1 # Tests that require python 3 list(APPEND TESTS_WITHOUT_BASELINES
4 AllPropertiesSaveStatePython.xml
8 ProgrammableSourcePythonEditorLink.xml
9 PythonDefaultLoadState.xml
10 PythonDefaultSaveState.xml
12 PythonResetSessionMacro.xml
13 SpreadSheetNullArrayName.xml # needs programmable filter
14 # TestPopOutWidget.xml
16 TraceIntegrateVariables.xml
19 # This test rely on copy being Ctrl-C 21 list(APPEND TEST_WITHOUT_BASELINES_CLIENT_ONLY
23 TestHTGHoverOnCell.xml
27 # VTTKJS exporter requires the Web module 28 if (PARAVIEW_ENABLE_WEB)
29 list (APPEND TESTS_WITHOUT_BASELINES
31 ExportToVTKJSWithArraySelection.xml
33 set (ExportToVTKJS_FORCE_SERIAL TRUE) # since
this uses popup-menu
36 list(APPEND TESTS_WITH_BASELINES
38 ColorByComponentNames.xml # needs programmable filter
39 LiveProgrammableSource.xml
42 PythonShellRunScript.xml
44 SaveLoadStatePython.xml
45 SaveLoadStateSelectionPython.xml
47 TraceExportAndSaveData.xml
49 # TraceStatisticsFilter.xml (see paraview/paraview#20661. Also was disabled in CS/CRS mode)
50 TraceSupplementalProxiesFully.xml
52 TraceWithoutRenderingComponents.xml
54 # Surface selection unstable on CRS mode
55 set(SaveLoadStateSelectionPython_DISABLE_CRS TRUE)
57 set (AutoSaveState_FORCE_SERIAL TRUE) # since
this modifies settings
59 list(APPEND TESTS_WITH_INLINE_COMPARES
60 RestoreArrayDefaultTransferFunction.xml
61 RestoreDefaultTransferFunction.xml
63 SelectionLinkScripting.xml
68 set(SelectCellsTrace_DISABLE_CRS TRUE)
69 set(SelectPointsTrace_DISABLE_CRS TRUE)
71 # Check that matplotlib is available 72 include(ParaViewFindPythonModules)
75 list(APPEND TESTS_WITH_BASELINES TestPythonView.xml)
76 list(APPEND TESTS_WITH_INLINE_COMPARES TextSourceInteriorLines.xml)
77 list(APPEND TESTS_WITH_INLINE_COMPARES TextSourcesInChartViews.xml)
78 list(APPEND TESTS_WITH_INLINE_COMPARES MathTextColumn.xml)
83 list(APPEND TESTS_WITH_BASELINES
84 AnnotateNotSanitizedArray.xml
85 ContextViewSelectionTrace.xml
86 FindDataNameSanitization.xml
87 FindDataNonDistributedData.xml
88 FindDataPartialArrays.xml
89 FindDataSelectLocationMultiblock.xml
# find data needs python/numpy 90 FindDataSelectLocation.xml # find
94 FreezeQueryMultiblock.xml
95 IndexedLookupInitialization.xml # needs Python Calculator/numpy
96 PlotOverLine_surface.xml # needs find
data 97 ProgrammableAnnotation.xml
98 SelectionSaveStatePVSM.xml # find
99 SelectionSaveStatePython.xml # find
100 SpreadSheetSelectionTrace.xml
101 StructuredGridCellBlanking.xml
102 VolumeNoMapScalars.xml # needs programmable filter + numpy
105 # Selection non-functional on CRS mode
106 set(SelectionSaveStatePVSM_DISABLE_CRS TRUE)
108 # Test without baselines and could only run in built-in mode. 109 list(APPEND TEST_WITHOUT_BASELINES_CLIENT_ONLY
110 HyperTreeGridGenerateFields.xml
111 HTGPlotSelectionOverTime.xml
112 MultipleNumberOfComponents.xml
113 ProgrammableFilterFieldData.xml
114 PythonCalculatorInput.xml
117 list(APPEND TESTS_WITHOUT_BASELINES
118 ExpressionChooser.xml
120 FieldDataDomainDefault.xml
121 PlotOverLine_htg.xml # needs find data
123 PythonCalculatorArrayAssociation.xml
124 PythonCalculatorAutocomplete.xml
125 PythonCalculatorCrossComposite.xml
126 PythonCalculatorFieldData.xml
127 PythonCalculatorMultiline.xml
128 SelectionAndAutoSaveState.xml
131 set(SpreadSheetSelectionTrace_DISABLE_CS TRUE)
132 set(SpreadSheetSelectionTrace_DISABLE_CRS TRUE)
134 list(APPEND TESTS_WITH_INLINE_COMPARES
138 TestTableFFT.xml # needs programmable filter + numpy
141 # PythonAlgorithm plugin tests. 143 "PythonAlgorithmPlugin.xml.in" 144 "${CMAKE_CURRENT_BINARY_DIR}/PythonAlgorithmPlugin.xml" @ONLY)
146 "PythonAlgorithmReadersAndWriters.xml.in" 147 "${CMAKE_CURRENT_BINARY_DIR}/PythonAlgorithmReadersAndWriters.xml" @ONLY)
149 set(pyalgo_plugin_tests
150 PythonAlgorithmPlugin
151 PythonAlgorithmReadersAndWriters)
152 foreach(tname IN LISTS pyalgo_plugin_tests)
153 list(APPEND TESTS_WITH_BASELINES
154 ${CMAKE_CURRENT_BINARY_DIR}/${tname}.xml)
156 # we need to extend testing infrastructure to better support
157 # loading plugins in client-server. At that point, we can test these as well.
158 set(${tname}_DISABLE_CS TRUE)
159 set(${tname}_DISABLE_CRS TRUE)
163 #---------------------------------------------------------------------- 164 # Tests that produce some output (other than rendered images) from ParaView 165 # that should be checked for correctness. These work by executing an XML 166 # test in the UI that produces some output, then pvpython runs a Python script 167 # that checks the file for correctness. Example use: checking a CSV 168 # file for expected content. 170 # Tests listed here are required to define the following files: 171 # - <test>.xml - XML test script to play in the uI 172 # - <test>Verify.py - Python code to verify output saved out in the XML 174 #---------------------------------------------------------------------- 175 set(paraview_python_verify_tests
176 ExportMultiblockFieldDataSpreadsheet
177 ExportSceneSpreadSheetView
180 if (PARAVIEW_ENABLE_WEB)
181 list(APPEND paraview_python_verify_tests
186 if (PARAVIEW_USE_PYTHON)
187 foreach(test_name ${paraview_python_verify_tests})
188 set(tname
"ParaView::Applications::${test_name}")
189 add_test(
NAME ${tname}
190 COMMAND ${CMAKE_COMMAND}
191 -DPARAVIEW_EXECUTABLE:FILEPATH=$<TARGET_FILE:ParaView::paraview>
192 -DPVPYTHON_EXECUTABLE:FILEPATH=$<TARGET_FILE:ParaView::pvpython>
193 -DDATA_DIR:PATH=${paraview_test_data_directory_output}
194 -DTEST_NAME:STRING=${test_name}
195 -DTEST_SCRIPT:FILEPATH=${CMAKE_CURRENT_SOURCE_DIR}/${test_name}.xml
196 -DTEST_VERIFIER:FILEPATH=${CMAKE_CURRENT_SOURCE_DIR}/${test_name}Verify.py
197 -DTEMPORARY_DIR:PATH=${CMAKE_BINARY_DIR}/Testing/Temporary
198 -P ${CMAKE_CURRENT_SOURCE_DIR}/PythonScriptTestDriver.cmake
200 set_tests_properties(${tname} PROPERTIES
LABELS "paraview")
function find_python_module(module_name, result)
