The full list of issues addressed by this release is available here. Major changes made since ParaView 5.4.1 include the following:
ParaView's Ray Traced Rendering capacity continues to evolve. In this release we've updated to a new version of OSPRay that gives us the ability to directly volume render Overlapping AMR and Unstructured Grid data in addition to the Structured Grid that we've had for a couple of releases now. We've also exposed a path tracing option for surface geometry. What this does is give the capacity for full photorealism by sampling the scene with many more rays and ray bounces than before. For this purpose we've added the Light Inspector panel in which you can add, remove and more precisely control an arbitrary number of lights in the scene. The Light Inspector's radius control, which results in soft shadows with the path tracer, is the only part of the panel that is specific to OSPRay, the rest is also useful for standard rendering. Also, for the purpose of photorealism, we've added an ability to import JSON-based OSPRay Material specification files. Materials are a way to give objects, blocks, or cells advanced textures and arbitrary appearance properties that make them look like metal, glass, and other real world effects. Note that many features of the path tracer (like shadows before and reflections and refractions now) will result in rendering artifacts in distributed memory parallel runs.
| OSPRay path tracer combined with typical visualization capabilities. |
Using Render Lines As Tubes and Render Points As Spheres properties in the Display section on the Properties Panel, it's now possible to render lines as 3D tubes and points as 3D spheres.
To make it easier to generate publication quality images, ParaView has a new Preview mode. Preview mode is similar to the Print Preview mode offered by many tools, including your web browser. The idea is to provide a way to do final visualization setup just prior to saving a screenshot or animation in a way that minimizes surprise object rescaling in the save image output, which can happen if the ParaView window aspect ratio differs from the requested image resolution aspect ratio. To use Preview mode, select a target resolution from the View -> Preview submenu and the active layout will be resized to match the chosen resolution. If the target resolution is larger than the space available for the layout tab on your screen, it will be resized to match the target aspect ratio.
| Preview mode resolution size selection. |
A number of bugfixes went into the Eye Dome Lighting and IceT layers to allow this screen-space ambient occlusion algorithm to work on parallel/remote render servers.
This plugin adds three new representations.
| Extrusion map created with the embossing plugin. Data and picture credit: [http://www.dkrz.de/](DKRZ). |
This option is now exposed through settings. Enabling it will include volumes in the depth-peeling pass to render intermixed volumes with translucent polygons correctly.
It is now possible to enable culling and level of detail (LOD) in the 3D Glyphs representation. This enables rendering a higher number of glyphs at interactive frame rates. When the option is enabled, instances that are not visible are discarded and not drawn. One can also specify LOD parameters inside a table. The first table column is the distance after which the LOD is enabled, the second column is the reduction factor applied to the instance geometry. It is also possible to display instances in different colors depending on the LOD. Please note that this feature works only with OpenGL driver >= 4.0.
| 3D Glyphs representation option in the user interface. |
| 3D Glyphs rendering 1 million instances of a bunny model. |
As in earlier versions of ParaView, it is again possible to orient the color legend title horizontally when the color legend is oriented vertically. By default, the title is rotated 90 degrees counterclockwise and aligned with the color legend vertically.
Thanks to a recent change in VTK, it is now possible to use the OpenGL-based volume rendering mapper to display isocontours without precomputing them on the CPU. This feature is exposed through two new properties on the image volume representation: Show IsoSurfaces to enable the feature, and Contour Values to specify the isocontours values similar to how they are set in the Contour filter.
| Image volume representation isocontours. |
It is now possible to create new filters from the Pipeline Browser context menu. Only filters that are applicable to the active source are shown in the context menu.
Adjust Camera dialog now allows saving of more than 4 camera positions. The limit has been extended to 30 positions, with a minimum of 4. You can add/remove positions within this limit using the Adjust Camera dialog's Configure... button.
The LZMA lossless compressor is now available when writing XML data files, offering a higher compression ratio and higher write time compared with existing LZ4 and ZLib compressors. A Compression Level setting is now available to fine tune the tradeoff between compressed file size and write time for each compressor.
ParaView's XML readers and writers support arbitrary-order Lagrange finite elements. The Unstructured Cell Type source can be used to generate representative grids with Lagrange elements.
|| |:–:| | An example of a grid with higher-order wedges. |
Previously, the order of selection of the proxies in the pipeline was not respected. For instance, selecting a Box Source first and then a Sphere Source in the pipeline before applying a Group DataSets filter did not ensure that block 0 would be the box. Selection order is now respected
This plugin introduces two new filters to help the analysis of digital rock.
| Exploded rock view from the DigitalRockPhysics plugin. |
We add support for vtkMolecule as input/output data type in the Python Programmable Source and Programmable Filter. Molecule type is now also exposed correctly in the Information Panel.
ParaView now supports reading particle data from AMReX plotfiles. The reader supports both single plotfile or multiple plotfiles that form a time series.
vtkFileSeriesReader now supports a new meta file format based on JSON. This format has support for specifying time values. The format (currently version 1.0) looks like the following
The reader will interpret any files that end with the .series extension as a = meta file. To add support for the meta file for a reader in the readers description, add the extension.series extension to the extension list. For example, for legacy VTK files, the reader now supports .vtk and .vtk.series
ParaView now supports geospatial (GDAL Raster and Vector Reader) and point cloud data (PDAL Reader). Any dataset supported by GDAL or PDAL libraries is now supported by ParaView.
| An orthorectified satellite image and a point cloud of Jacksonville, FL, rendered in ParaView. |
CGNS library has been updated to version 3.3.1. This version contains a bug fix that allows loading large files in Windows.
When the 3D Glyph representation is selected, one can use a data array to define the orientation of the glyphs. Previously, one had a choice between direction vector or angles around three axes (both by selecting a 3-components array). We added a new Quaternion mode to specify the orientation through a 4-components point array with quaternions defined in WXYZ format.
A newly added filter Plot Data Over Time supports plotting entire datasets, and not just the selected subset. When in distributed mode, however, the current implementation show stats for each rank separately. This will be fixed in a future release to correctly compute distributed statistical summaries.
PVD reader (vtkPVDReader) now supports selecting which arrays to read. This can be useful to minimize memory foot print and reduce I/O times when reading PVD files by skipping arrays that may not be needed.
ParaView now supports restoring user preferences to default from the Edit menu. One can optionally generate backup files before restoring user preferences to default.
Dialogs for save-screenshot and save-animation now show file format-specific options for quality, compression, etc., rather than a single Image Quality parameter which was internally interpreted differently for each file format. This allows the user finer controls based on the file format, in addition to avoiding confusion.
It is now possible to display 2D and 3D text with TrueType font files you provide, and thus use fonts different from the built-in fonts (Arial, Courier, and Times). This feature is accessible by choosing File as the font family in the Font Properties property and then specifying the full path to the .ttf file in the file selection field.
| TrueType fonts can now be used for text. |
All functionality related to the experimental vtkHyperOctree tree-based AMR implementation has been deprecated in VTK and removed from ParaView. It is being replaced with the newer vtkHyperTreeGrid data structure, which is more efficient and more expressive than its predecessor. The new vtkHyperTreeGrid is a superset of previous implementation. This ParaView release includes a more efficient hyper tree grid implementation than in 5.4 along with VTK XML based IO, a few dedicated filters, and bug fixes.
Clip filter now can clip away the exact exterior of a box. Note, though, that this is an expensive operation as it performs six plane clips in order to provide the exact box clip.
Which portion of the geometry was clipped has been inverted as the default was confusing for the Box, Sphere, and Cylinder. Now, the clipped geometry is interior to the clip shape rather than exterior.
The Generate Ghosts Cells filter was added. It generates a requested level of ghost cells. The Remove Ghost Information filter will remove ghost cells from datasets.
Attribute arrays appended with the Append Attributes filter are renamed to accommodate inputs with arrays having the same name.
All filters are now available in the GUI regardless of how many pvserver processes are being used. This will allow filters like Process Id Scalars and Generate Ghosts Cells to be easily added with a serial pvserver process with the intent of saving a Python trace, state, or generating a Catalyst Python script that can be properly used in parallel later on.
Added option to specify array type for Calculator filter. This is the available via the new Result Array Type advanced option.
Added the Cell Size filter to measure the number of points for vertex or polyvertex cells, length for 1D cells, area for 2D cells and/or volume for 3D cells.The sizes are output in separate cell data arrays and you can choose which arrays to output. The filter also includes an option to sum the size and will output this in field data arrays.
Added new options for vtkGradientFilter for controlling which cells contribute to the gradient calculation.
A new GenericIO reader provides support for reading Argonnes National Laboratory’s GenericIO files produced by the HACC simulation code. It also allows sampling of the GenericIO files as well as basic filtering operations.
Improved the file series writer to allow specifying min, max and stride for time steps.
Added the ability to read raw images as a time series.
Added option to write out all time steps for XML PVD Writer (i.e. .pvd output files).
Added option to output text files as tab-delimited. The file extension for this is .tsv.
We added a volume rendering edition for Catalyst.
Several improvements have been made in VTK/ParaView Web to offer better image delivery performances. We added new controls for the server side to manage image resolution and framerate while interacting.
The Web applications have also been updated accordingly to leverage those new capabilities.
ParaView 5.5 bundles the following applications:
On Unix, ParaView no longer installs its libraries under <prefix>/lib/paraview-${paraview-version}. Instead, it follows the standard practice of installing them under <prefix>/lib directly.
Python packages built by ParaView are now built and installed under <prefix>/lib/python-$<python-version>/site-packages on *nixes, and <prefix>/bin/Lib/site-packages on Windows. This is consistent with how Python installs its packages on the two platforms. In macOS app bundle, the location in unchanged i.e. <app>/Contents/Python.
Plugins are built and installed in self contained directories named same as the plugin under PARAVIEW_BUILD_PLUGINS_DIR and PARAVIEW_INSTALL_PLUGINS_DIR. These are set to lib/paraview-${paraview-version}/plugins (bin/plugins on Windows) by default. For macOS app bundles too, while the plugins are installed under <app>/Contents/Plugins, they are now contained in a separate directory per plugin.
The .plugins file has also been moved to PARAVIEW_BUILD_PLUGINS_DIR and PARAVIEW_INSTALL_PLUGINS_DIR for builds and installs respectively.
vtkSIDataArraySelectionProperty makes it easier to expose array selection properties for filter/readers that support an API to toggle selection status using vtkDataArraySelection instance. See vtkSIDataArraySelectionProperty docs for details.
We removed the CoProcessingScriptGenerator plugin and promoted its functions to mainline ParaView. As before they depend on Python and Qt, but otherwise they are now always available. With this we removed the plugin's two menus and moved their contents under the Catalyst menu.
The ClientServer wrapping tool now uses the WRAP_EXCLUDE_PYTHON property rather than WRAP_EXCLUDE. It also now properly skips classes which cannot be wrapped with no-op wrappings (rather than failing as before). One limitation currently is that files with no classes still need to be excluded since the wrapper does not know what name to use when creating the no-op function.
info attribute for EnumerationDomainEnumerationDomain now supports info attribute for each of the entries. If present, the UI will show that text in the combo-box rendered for the domain to provide you additional tips for the items to choose.
ParaView now supports add a QToolBar subclass via the plugin mechanism. In the past, one had to add actions to a toolbar via a QActionGroup. Now, directly adding a QToolBar is a supported by using add_paraview_toolbar CMake function.
WarnOnCreateSources and filters XML now supports an ability to add a warning or information message for the user to be shown when creating the source or filter. See WarnOnCreate hint for details.
1.8.13 on Sun Dec 14 2025
