MantisBT - ParaView |
View Issue Details |
0011802 | ParaView | Bug | public | 2011-02-04 23:41 | 2011-07-29 10:43 |
Reporter | Stephane P | |
Assigned To | Utkarsh Ayachit | |
Priority | high | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | |
Platform | linux | OS | ubuntu | OS Version | 10.10 64bit |
Product Version | Development | |
Target Version | | Fixed in Version | 3.12 | |
Project | ParaViS |
Topic Name | |
Type | |
Summary | 0011802: point sprite plugin python trace not functionnal |
Description | Dumping a python script using the trace functionnality creates a script that does not reproduce the same result when re-executed, especially when using the texture mode. |
Steps To Reproduce | load point sprite plugin, start trace, create wavelet source, set represetation to point sprite, texture mode and sphere texture, stop trace, save python script.
clean pipeline (Edit --> delete all), run script (python shell --> run script)
The representation does not use the sphere texture as it should. |
Additional Information | attached is the python script generated by the above steps, that can also be run by pvpython. |
Tags | No tags attached. |
Relationships | has duplicate | 0011702 | closed | Utkarsh Ayachit | Trace recorder creates lots of junk |
Attached Files | test.py (12,022) 2011-02-04 23:41 https://www.vtk.org/Bug/file/8679/test.py |
2011-02-04 23:41 | Stephane P | New Issue | |
2011-02-04 23:41 | Stephane P | File Added: test.py | |
2011-02-07 10:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-02-07 10:16 | Utkarsh Ayachit | Status | backlog => tabled |
2011-02-07 14:46 | Utkarsh Ayachit | Note Added: 0025318 | |
2011-02-07 14:46 | Utkarsh Ayachit | Status | tabled => @80@ |
2011-02-07 14:46 | Utkarsh Ayachit | Fixed in Version | => 4.0 |
2011-02-07 14:46 | Utkarsh Ayachit | Resolution | open => fixed |
2011-02-11 14:00 | Utkarsh Ayachit | Relationship added | has duplicate 0011702 |
2011-05-02 21:30 | Alan Scott | Note Added: 0026411 | |
2011-05-02 21:30 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
2011-07-29 10:43 | Utkarsh Ayachit | Fixed in Version | 4.0 => 3.12 |
