Bug fixes made since ParaView 5.13.2 are listed below:
Interface improvements
- MultiBlock Inspector enables the Extract Blocks button only when needed. (details)
- The Lock View Size option in the Tools menu is reset to off when ParaView's session is reset. (details)
- Find Data: fixed an issue with regular expression of values containing a dot. (details)
- Fixed an incorrect tooltip in the Adjust Camera dialog. (details)
Rendering
- Fixed initial display of Polar Axes. (details)
- Fixed Polar Axes bounds in client/server mode. (details)
- Fixed issues drawing thick lines on Macs with Apple Silicon chips. (details here and here)
- Unexpected rescaling of the bottom axis in the Histogram view was fixed. (details)
- Backface coloring for 3D Glyph representation has been fixed. (details)
- The minimum and maximum values displayed when color legend's Draw Data Range Label option is on are now displayed correctly. (details)
Readers
- Fixed VTKHDF reader overflow issue when reading AMR datasets. (details)
- AMReX Particle reader now works even when there is no header file available. (details)
- Fixed AMReX Grid reader to enable reading files larger than 2GB on Windows. (details)
- Fix AMReX Particles reader when using MPI when the number of grids in the loaded dataset is not exactly divisible by the number of MPI processes. (details)
- Fixed EnSight Gold binary reader to prevent integer math overflow when reading a large number of cells. (details)
- XDMF2 reader now reports an error message when a dataset has a rank that does not match an array's selection rank. (details)
- The CDI reader is now more stable on Windows. (details)
Filters
- Extract Selection Over Time now works with HyperTree Grid datasets. (details)
Catalyst
- AnimationScene is no longer referenced in exported Catalyst scripts when there are no image extractors in the pipeline (details)
- Fixed some flaky behavior when processing fields in Catalyst. (details)
- Avoid crash when Catalyst 2 script path points to file that does not exist. (details)
- ParaView Catalyst now catches
pipeline_execute_failed errors that occur during Catalyst pipeline execution. (details)
Build
- Compilation failures on Intel Classic compilers was fixed. (details here and here)
