8]
size_t  size
◆ mutable_group() [2/2]
◆ release_group() [2/2]
◆ set_allocated_group() [2/2]
◆ has_name() [4/5]
◆ clear_name() [4/5]
◆ name() [4/5]
◆ set_name() [13/20]
◆ set_name() [14/20]
◆ set_name() [15/20]
◆ set_name() [16/20]
size_t  size
◆ mutable_name() [4/5]
◆ release_name() [4/5]
◆ set_allocated_name() [4/5]
◆ has_xml()
bool paraview_protobuf::PROTOBUF_FINAL::has_xml ( ) const
◆ clear_xml()
void paraview_protobuf::PROTOBUF_FINAL::clear_xml ( )
◆ xml()
const std::string& paraview_protobuf::PROTOBUF_FINAL::xml ( ) const
◆ set_xml() [1/4]
void paraview_protobuf::PROTOBUF_FINAL::set_xml ( const std::string value)
◆ set_xml() [2/4]
void paraview_protobuf::PROTOBUF_FINAL::set_xml ( std::string &&  value)
◆ set_xml() [3/4]
void paraview_protobuf::PROTOBUF_FINAL::set_xml ( const char *  value)
◆ set_xml() [4/4]
void paraview_protobuf::PROTOBUF_FINAL::set_xml ( const char *  value,
size_t  size
◆ mutable_xml()
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_xml ( )
◆ release_xml()
std::string* paraview_protobuf::PROTOBUF_FINAL::release_xml ( )
◆ set_allocated_xml()
void paraview_protobuf::PROTOBUF_FINAL::set_allocated_xml ( std::string xml)
◆ ProxyDefinitionState() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState ( )
inline
Definition at line 2735 of file vtkPVMessage.pb.h.
◆ ProxyDefinitionState() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState ( const ProxyDefinitionState &  from)
◆ ProxyDefinitionState() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState ( ProxyDefinitionState &&  from)
inlinenoexcept
Definition at line 2739 of file vtkPVMessage.pb.h.
◆ operator=() [27/48]
ProxyDefinitionState& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxyDefinitionState from)
inline
Definition at line 2744 of file vtkPVMessage.pb.h.
◆ operator=() [28/48]
ProxyDefinitionState& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxyDefinitionState &&  from)
inlinenoexcept
Definition at line 2748 of file vtkPVMessage.pb.h.
◆ unknown_fields() [14/24]
inline
Definition at line 2757 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [14/24]
inline
Definition at line 2760 of file vtkPVMessage.pb.h.
◆ descriptor() [14/24]
inlinestatic
Definition at line 2764 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [14/24]
inlinestatic
Definition at line 2767 of file vtkPVMessage.pb.h.
◆ GetReflection() [14/24]
inlinestatic
Definition at line 2770 of file vtkPVMessage.pb.h.
◆ default_instance() [14/24]
static const ProxyDefinitionState& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [14/24]
◆ internal_default_instance() [14/24]
static const ProxyDefinitionState* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 2776 of file vtkPVMessage.pb.h.
◆ Swap() [14/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxyDefinitionState other)
inline
Definition at line 2786 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [14/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxyDefinitionState other)
inline
Definition at line 2794 of file vtkPVMessage.pb.h.
◆ New() [27/48]
ProxyDefinitionState* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 2802 of file vtkPVMessage.pb.h.
◆ New() [28/48]
ProxyDefinitionState* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 2806 of file vtkPVMessage.pb.h.
◆ CopyFrom() [27/48]
final
◆ MergeFrom() [27/48]
final
◆ CopyFrom() [28/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxyDefinitionState from)
◆ MergeFrom() [28/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxyDefinitionState from)
◆ Clear() [14/24]
final
◆ IsInitialized() [14/24]
final
◆ ByteSizeLong() [14/24]
final
◆ _InternalParse() [14/24]
final
◆ _InternalSerialize() [14/24]
) const
final
◆ GetCachedSize() [14/24]
inlinefinal
Definition at line 2820 of file vtkPVMessage.pb.h.
◆ ProxyDefinitionState() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxyDefinitionState ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [14/24]
final
◆ PullRequest() [1/4]
paraview_protobuf::PROTOBUF_FINAL::PullRequest ( )
inline
Definition at line 2876 of file vtkPVMessage.pb.h.
◆ PullRequest() [2/4]
paraview_protobuf::PROTOBUF_FINAL::PullRequest ( const PullRequest &  from)
◆ PullRequest() [3/4]
paraview_protobuf::PROTOBUF_FINAL::PullRequest ( PullRequest &&  from)
inlinenoexcept
Definition at line 2880 of file vtkPVMessage.pb.h.
◆ operator=() [29/48]
PullRequest& paraview_protobuf::PROTOBUF_FINAL::operator= ( const PullRequest from)
inline
Definition at line 2885 of file vtkPVMessage.pb.h.
◆ operator=() [30/48]
PullRequest& paraview_protobuf::PROTOBUF_FINAL::operator= ( PullRequest &&  from)
inlinenoexcept
Definition at line 2889 of file vtkPVMessage.pb.h.
◆ unknown_fields() [15/24]
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet& paraview_protobuf::PROTOBUF_FINAL::unknown_fields ( ) const
inline
Definition at line 2898 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [15/24]
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet* paraview_protobuf::PROTOBUF_FINAL::mutable_unknown_fields ( )
inline
Definition at line 2901 of file vtkPVMessage.pb.h.
◆ descriptor() [15/24]
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::PROTOBUF_FINAL::descriptor ( )
inlinestatic
Definition at line 2905 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [15/24]
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::PROTOBUF_FINAL::GetDescriptor ( )
inlinestatic
Definition at line 2908 of file vtkPVMessage.pb.h.
◆ GetReflection() [15/24]
static const ::PROTOBUF_NAMESPACE_ID::Reflection* paraview_protobuf::PROTOBUF_FINAL::GetReflection ( )
inlinestatic
Definition at line 2911 of file vtkPVMessage.pb.h.
◆ default_instance() [15/24]
static const PullRequest& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [15/24]
static void paraview_protobuf::PROTOBUF_FINAL::InitAsDefaultInstance ( )
◆ internal_default_instance() [15/24]
static const PullRequest* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 2917 of file vtkPVMessage.pb.h.
◆ Swap() [15/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( PullRequest other)
inline
Definition at line 2927 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [15/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( PullRequest other)
inline
Definition at line 2935 of file vtkPVMessage.pb.h.
◆ New() [29/48]
PullRequest* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 2943 of file vtkPVMessage.pb.h.
◆ New() [30/48]
PullRequest* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 2947 of file vtkPVMessage.pb.h.
◆ CopyFrom() [29/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ::PROTOBUF_NAMESPACE_ID::Message &  from)
final
◆ MergeFrom() [29/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ::PROTOBUF_NAMESPACE_ID::Message &  from)
final
◆ CopyFrom() [30/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const PullRequest from)
◆ MergeFrom() [30/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const PullRequest from)
◆ Clear() [15/24]
PROTOBUF_ATTRIBUTE_REINITIALIZES void paraview_protobuf::PROTOBUF_FINAL::Clear ( )
final
◆ IsInitialized() [15/24]
bool paraview_protobuf::PROTOBUF_FINAL::IsInitialized ( ) const
final
◆ ByteSizeLong() [15/24]
size_t paraview_protobuf::PROTOBUF_FINAL::ByteSizeLong ( ) const
final
◆ _InternalParse() [15/24]
const char* paraview_protobuf::PROTOBUF_FINAL::_InternalParse ( const char *  ptr,
::PROTOBUF_NAMESPACE_ID::internal::ParseContext *  ctx
final
◆ _InternalSerialize() [15/24]
::PROTOBUF_NAMESPACE_ID::uint8* paraview_protobuf::PROTOBUF_FINAL::_InternalSerialize ( ::PROTOBUF_NAMESPACE_ID::uint8 *  target,
::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *  stream
) const
final
◆ GetCachedSize() [15/24]
int paraview_protobuf::PROTOBUF_FINAL::GetCachedSize ( ) const
inlinefinal
Definition at line 2961 of file vtkPVMessage.pb.h.
◆ PullRequest() [4/4]
paraview_protobuf::PROTOBUF_FINAL::PullRequest ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [15/24]
::PROTOBUF_NAMESPACE_ID::Metadata paraview_protobuf::PROTOBUF_FINAL::GetMetadata ( ) const
final
◆ ProxySelectionModelState() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ProxySelectionModelState ( )
inline
Definition at line 3011 of file vtkPVMessage.pb.h.
◆ ProxySelectionModelState() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ProxySelectionModelState ( const ProxySelectionModelState &  from)
◆ ProxySelectionModelState() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ProxySelectionModelState ( ProxySelectionModelState &&  from)
inlinenoexcept
Definition at line 3015 of file vtkPVMessage.pb.h.
◆ operator=() [31/48]
ProxySelectionModelState& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ProxySelectionModelState from)
inline
Definition at line 3020 of file vtkPVMessage.pb.h.
◆ operator=() [32/48]
ProxySelectionModelState& paraview_protobuf::PROTOBUF_FINAL::operator= ( ProxySelectionModelState &&  from)
inlinenoexcept
Definition at line 3024 of file vtkPVMessage.pb.h.
◆ unknown_fields() [16/24]
inline
Definition at line 3033 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [16/24]
inline
Definition at line 3036 of file vtkPVMessage.pb.h.
◆ descriptor() [16/24]
inlinestatic
Definition at line 3040 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [16/24]
inlinestatic
Definition at line 3043 of file vtkPVMessage.pb.h.
◆ GetReflection() [16/24]
inlinestatic
Definition at line 3046 of file vtkPVMessage.pb.h.
◆ default_instance() [16/24]
static const ProxySelectionModelState& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [16/24]
◆ internal_default_instance() [16/24]
static const ProxySelectionModelState* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 3052 of file vtkPVMessage.pb.h.
◆ Swap() [16/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ProxySelectionModelState other)
inline
Definition at line 3062 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [16/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ProxySelectionModelState other)
inline
Definition at line 3070 of file vtkPVMessage.pb.h.
◆ New() [31/48]
ProxySelectionModelState* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 3078 of file vtkPVMessage.pb.h.
◆ New() [32/48]
ProxySelectionModelState* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 3082 of file vtkPVMessage.pb.h.
◆ CopyFrom() [31/48]
final
◆ MergeFrom() [31/48]
final
◆ CopyFrom() [32/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ProxySelectionModelState from)
◆ MergeFrom() [32/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ProxySelectionModelState from)
◆ Clear() [16/24]
final
◆ IsInitialized() [16/24]
final
◆ ByteSizeLong() [16/24]
final
◆ _InternalParse() [16/24]
final
◆ _InternalSerialize() [16/24]
) const
final
◆ GetCachedSize() [16/24]
inlinefinal
Definition at line 3096 of file vtkPVMessage.pb.h.
◆ ProxySelectionModelState() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ProxySelectionModelState ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [16/24]
final
◆ LinkState_LinkDescription() [1/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState_LinkDescription ( )
inline
Definition at line 3158 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription() [2/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState_LinkDescription ( const LinkState_LinkDescription &  from)
◆ LinkState_LinkDescription() [3/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState_LinkDescription ( LinkState_LinkDescription &&  from)
inlinenoexcept
Definition at line 3162 of file vtkPVMessage.pb.h.
◆ operator=() [33/48]
LinkState_LinkDescription& paraview_protobuf::PROTOBUF_FINAL::operator= ( const LinkState_LinkDescription from)
inline
Definition at line 3167 of file vtkPVMessage.pb.h.
◆ operator=() [34/48]
LinkState_LinkDescription& paraview_protobuf::PROTOBUF_FINAL::operator= ( LinkState_LinkDescription &&  from)
inlinenoexcept
Definition at line 3171 of file vtkPVMessage.pb.h.
◆ unknown_fields() [17/24]
inline
Definition at line 3180 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [17/24]
inline
Definition at line 3183 of file vtkPVMessage.pb.h.
◆ descriptor() [17/24]
inlinestatic
Definition at line 3187 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [17/24]
inlinestatic
Definition at line 3190 of file vtkPVMessage.pb.h.
◆ GetReflection() [17/24]
inlinestatic
Definition at line 3193 of file vtkPVMessage.pb.h.
◆ default_instance() [17/24]
static const LinkState_LinkDescription& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [17/24]
◆ internal_default_instance() [17/24]
static const LinkState_LinkDescription* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 3199 of file vtkPVMessage.pb.h.
◆ Swap() [17/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( LinkState_LinkDescription other)
inline
Definition at line 3209 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [17/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( LinkState_LinkDescription other)
inline
Definition at line 3217 of file vtkPVMessage.pb.h.
◆ New() [33/48]
LinkState_LinkDescription* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 3225 of file vtkPVMessage.pb.h.
◆ New() [34/48]
LinkState_LinkDescription* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 3229 of file vtkPVMessage.pb.h.
◆ CopyFrom() [33/48]
final
◆ MergeFrom() [33/48]
final
◆ CopyFrom() [34/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const LinkState_LinkDescription from)
◆ MergeFrom() [34/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const LinkState_LinkDescription from)
◆ Clear() [17/24]
final
◆ IsInitialized() [17/24]
final
◆ ByteSizeLong() [17/24]
final
◆ _InternalParse() [17/24]
final
◆ _InternalSerialize() [17/24]
) const
final
◆ GetCachedSize() [17/24]
inlinefinal
Definition at line 3243 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription() [4/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState_LinkDescription ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [17/24]
final
◆ Direction_IsValid()
static bool paraview_protobuf::PROTOBUF_FINAL::Direction_IsValid ( int  value)
inlinestatic
Definition at line 3279 of file vtkPVMessage.pb.h.
◆ Direction_descriptor()
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::PROTOBUF_FINAL::Direction_descriptor ( )
inlinestatic
Definition at line 3289 of file vtkPVMessage.pb.h.
◆ Direction_Name()
template<typename T >
static const std::string& paraview_protobuf::PROTOBUF_FINAL::Direction_Name ( enum_t_value)
inlinestatic
Definition at line 3293 of file vtkPVMessage.pb.h.
◆ Direction_Parse()
static bool paraview_protobuf::PROTOBUF_FINAL::Direction_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
Direction value
inlinestatic
Definition at line 3299 of file vtkPVMessage.pb.h.
◆ has_property_name()
bool paraview_protobuf::PROTOBUF_FINAL::has_property_name ( ) const
◆ clear_property_name()
void paraview_protobuf::PROTOBUF_FINAL::clear_property_name ( )
◆ property_name()
const std::string& paraview_protobuf::PROTOBUF_FINAL::property_name ( ) const
◆ set_property_name() [1/4]
void paraview_protobuf::PROTOBUF_FINAL::set_property_name ( const std::string value)
◆ set_property_name() [2/4]
void paraview_protobuf::PROTOBUF_FINAL::set_property_name ( std::string &&  value)
◆ set_property_name() [3/4]
void paraview_protobuf::PROTOBUF_FINAL::set_property_name ( const char *  value)
◆ set_property_name() [4/4]
void paraview_protobuf::PROTOBUF_FINAL::set_property_name ( const char *  value,
size_t  size
◆ mutable_property_name()
std::string* paraview_protobuf::PROTOBUF_FINAL::mutable_property_name ( )
◆ release_property_name()
std::string* paraview_protobuf::PROTOBUF_FINAL::release_property_name ( )
◆ set_allocated_property_name()
void paraview_protobuf::PROTOBUF_FINAL::set_allocated_property_name ( std::string property_name)
◆ has_proxy()
bool paraview_protobuf::PROTOBUF_FINAL::has_proxy ( ) const
◆ clear_proxy()
void paraview_protobuf::PROTOBUF_FINAL::clear_proxy ( )
◆ proxy()
::PROTOBUF_NAMESPACE_ID::uint32 paraview_protobuf::PROTOBUF_FINAL::proxy ( ) const
◆ set_proxy()
void paraview_protobuf::PROTOBUF_FINAL::set_proxy ( ::PROTOBUF_NAMESPACE_ID::uint32  value)
◆ has_direction()
bool paraview_protobuf::PROTOBUF_FINAL::has_direction ( ) const
◆ clear_direction()
void paraview_protobuf::PROTOBUF_FINAL::clear_direction ( )
◆ direction()
::paraview_protobuf::LinkState_LinkDescription_Direction paraview_protobuf::PROTOBUF_FINAL::direction ( ) const
◆ set_direction()
void paraview_protobuf::PROTOBUF_FINAL::set_direction ( ::paraview_protobuf::LinkState_LinkDescription_Direction  value)
◆ LinkState() [1/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState ( )
inline
Definition at line 3379 of file vtkPVMessage.pb.h.
◆ LinkState() [2/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState ( const LinkState &  from)
◆ LinkState() [3/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState ( LinkState &&  from)
inlinenoexcept
Definition at line 3383 of file vtkPVMessage.pb.h.
◆ operator=() [35/48]
LinkState& paraview_protobuf::PROTOBUF_FINAL::operator= ( const LinkState from)
inline
Definition at line 3388 of file vtkPVMessage.pb.h.
◆ operator=() [36/48]
LinkState& paraview_protobuf::PROTOBUF_FINAL::operator= ( LinkState &&  from)
inlinenoexcept
Definition at line 3392 of file vtkPVMessage.pb.h.
◆ unknown_fields() [18/24]
inline
Definition at line 3401 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [18/24]
inline
Definition at line 3404 of file vtkPVMessage.pb.h.
◆ descriptor() [18/24]
inlinestatic
Definition at line 3408 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [18/24]
inlinestatic
Definition at line 3411 of file vtkPVMessage.pb.h.
◆ GetReflection() [18/24]
inlinestatic
Definition at line 3414 of file vtkPVMessage.pb.h.
◆ default_instance() [18/24]
static const LinkState& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [18/24]
◆ internal_default_instance() [18/24]
static const LinkState* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 3420 of file vtkPVMessage.pb.h.
◆ Swap() [18/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( LinkState other)
inline
Definition at line 3430 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [18/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( LinkState other)
inline
Definition at line 3438 of file vtkPVMessage.pb.h.
◆ New() [35/48]
LinkState* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 3446 of file vtkPVMessage.pb.h.
◆ New() [36/48]
LinkState* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 3450 of file vtkPVMessage.pb.h.
◆ CopyFrom() [35/48]
final
◆ MergeFrom() [35/48]
final
◆ CopyFrom() [36/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const LinkState from)
◆ MergeFrom() [36/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const LinkState from)
◆ Clear() [18/24]
final
◆ IsInitialized() [18/24]
final
◆ ByteSizeLong() [18/24]
final
◆ _InternalParse() [18/24]
final
◆ _InternalSerialize() [18/24]
) const
final
◆ GetCachedSize() [18/24]
inlinefinal
Definition at line 3464 of file vtkPVMessage.pb.h.
◆ LinkState() [4/4]
paraview_protobuf::PROTOBUF_FINAL::LinkState ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [18/24]
final
◆ MousePointer() [1/4]
paraview_protobuf::PROTOBUF_FINAL::MousePointer ( )
inline
Definition at line 3532 of file vtkPVMessage.pb.h.
◆ MousePointer() [2/4]
paraview_protobuf::PROTOBUF_FINAL::MousePointer ( const MousePointer &  from)
◆ MousePointer() [3/4]
paraview_protobuf::PROTOBUF_FINAL::MousePointer ( MousePointer &&  from)
inlinenoexcept
Definition at line 3536 of file vtkPVMessage.pb.h.
◆ operator=() [37/48]
MousePointer& paraview_protobuf::PROTOBUF_FINAL::operator= ( const MousePointer from)
inline
Definition at line 3541 of file vtkPVMessage.pb.h.
◆ operator=() [38/48]
MousePointer& paraview_protobuf::PROTOBUF_FINAL::operator= ( MousePointer &&  from)
inlinenoexcept
Definition at line 3545 of file vtkPVMessage.pb.h.
◆ unknown_fields() [19/24]
inline
Definition at line 3554 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [19/24]
inline
Definition at line 3557 of file vtkPVMessage.pb.h.
◆ descriptor() [19/24]
inlinestatic
Definition at line 3561 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [19/24]
inlinestatic
Definition at line 3564 of file vtkPVMessage.pb.h.
◆ GetReflection() [19/24]
inlinestatic
Definition at line 3567 of file vtkPVMessage.pb.h.
◆ default_instance() [19/24]
static const MousePointer& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [19/24]
◆ internal_default_instance() [19/24]
static const MousePointer* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 3573 of file vtkPVMessage.pb.h.
◆ Swap() [19/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( MousePointer other)
inline
Definition at line 3583 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [19/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( MousePointer other)
inline
Definition at line 3591 of file vtkPVMessage.pb.h.
◆ New() [37/48]
MousePointer* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 3599 of file vtkPVMessage.pb.h.
◆ New() [38/48]
MousePointer* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 3603 of file vtkPVMessage.pb.h.
◆ CopyFrom() [37/48]
final
◆ MergeFrom() [37/48]
final
◆ CopyFrom() [38/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const MousePointer from)
◆ MergeFrom() [38/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const MousePointer from)
◆ Clear() [19/24]
final
◆ IsInitialized() [19/24]
final
◆ ByteSizeLong() [19/24]
final
◆ _InternalParse() [19/24]
final
◆ _InternalSerialize() [19/24]
) const
final
◆ GetCachedSize() [19/24]
inlinefinal
Definition at line 3617 of file vtkPVMessage.pb.h.
◆ MousePointer() [4/4]
paraview_protobuf::PROTOBUF_FINAL::MousePointer ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [19/24]
final
◆ Ratio_IsValid()
static bool paraview_protobuf::PROTOBUF_FINAL::Ratio_IsValid ( int  value)
inlinestatic
Definition at line 3653 of file vtkPVMessage.pb.h.
◆ Ratio_descriptor()
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::PROTOBUF_FINAL::Ratio_descriptor ( )
inlinestatic
Definition at line 3663 of file vtkPVMessage.pb.h.
◆ Ratio_Name()
static const std::string& paraview_protobuf::PROTOBUF_FINAL::Ratio_Name ( enum_t_value)
inlinestatic
Definition at line 3667 of file vtkPVMessage.pb.h.
◆ Ratio_Parse()
static bool paraview_protobuf::PROTOBUF_FINAL::Ratio_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
Ratio value
inlinestatic
Definition at line 3673 of file vtkPVMessage.pb.h.
◆ ChartViewBounds() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ChartViewBounds ( )
inline
Definition at line 3715 of file vtkPVMessage.pb.h.
◆ ChartViewBounds() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ChartViewBounds ( const ChartViewBounds &  from)
◆ ChartViewBounds() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ChartViewBounds ( ChartViewBounds &&  from)
inlinenoexcept
Definition at line 3719 of file vtkPVMessage.pb.h.
◆ operator=() [39/48]
ChartViewBounds& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ChartViewBounds from)
inline
Definition at line 3724 of file vtkPVMessage.pb.h.
◆ operator=() [40/48]
ChartViewBounds& paraview_protobuf::PROTOBUF_FINAL::operator= ( ChartViewBounds &&  from)
inlinenoexcept
Definition at line 3728 of file vtkPVMessage.pb.h.
◆ unknown_fields() [20/24]
inline
Definition at line 3737 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [20/24]
inline
Definition at line 3740 of file vtkPVMessage.pb.h.
◆ descriptor() [20/24]
inlinestatic
Definition at line 3744 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [20/24]
inlinestatic
Definition at line 3747 of file vtkPVMessage.pb.h.
◆ GetReflection() [20/24]
inlinestatic
Definition at line 3750 of file vtkPVMessage.pb.h.
◆ default_instance() [20/24]
static const ChartViewBounds& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [20/24]
◆ internal_default_instance() [20/24]
static const ChartViewBounds* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 3756 of file vtkPVMessage.pb.h.
◆ Swap() [20/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ChartViewBounds other)
inline
Definition at line 3766 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [20/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ChartViewBounds other)
inline
Definition at line 3774 of file vtkPVMessage.pb.h.
◆ New() [39/48]
ChartViewBounds* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 3782 of file vtkPVMessage.pb.h.
◆ New() [40/48]
ChartViewBounds* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 3786 of file vtkPVMessage.pb.h.
◆ CopyFrom() [39/48]
final
◆ MergeFrom() [39/48]
final
◆ CopyFrom() [40/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ChartViewBounds from)
◆ MergeFrom() [40/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ChartViewBounds from)
◆ Clear() [20/24]
final
◆ IsInitialized() [20/24]
final
◆ ByteSizeLong() [20/24]
final
◆ _InternalParse() [20/24]
final
◆ _InternalSerialize() [20/24]
) const
final
◆ GetCachedSize() [20/24]
inlinefinal
Definition at line 3800 of file vtkPVMessage.pb.h.
◆ ChartViewBounds() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ChartViewBounds ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [20/24]
final
◆ ClientsInformation_ClientInfo() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation_ClientInfo ( )
inline
Definition at line 3854 of file vtkPVMessage.pb.h.
◆ ClientsInformation_ClientInfo() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation_ClientInfo ( const ClientsInformation_ClientInfo &  from)
◆ ClientsInformation_ClientInfo() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation_ClientInfo ( ClientsInformation_ClientInfo &&  from)
inlinenoexcept
Definition at line 3858 of file vtkPVMessage.pb.h.
◆ operator=() [41/48]
ClientsInformation_ClientInfo& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ClientsInformation_ClientInfo from)
inline
Definition at line 3863 of file vtkPVMessage.pb.h.
◆ operator=() [42/48]
ClientsInformation_ClientInfo& paraview_protobuf::PROTOBUF_FINAL::operator= ( ClientsInformation_ClientInfo &&  from)
inlinenoexcept
Definition at line 3867 of file vtkPVMessage.pb.h.
◆ unknown_fields() [21/24]
inline
Definition at line 3876 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [21/24]
inline
Definition at line 3879 of file vtkPVMessage.pb.h.
◆ descriptor() [21/24]
inlinestatic
Definition at line 3883 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [21/24]
inlinestatic
Definition at line 3886 of file vtkPVMessage.pb.h.
◆ GetReflection() [21/24]
inlinestatic
Definition at line 3889 of file vtkPVMessage.pb.h.
◆ default_instance() [21/24]
static const ClientsInformation_ClientInfo& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [21/24]
◆ internal_default_instance() [21/24]
static const ClientsInformation_ClientInfo* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 3895 of file vtkPVMessage.pb.h.
◆ Swap() [21/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ClientsInformation_ClientInfo other)
inline
Definition at line 3905 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [21/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ClientsInformation_ClientInfo other)
inline
Definition at line 3913 of file vtkPVMessage.pb.h.
◆ New() [41/48]
ClientsInformation_ClientInfo* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 3921 of file vtkPVMessage.pb.h.
◆ New() [42/48]
ClientsInformation_ClientInfo* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 3925 of file vtkPVMessage.pb.h.
◆ CopyFrom() [41/48]
final
◆ MergeFrom() [41/48]
final
◆ CopyFrom() [42/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ClientsInformation_ClientInfo from)
◆ MergeFrom() [42/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ClientsInformation_ClientInfo from)
◆ Clear() [21/24]
final
◆ IsInitialized() [21/24]
final
◆ ByteSizeLong() [21/24]
final
◆ _InternalParse() [21/24]
final
◆ _InternalSerialize() [21/24]
) const
final
◆ GetCachedSize() [21/24]
inlinefinal
Definition at line 3939 of file vtkPVMessage.pb.h.
◆ ClientsInformation_ClientInfo() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation_ClientInfo ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [21/24]
final
◆ has_name() [5/5]
◆ clear_name() [5/5]
◆ name() [5/5]
◆ set_name() [17/20]
◆ set_name() [18/20]
◆ set_name() [19/20]
◆ set_name() [20/20]
size_t  size
◆ mutable_name() [5/5]
◆ release_name() [5/5]
◆ set_allocated_name() [5/5]
◆ has_user()
bool paraview_protobuf::PROTOBUF_FINAL::has_user ( ) const
◆ clear_user()
void paraview_protobuf::PROTOBUF_FINAL::clear_user ( )
◆ user()
::PROTOBUF_NAMESPACE_ID::uint32 paraview_protobuf::PROTOBUF_FINAL::user ( ) const
◆ set_user()
void paraview_protobuf::PROTOBUF_FINAL::set_user ( ::PROTOBUF_NAMESPACE_ID::uint32  value)
◆ has_is_master()
bool paraview_protobuf::PROTOBUF_FINAL::has_is_master ( ) const
◆ clear_is_master()
void paraview_protobuf::PROTOBUF_FINAL::clear_is_master ( )
◆ is_master()
bool paraview_protobuf::PROTOBUF_FINAL::is_master ( ) const
◆ set_is_master()
void paraview_protobuf::PROTOBUF_FINAL::set_is_master ( bool  value)
◆ has_follow_cam()
bool paraview_protobuf::PROTOBUF_FINAL::has_follow_cam ( ) const
◆ clear_follow_cam()
void paraview_protobuf::PROTOBUF_FINAL::clear_follow_cam ( )
◆ follow_cam()
bool paraview_protobuf::PROTOBUF_FINAL::follow_cam ( ) const
◆ set_follow_cam()
void paraview_protobuf::PROTOBUF_FINAL::set_follow_cam ( bool  value)
◆ has_disable_further_connections()
bool paraview_protobuf::PROTOBUF_FINAL::has_disable_further_connections ( ) const
◆ clear_disable_further_connections()
void paraview_protobuf::PROTOBUF_FINAL::clear_disable_further_connections ( )
◆ disable_further_connections()
bool paraview_protobuf::PROTOBUF_FINAL::disable_further_connections ( ) const
◆ set_disable_further_connections()
void paraview_protobuf::PROTOBUF_FINAL::set_disable_further_connections ( bool  value)
◆ has_connect_id()
bool paraview_protobuf::PROTOBUF_FINAL::has_connect_id ( ) const
◆ clear_connect_id()
void paraview_protobuf::PROTOBUF_FINAL::clear_connect_id ( )
◆ connect_id()
::PROTOBUF_NAMESPACE_ID::uint32 paraview_protobuf::PROTOBUF_FINAL::connect_id ( ) const
◆ set_connect_id()
void paraview_protobuf::PROTOBUF_FINAL::set_connect_id ( ::PROTOBUF_NAMESPACE_ID::uint32  value)
◆ ClientsInformation() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation ( )
inline
Definition at line 4085 of file vtkPVMessage.pb.h.
◆ ClientsInformation() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation ( const ClientsInformation &  from)
◆ ClientsInformation() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation ( ClientsInformation &&  from)
inlinenoexcept
Definition at line 4089 of file vtkPVMessage.pb.h.
◆ operator=() [43/48]
ClientsInformation& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ClientsInformation from)
inline
Definition at line 4094 of file vtkPVMessage.pb.h.
◆ operator=() [44/48]
ClientsInformation& paraview_protobuf::PROTOBUF_FINAL::operator= ( ClientsInformation &&  from)
inlinenoexcept
Definition at line 4098 of file vtkPVMessage.pb.h.
◆ unknown_fields() [22/24]
inline
Definition at line 4107 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [22/24]
inline
Definition at line 4110 of file vtkPVMessage.pb.h.
◆ descriptor() [22/24]
inlinestatic
Definition at line 4114 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [22/24]
inlinestatic
Definition at line 4117 of file vtkPVMessage.pb.h.
◆ GetReflection() [22/24]
inlinestatic
Definition at line 4120 of file vtkPVMessage.pb.h.
◆ default_instance() [22/24]
static const ClientsInformation& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [22/24]
◆ internal_default_instance() [22/24]
static const ClientsInformation* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 4126 of file vtkPVMessage.pb.h.
◆ Swap() [22/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ClientsInformation other)
inline
Definition at line 4136 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [22/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ClientsInformation other)
inline
Definition at line 4144 of file vtkPVMessage.pb.h.
◆ New() [43/48]
ClientsInformation* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 4152 of file vtkPVMessage.pb.h.
◆ New() [44/48]
ClientsInformation* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 4156 of file vtkPVMessage.pb.h.
◆ CopyFrom() [43/48]
final
◆ MergeFrom() [43/48]
final
◆ CopyFrom() [44/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ClientsInformation from)
◆ MergeFrom() [44/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ClientsInformation from)
◆ Clear() [22/24]
final
◆ IsInitialized() [22/24]
final
◆ ByteSizeLong() [22/24]
final
◆ _InternalParse() [22/24]
final
◆ _InternalSerialize() [22/24]
) const
final
◆ GetCachedSize() [22/24]
inlinefinal
Definition at line 4170 of file vtkPVMessage.pb.h.
◆ ClientsInformation() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ClientsInformation ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [22/24]
final
◆ ChatMessage() [1/4]
paraview_protobuf::PROTOBUF_FINAL::ChatMessage ( )
inline
Definition at line 4222 of file vtkPVMessage.pb.h.
◆ ChatMessage() [2/4]
paraview_protobuf::PROTOBUF_FINAL::ChatMessage ( const ChatMessage &  from)
◆ ChatMessage() [3/4]
paraview_protobuf::PROTOBUF_FINAL::ChatMessage ( ChatMessage &&  from)
inlinenoexcept
Definition at line 4226 of file vtkPVMessage.pb.h.
◆ operator=() [45/48]
ChatMessage& paraview_protobuf::PROTOBUF_FINAL::operator= ( const ChatMessage from)
inline
Definition at line 4231 of file vtkPVMessage.pb.h.
◆ operator=() [46/48]
ChatMessage& paraview_protobuf::PROTOBUF_FINAL::operator= ( ChatMessage &&  from)
inlinenoexcept
Definition at line 4235 of file vtkPVMessage.pb.h.
◆ unknown_fields() [23/24]
inline
Definition at line 4244 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [23/24]
inline
Definition at line 4247 of file vtkPVMessage.pb.h.
◆ descriptor() [23/24]
inlinestatic
Definition at line 4251 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [23/24]
inlinestatic
Definition at line 4254 of file vtkPVMessage.pb.h.
◆ GetReflection() [23/24]
inlinestatic
Definition at line 4257 of file vtkPVMessage.pb.h.
◆ default_instance() [23/24]
static const ChatMessage& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [23/24]
◆ internal_default_instance() [23/24]
static const ChatMessage* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 4263 of file vtkPVMessage.pb.h.
◆ Swap() [23/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( ChatMessage other)
inline
Definition at line 4273 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [23/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( ChatMessage other)
inline
Definition at line 4281 of file vtkPVMessage.pb.h.
◆ New() [45/48]
ChatMessage* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 4289 of file vtkPVMessage.pb.h.
◆ New() [46/48]
ChatMessage* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 4293 of file vtkPVMessage.pb.h.
◆ CopyFrom() [45/48]
final
◆ MergeFrom() [45/48]
final
◆ CopyFrom() [46/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const ChatMessage from)
◆ MergeFrom() [46/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const ChatMessage from)
◆ Clear() [23/24]
final
◆ IsInitialized() [23/24]
final
◆ ByteSizeLong() [23/24]
final
◆ _InternalParse() [23/24]
final
◆ _InternalSerialize() [23/24]
) const
final
◆ GetCachedSize() [23/24]
inlinefinal
Definition at line 4307 of file vtkPVMessage.pb.h.
◆ ChatMessage() [4/4]
paraview_protobuf::PROTOBUF_FINAL::ChatMessage ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [23/24]
final
◆ QtEvent() [1/4]
paraview_protobuf::PROTOBUF_FINAL::QtEvent ( )
inline
Definition at line 4361 of file vtkPVMessage.pb.h.
◆ QtEvent() [2/4]
paraview_protobuf::PROTOBUF_FINAL::QtEvent ( const QtEvent &  from)
◆ QtEvent() [3/4]
paraview_protobuf::PROTOBUF_FINAL::QtEvent ( QtEvent &&  from)
inlinenoexcept
Definition at line 4365 of file vtkPVMessage.pb.h.
◆ operator=() [47/48]
QtEvent& paraview_protobuf::PROTOBUF_FINAL::operator= ( const QtEvent from)
inline
Definition at line 4370 of file vtkPVMessage.pb.h.
◆ operator=() [48/48]
QtEvent& paraview_protobuf::PROTOBUF_FINAL::operator= ( QtEvent &&  from)
inlinenoexcept
Definition at line 4374 of file vtkPVMessage.pb.h.
◆ unknown_fields() [24/24]
inline
Definition at line 4383 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields() [24/24]
inline
Definition at line 4386 of file vtkPVMessage.pb.h.
◆ descriptor() [24/24]
inlinestatic
Definition at line 4390 of file vtkPVMessage.pb.h.
◆ GetDescriptor() [24/24]
inlinestatic
Definition at line 4393 of file vtkPVMessage.pb.h.
◆ GetReflection() [24/24]
inlinestatic
Definition at line 4396 of file vtkPVMessage.pb.h.
◆ default_instance() [24/24]
static const QtEvent& paraview_protobuf::PROTOBUF_FINAL::default_instance ( )
◆ InitAsDefaultInstance() [24/24]
◆ internal_default_instance() [24/24]
static const QtEvent* paraview_protobuf::PROTOBUF_FINAL::internal_default_instance ( )
inlinestatic
Definition at line 4402 of file vtkPVMessage.pb.h.
◆ Swap() [24/24]
void paraview_protobuf::PROTOBUF_FINAL::Swap ( QtEvent other)
inline
Definition at line 4412 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap() [24/24]
void paraview_protobuf::PROTOBUF_FINAL::UnsafeArenaSwap ( QtEvent other)
inline
Definition at line 4420 of file vtkPVMessage.pb.h.
◆ New() [47/48]
QtEvent* paraview_protobuf::PROTOBUF_FINAL::New ( void  ) const
inlinefinal
Definition at line 4428 of file vtkPVMessage.pb.h.
◆ New() [48/48]
QtEvent* paraview_protobuf::PROTOBUF_FINAL::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena) const
inlinefinal
Definition at line 4432 of file vtkPVMessage.pb.h.
◆ CopyFrom() [47/48]
final
◆ MergeFrom() [47/48]
final
◆ CopyFrom() [48/48]
void paraview_protobuf::PROTOBUF_FINAL::CopyFrom ( const QtEvent from)
◆ MergeFrom() [48/48]
void paraview_protobuf::PROTOBUF_FINAL::MergeFrom ( const QtEvent from)
◆ Clear() [24/24]
final
◆ IsInitialized() [24/24]
final
◆ ByteSizeLong() [24/24]
final
◆ _InternalParse() [24/24]
final
◆ _InternalSerialize() [24/24]
) const
final
◆ GetCachedSize() [24/24]
inlinefinal
Definition at line 4446 of file vtkPVMessage.pb.h.
◆ QtEvent() [4/4]
paraview_protobuf::PROTOBUF_FINAL::QtEvent ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena)
explicitprotected
◆ GetMetadata() [24/24]
final
◆ QtEventType_IsValid()
static bool paraview_protobuf::PROTOBUF_FINAL::QtEventType_IsValid ( int  value)
inlinestatic
Definition at line 4480 of file vtkPVMessage.pb.h.
◆ QtEventType_descriptor()
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::PROTOBUF_FINAL::QtEventType_descriptor ( )
inlinestatic
Definition at line 4490 of file vtkPVMessage.pb.h.
◆ QtEventType_Name()
static const std::string& paraview_protobuf::PROTOBUF_FINAL::QtEventType_Name ( enum_t_value)
inlinestatic
Definition at line 4494 of file vtkPVMessage.pb.h.
◆ QtEventType_Parse()
static bool paraview_protobuf::PROTOBUF_FINAL::QtEventType_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
QtEventType value
inlinestatic
Definition at line 4500 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend
Definition at line 357 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend
Definition at line 606 of file vtkPVMessage.pb.h.
◆ ::TableStruct_vtkPVMessage_2eproto
friend struct ::TableStruct_vtkPVMessage_2eproto
friend
Definition at line 621 of file vtkPVMessage.pb.h.
◆ swap [1/24]
void swap ( Variant a,
Variant b
friend
Definition at line 313 of file vtkPVMessage.pb.h.
◆ swap [2/24]
void swap ( VariantList a,
VariantList b
friend
Definition at line 676 of file vtkPVMessage.pb.h.
◆ swap [3/24]
void swap ( MessageCollection a,
MessageCollection b
friend
Definition at line 829 of file vtkPVMessage.pb.h.
◆ swap [4/24]
void swap ( Message a,
Message b
friend
Definition at line 982 of file vtkPVMessage.pb.h.
◆ swap [5/24]
void swap ( DefinitionHeader a,
DefinitionHeader b
friend
Definition at line 1197 of file vtkPVMessage.pb.h.
◆ swap [6/24]
void swap ( ProxyState_SubProxy a,
ProxyState_SubProxy b
friend
Definition at line 1336 of file vtkPVMessage.pb.h.
◆ swap [7/24]
void swap ( ProxyState_Annotation a,
ProxyState_Annotation b
friend
Definition at line 1510 of file vtkPVMessage.pb.h.
◆ swap [8/24]
void swap ( ProxyState_UserData a,
ProxyState_UserData b
friend
Definition at line 1691 of file vtkPVMessage.pb.h.
◆ swap [9/24]
void swap ( ProxyState_Property a,
ProxyState_Property b
friend
Definition at line 1867 of file vtkPVMessage.pb.h.
◆ swap [10/24]
void swap ( ProxyState a,
ProxyState b
friend
Definition at line 2063 of file vtkPVMessage.pb.h.
◆ swap [11/24]
void swap ( PXMRegistrationState_Entry a,
PXMRegistrationState_Entry b
friend
Definition at line 2239 of file vtkPVMessage.pb.h.
◆ swap [12/24]
void swap ( PXMRegistrationState a,
PXMRegistrationState b
friend
Definition at line 2435 of file vtkPVMessage.pb.h.
◆ swap [13/24]
Definition at line 2580 of file vtkPVMessage.pb.h.
◆ swap [14/24]
void swap ( ProxyDefinitionState a,
ProxyDefinitionState b
friend
Definition at line 2783 of file vtkPVMessage.pb.h.
◆ swap [15/24]
void swap ( PullRequest a,
PullRequest b
friend
Definition at line 2924 of file vtkPVMessage.pb.h.
◆ swap [16/24]
void swap ( ProxySelectionModelState a,
ProxySelectionModelState b
friend
Definition at line 3059 of file vtkPVMessage.pb.h.
◆ swap [17/24]
void swap ( LinkState_LinkDescription a,
LinkState_LinkDescription b
friend
Definition at line 3206 of file vtkPVMessage.pb.h.
◆ swap [18/24]
void swap ( LinkState a,
LinkState b
friend
Definition at line 3427 of file vtkPVMessage.pb.h.
◆ swap [19/24]
void swap ( MousePointer a,
MousePointer b
friend
Definition at line 3580 of file vtkPVMessage.pb.h.
◆ swap [20/24]
void swap ( ChartViewBounds a,
ChartViewBounds b
friend
Definition at line 3763 of file vtkPVMessage.pb.h.
◆ swap [21/24]
void swap ( ClientsInformation_ClientInfo a,
ClientsInformation_ClientInfo b
friend
Definition at line 3902 of file vtkPVMessage.pb.h.
◆ swap [22/24]
void swap ( ClientsInformation a,
ClientsInformation b
friend
Definition at line 4133 of file vtkPVMessage.pb.h.
◆ swap [23/24]
void swap ( ChatMessage a,
ChatMessage b
friend
Definition at line 4270 of file vtkPVMessage.pb.h.
◆ swap [24/24]
void swap ( QtEvent a,
QtEvent b
friend
Definition at line 4409 of file vtkPVMessage.pb.h.
◆ kIndexInFileMessages
static constexpr int paraview_protobuf::PROTOBUF_FINAL::kIndexInFileMessages
Initial value:
0
Definition at line 310 of file vtkPVMessage.pb.h.
◆ INT
constexpr Type paraview_protobuf::PROTOBUF_FINAL::INT
Initial value:
Definition at line 380 of file vtkPVMessage.pb.h.
◆ FLOAT64
constexpr Type paraview_protobuf::PROTOBUF_FINAL::FLOAT64
Initial value:
Definition at line 382 of file vtkPVMessage.pb.h.
◆ IDTYPE
constexpr Type paraview_protobuf::PROTOBUF_FINAL::IDTYPE
Initial value:
Definition at line 384 of file vtkPVMessage.pb.h.
◆ STRING
constexpr Type paraview_protobuf::PROTOBUF_FINAL::STRING
Initial value:
Definition at line 386 of file vtkPVMessage.pb.h.
◆ PROXY
constexpr Type paraview_protobuf::PROTOBUF_FINAL::PROXY
Initial value:
Definition at line 388 of file vtkPVMessage.pb.h.
◆ INPUT [1/2]
constexpr Type paraview_protobuf::PROTOBUF_FINAL::INPUT
Initial value:
Definition at line 390 of file vtkPVMessage.pb.h.
◆ BYTES
constexpr Type paraview_protobuf::PROTOBUF_FINAL::BYTES
Initial value:
Definition at line 392 of file vtkPVMessage.pb.h.
◆ MAP
constexpr Type paraview_protobuf::PROTOBUF_FINAL::MAP
Initial value:
Definition at line 394 of file vtkPVMessage.pb.h.
◆ Type_MIN
constexpr Type paraview_protobuf::PROTOBUF_FINAL::Type_MIN
Initial value:
Definition at line 399 of file vtkPVMessage.pb.h.
◆ Type_MAX
constexpr Type paraview_protobuf::PROTOBUF_FINAL::Type_MAX
Initial value:
Definition at line 401 of file vtkPVMessage.pb.h.
◆ Type_ARRAYSIZE
constexpr int paraview_protobuf::PROTOBUF_FINAL::Type_ARRAYSIZE
Initial value:
Definition at line 403 of file vtkPVMessage.pb.h.
◆ kClientClassFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kClientClassFieldNumber = 10
Definition at line 1265 of file vtkPVMessage.pb.h.
◆ client_class
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::client_class
Definition at line 1268 of file vtkPVMessage.pb.h.
◆ kServerClassFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kServerClassFieldNumber = 11
Definition at line 1269 of file vtkPVMessage.pb.h.
◆ server_class
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::server_class
Definition at line 1272 of file vtkPVMessage.pb.h.
◆ kXmlGroupFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kXmlGroupFieldNumber = 20
Definition at line 2136 of file vtkPVMessage.pb.h.
◆ xml_group
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::xml_group
Definition at line 2139 of file vtkPVMessage.pb.h.
◆ kXmlNameFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kXmlNameFieldNumber = 21
Definition at line 2140 of file vtkPVMessage.pb.h.
◆ xml_name
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::xml_name
Definition at line 2143 of file vtkPVMessage.pb.h.
◆ kXmlSubProxyNameFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kXmlSubProxyNameFieldNumber = 22
Definition at line 2144 of file vtkPVMessage.pb.h.
◆ xml_sub_proxy_name
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::xml_sub_proxy_name
Definition at line 2147 of file vtkPVMessage.pb.h.
◆ kPropertyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kPropertyFieldNumber = 23
Definition at line 2148 of file vtkPVMessage.pb.h.
◆ property
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_Property >, 11, false > paraview_protobuf::PROTOBUF_FINAL::property
Definition at line 2151 of file vtkPVMessage.pb.h.
◆ kSubproxyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kSubproxyFieldNumber = 24
Definition at line 2152 of file vtkPVMessage.pb.h.
◆ subproxy
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_SubProxy >, 11, false > paraview_protobuf::PROTOBUF_FINAL::subproxy
Definition at line 2155 of file vtkPVMessage.pb.h.
◆ kAnnotationFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kAnnotationFieldNumber = 25
Definition at line 2156 of file vtkPVMessage.pb.h.
◆ annotation
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_Annotation >, 11, false > paraview_protobuf::PROTOBUF_FINAL::annotation
Definition at line 2159 of file vtkPVMessage.pb.h.
◆ kHasAnnotationFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kHasAnnotationFieldNumber = 26
Definition at line 2160 of file vtkPVMessage.pb.h.
◆ has_annotation
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > paraview_protobuf::PROTOBUF_FINAL::has_annotation
Definition at line 2163 of file vtkPVMessage.pb.h.
◆ kUserDataFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kUserDataFieldNumber = 27
Definition at line 2164 of file vtkPVMessage.pb.h.
◆ user_data
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyState_UserData >, 11, false > paraview_protobuf::PROTOBUF_FINAL::user_data
Definition at line 2167 of file vtkPVMessage.pb.h.
◆ kLogNameFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kLogNameFieldNumber = 28
Definition at line 2168 of file vtkPVMessage.pb.h.
◆ log_name
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::log_name
Definition at line 2171 of file vtkPVMessage.pb.h.
◆ kVtkClassnameFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kVtkClassnameFieldNumber = 29
Definition at line 2172 of file vtkPVMessage.pb.h.
◆ vtk_classname
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::vtk_classname
Definition at line 2175 of file vtkPVMessage.pb.h.
◆ kRegisteredProxyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kRegisteredProxyFieldNumber = 30
Definition at line 2505 of file vtkPVMessage.pb.h.
◆ registered_proxy
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::PXMRegistrationState_Entry >, 11, false > paraview_protobuf::PROTOBUF_FINAL::registered_proxy
Definition at line 2508 of file vtkPVMessage.pb.h.
◆ kRegisteredSelectionModelFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kRegisteredSelectionModelFieldNumber = 31
Definition at line 2509 of file vtkPVMessage.pb.h.
◆ registered_selection_model
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::PXMRegistrationState_Entry >, 11, false > paraview_protobuf::PROTOBUF_FINAL::registered_selection_model
Definition at line 2512 of file vtkPVMessage.pb.h.
◆ kRegisteredLinkFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kRegisteredLinkFieldNumber = 32
Definition at line 2513 of file vtkPVMessage.pb.h.
◆ registered_link
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::PXMRegistrationState_Entry >, 11, false > paraview_protobuf::PROTOBUF_FINAL::registered_link
Definition at line 2516 of file vtkPVMessage.pb.h.
◆ kXmlDefinitionProxyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kXmlDefinitionProxyFieldNumber = 35
Definition at line 2853 of file vtkPVMessage.pb.h.
◆ xml_definition_proxy
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition >, 11, false > paraview_protobuf::PROTOBUF_FINAL::xml_definition_proxy
Definition at line 2856 of file vtkPVMessage.pb.h.
◆ kXmlCustomDefinitionProxyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kXmlCustomDefinitionProxyFieldNumber = 36
Definition at line 2857 of file vtkPVMessage.pb.h.
◆ xml_custom_definition_proxy
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition >, 11, false > paraview_protobuf::PROTOBUF_FINAL::xml_custom_definition_proxy
Definition at line 2860 of file vtkPVMessage.pb.h.
◆ kArgumentsFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kArgumentsFieldNumber = 40
Definition at line 2992 of file vtkPVMessage.pb.h.
◆ arguments
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::Variant >, 11, false > paraview_protobuf::PROTOBUF_FINAL::arguments
Definition at line 2995 of file vtkPVMessage.pb.h.
◆ kCurrentProxyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kCurrentProxyFieldNumber = 52
Definition at line 3127 of file vtkPVMessage.pb.h.
◆ current_proxy
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > paraview_protobuf::PROTOBUF_FINAL::current_proxy
Definition at line 3130 of file vtkPVMessage.pb.h.
◆ kCurrentPortFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kCurrentPortFieldNumber = 53
Definition at line 3131 of file vtkPVMessage.pb.h.
◆ current_port
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::int32 >, 5, false > paraview_protobuf::PROTOBUF_FINAL::current_port
Definition at line 3134 of file vtkPVMessage.pb.h.
◆ kProxyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kProxyFieldNumber = 50
Definition at line 3135 of file vtkPVMessage.pb.h.
◆ proxy
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedPrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > paraview_protobuf::PROTOBUF_FINAL::proxy
Definition at line 3138 of file vtkPVMessage.pb.h.
◆ kPortFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kPortFieldNumber = 51
Definition at line 3139 of file vtkPVMessage.pb.h.
◆ port
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedPrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::int32 >, 5, false > paraview_protobuf::PROTOBUF_FINAL::port
Definition at line 3142 of file vtkPVMessage.pb.h.
◆ NONE
constexpr Direction paraview_protobuf::PROTOBUF_FINAL::NONE
Initial value:
Definition at line 3273 of file vtkPVMessage.pb.h.
◆ INPUT [2/2]
constexpr Direction paraview_protobuf::PROTOBUF_FINAL::INPUT
Initial value:
Definition at line 3275 of file vtkPVMessage.pb.h.
◆ OUTPUT
constexpr Direction paraview_protobuf::PROTOBUF_FINAL::OUTPUT
Initial value:
Definition at line 3277 of file vtkPVMessage.pb.h.
◆ Direction_MIN
constexpr Direction paraview_protobuf::PROTOBUF_FINAL::Direction_MIN
Initial value:
Definition at line 3282 of file vtkPVMessage.pb.h.
◆ Direction_MAX
constexpr Direction paraview_protobuf::PROTOBUF_FINAL::Direction_MAX
Initial value:
Definition at line 3284 of file vtkPVMessage.pb.h.
◆ Direction_ARRAYSIZE
constexpr int paraview_protobuf::PROTOBUF_FINAL::Direction_ARRAYSIZE
◆ kPropagateUpdateFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kPropagateUpdateFieldNumber = 60
Definition at line 3497 of file vtkPVMessage.pb.h.
◆ propagate_update
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > paraview_protobuf::PROTOBUF_FINAL::propagate_update
Definition at line 3500 of file vtkPVMessage.pb.h.
◆ kEnabledFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kEnabledFieldNumber = 61
Definition at line 3501 of file vtkPVMessage.pb.h.
◆ enabled
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > paraview_protobuf::PROTOBUF_FINAL::enabled
Definition at line 3504 of file vtkPVMessage.pb.h.
◆ kSyncInteractiveRendersFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kSyncInteractiveRendersFieldNumber = 62
Definition at line 3505 of file vtkPVMessage.pb.h.
◆ sync_interactive_renders
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > paraview_protobuf::PROTOBUF_FINAL::sync_interactive_renders
Definition at line 3508 of file vtkPVMessage.pb.h.
◆ kLinkFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kLinkFieldNumber = 63
Definition at line 3509 of file vtkPVMessage.pb.h.
◆ link
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::LinkState_LinkDescription >, 11, false > paraview_protobuf::PROTOBUF_FINAL::link
Definition at line 3512 of file vtkPVMessage.pb.h.
◆ kExceptionPropertyFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kExceptionPropertyFieldNumber = 64
Definition at line 3513 of file vtkPVMessage.pb.h.
◆ exception_property
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedStringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::exception_property
Definition at line 3516 of file vtkPVMessage.pb.h.
◆ BOTH
constexpr Ratio paraview_protobuf::PROTOBUF_FINAL::BOTH
Initial value:
Definition at line 3647 of file vtkPVMessage.pb.h.
◆ HEIGHT
constexpr Ratio paraview_protobuf::PROTOBUF_FINAL::HEIGHT
Initial value:
Definition at line 3649 of file vtkPVMessage.pb.h.
◆ WIDTH
constexpr Ratio paraview_protobuf::PROTOBUF_FINAL::WIDTH
Initial value:
Definition at line 3651 of file vtkPVMessage.pb.h.
◆ Ratio_MIN
constexpr Ratio paraview_protobuf::PROTOBUF_FINAL::Ratio_MIN
Initial value:
Definition at line 3656 of file vtkPVMessage.pb.h.
◆ Ratio_MAX
constexpr Ratio paraview_protobuf::PROTOBUF_FINAL::Ratio_MAX
Initial value:
Definition at line 3658 of file vtkPVMessage.pb.h.
◆ Ratio_ARRAYSIZE
constexpr int paraview_protobuf::PROTOBUF_FINAL::Ratio_ARRAYSIZE
Initial value:
Definition at line 3660 of file vtkPVMessage.pb.h.
◆ kViewFieldNumber
static const int paraview_protobuf::PROTOBUF_FINAL::kViewFieldNumber = 70
Definition at line 3680 of file vtkPVMessage.pb.h.
◆ view
static::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier<::paraview_protobuf::Message,::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits<::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > paraview_protobuf::PROTOBUF_FINAL::view
Definition at line 3683 of file vtkPVMessage.pb.h.
◆ kXFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kXFieldNumber = 71
Definition at line 3684 of file vtkPVMessage.pb.h.
◆ x
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< double >, 1, false > paraview_protobuf::PROTOBUF_FINAL::x
Definition at line 3687 of file vtkPVMessage.pb.h.
◆ kYFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kYFieldNumber = 72
Definition at line 3688 of file vtkPVMessage.pb.h.
◆ y
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< double >, 1, false > paraview_protobuf::PROTOBUF_FINAL::y
Definition at line 3691 of file vtkPVMessage.pb.h.
◆ kForceShowFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kForceShowFieldNumber = 73
Definition at line 3692 of file vtkPVMessage.pb.h.
◆ forceShow
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< bool >, 8, false > paraview_protobuf::PROTOBUF_FINAL::forceShow
Definition at line 3695 of file vtkPVMessage.pb.h.
◆ kRatioTypeFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kRatioTypeFieldNumber = 74
Definition at line 3696 of file vtkPVMessage.pb.h.
◆ ratioType
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::EnumTypeTraits< ::paraview_protobuf::MousePointer_Ratio, ::paraview_protobuf::MousePointer_Ratio_IsValid>, 14, false > paraview_protobuf::PROTOBUF_FINAL::ratioType
Definition at line 3699 of file vtkPVMessage.pb.h.
◆ kRangeFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kRangeFieldNumber = 76
Definition at line 3835 of file vtkPVMessage.pb.h.
◆ range
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedPrimitiveTypeTraits< double >, 1, false > paraview_protobuf::PROTOBUF_FINAL::range
Definition at line 3838 of file vtkPVMessage.pb.h.
◆ kUserFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kUserFieldNumber = 80
Definition at line 4203 of file vtkPVMessage.pb.h.
◆ user
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::RepeatedMessageTypeTraits< ::paraview_protobuf::ClientsInformation_ClientInfo >, 11, false > paraview_protobuf::PROTOBUF_FINAL::user
Definition at line 4206 of file vtkPVMessage.pb.h.
◆ kAuthorFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kAuthorFieldNumber = 84
Definition at line 4338 of file vtkPVMessage.pb.h.
◆ author
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::PrimitiveTypeTraits< ::PROTOBUF_NAMESPACE_ID::uint32 >, 13, false > paraview_protobuf::PROTOBUF_FINAL::author
Definition at line 4341 of file vtkPVMessage.pb.h.
◆ kTxtFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kTxtFieldNumber = 85
Definition at line 4342 of file vtkPVMessage.pb.h.
◆ txt
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::StringTypeTraits, 9, false > paraview_protobuf::PROTOBUF_FINAL::txt
Definition at line 4345 of file vtkPVMessage.pb.h.
◆ CHAT
constexpr QtEventType paraview_protobuf::PROTOBUF_FINAL::CHAT
Initial value:
Definition at line 4476 of file vtkPVMessage.pb.h.
◆ OTHER
constexpr QtEventType paraview_protobuf::PROTOBUF_FINAL::OTHER
Initial value:
Definition at line 4478 of file vtkPVMessage.pb.h.
◆ QtEventType_MIN
constexpr QtEventType paraview_protobuf::PROTOBUF_FINAL::QtEventType_MIN
Initial value:
Definition at line 4483 of file vtkPVMessage.pb.h.
◆ QtEventType_MAX
constexpr QtEventType paraview_protobuf::PROTOBUF_FINAL::QtEventType_MAX
Initial value:
Definition at line 4485 of file vtkPVMessage.pb.h.
◆ QtEventType_ARRAYSIZE
constexpr int paraview_protobuf::PROTOBUF_FINAL::QtEventType_ARRAYSIZE
Initial value:
Definition at line 4487 of file vtkPVMessage.pb.h.
◆ kTypeFieldNumber
const int paraview_protobuf::PROTOBUF_FINAL::kTypeFieldNumber = 98
Definition at line 4507 of file vtkPVMessage.pb.h.
◆ type
::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< ::paraview_protobuf::Message, ::PROTOBUF_NAMESPACE_ID::internal::EnumTypeTraits< ::paraview_protobuf::QtEvent_QtEventType, ::paraview_protobuf::QtEvent_QtEventType_IsValid>, 14, false > paraview_protobuf::PROTOBUF_FINAL::type
Definition at line 4510 of file vtkPVMessage.pb.h.
