(0003679)
Utkarsh Ayachit
2006-02-03 10:34
The issue had nothing to do with Client/Server. The second time a state was saved in any paraview session, it was always saved wrong.
The problem was the the widgets' trace helper assumed that the they had initialized the widgets in the state file after the first saving of state file. Any consecutive saves did not reset the flag that indicated that the widget had been initialized in the state, hence all subsequent saved states were broken. Fixed it.
new revision: 1.137; previous revision: 1.136
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVSource.cxx,v <-- vtkPVSource.cxx
new revision: 1.475; previous revision: 1.474
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVTraceHelper.cxx,v <-- vtkPVTraceHelper.cxx
new revision: 1.6; previous revision: 1.5
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVTraceHelper.h,v <-- vtkPVTraceHelper.h
new revision: 1.5; previous revision: 1.4
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVWindow.cxx,v <-- vtkPVWindow.cxx
new revision: 1.781; previous revision: 1.780
(0003814)
Utkarsh Ayachit
2006-02-28 10:38
This patch also addresses Bug 0002545 - SNL: Plotting improvements.
Instead of relying of clearing of the StateInitialzed flags by the PVSource before saving state of a widget, now the TraceHelper for each widget obtains the unique state file id assigned to the currently active state file. If the Id is different, then the trace helper realizes that its a new state file and saves the initialization code.
/cvsroot/ParaView/ParaView/GUI/Client/CMakeLists.txt,v <-- CMakeLists.txt
new revision: 1.138; previous revision: 1.137
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVArraySelection.cxx,v <-- vtkPVArraySelection.cxx
new revision: 1.83; previous revision: 1.82
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVArraySelection.h,v <-- vtkPVArraySelection.h
new revision: 1.45; previous revision: 1.44
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVDataAnalysis.cxx,v <-- vtkPVDataAnalysis.cxx
initial revision: 1.1
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVDataAnalysis.h,v <-- vtkPVDataAnalysis.h
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVLineSourceWidget.cxx,v <-- vtkPVLineSourceWidget.cxx
new revision: 1.40; previous revision: 1.39
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotArraySelection.cxx,v <-- vtkPVPlotArraySelection.cxx
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotArraySelection.h,v <-- vtkPVPlotArraySelection.h
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotDisplayLabelPropertiesDialog.cxx,v <-- vtkPVPlotDisplayLabelPropertiesDialog.cxx
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotDisplayLabelPropertiesDialog.h,v <-- vtkPVPlotDisplayLabelPropertiesDialog.h
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVPointSourceWidget.cxx,v <-- vtkPVPointSourceWidget.cxx
new revision: 1.53; previous revision: 1.52
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVPointSourceWidget.h,v <-- vtkPVPointSourceWidget.h
new revision: 1.25; previous revision: 1.24
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVPointWidget.cxx,v <-- vtkPVPointWidget.cxx
new revision: 1.62; previous revision: 1.61
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVProbe.cxx,v <-- vtkPVProbe.cxx
new revision: 1.171; previous revision: 1.170
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVReaderModule.cxx,v <-- vtkPVReaderModule.cxx
new revision: 1.73; previous revision: 1.72
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVSelectWidget.cxx,v <-- vtkPVSelectWidget.cxx
new revision: 1.78; previous revision: 1.77
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVSelectWidget.h,v <-- vtkPVSelectWidget.h
new revision: 1.37; previous revision: 1.36
new revision: 1.477; previous revision: 1.476
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVSource.h,v <-- vtkPVSource.h
new revision: 1.205; previous revision: 1.204
new revision: 1.783; previous revision: 1.782
/cvsroot/ParaView/ParaView/GUI/Client/vtkPVWindow.h,v <-- vtkPVWindow.h
new revision: 1.246; previous revision: 1.245
/cvsroot/ParaView/ParaView/GUI/Client/Resources/Filters.xml,v <-- Filters.xml
new revision: 1.169; previous revision: 1.168
/cvsroot/ParaView/ParaView/Servers/Filters/CMakeLists.txt,v <-- CMakeLists.txt
new revision: 1.85; previous revision: 1.84
/cvsroot/ParaView/ParaView/Servers/Filters/vtkDataAnalysisFilter.cxx,v <-- vtkDataAnalysisFilter.cxx
/cvsroot/ParaView/ParaView/Servers/Filters/vtkDataAnalysisFilter.h,v <-- vtkDataAnalysisFilter.h
/cvsroot/ParaView/ParaView/Servers/Filters/vtkPPickFilter.cxx,v <-- vtkPPickFilter.cxx
/cvsroot/ParaView/ParaView/Servers/Filters/vtkPPickFilter.h,v <-- vtkPPickFilter.h
/cvsroot/ParaView/ParaView/Servers/Filters/vtkPickFilter.h,v <-- vtkPickFilter.hnew revision: 1.9; previous revision: 1.8
/cvsroot/ParaView/ParaView/Servers/Filters/vtkTemporalCacheFilter.cxx,v <-- vtkTemporalCacheFilter.cxx
/cvsroot/ParaView/ParaView/Servers/Filters/vtkTemporalCacheFilter.h,v <-- vtkTemporalCacheFilter.h
/cvsroot/ParaView/ParaView/Servers/ServerManager/CMakeLists.txt,v <-- CMakeLists.txt
/cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMAnimationCueProxy.h,v <-- vtkSMAnimationCueProxy.h
new revision: 1.10; previous revision: 1.9
/cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMTemporalXYPlotDisplayProxy.cxx,v <-- vtkSMTemporalXYPlotDisplayProxy.cxx
/cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMTemporalXYPlotDisplayProxy.h,v <-- vtkSMTemporalXYPlotDisplayProxy.h
/cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotActorProxy.cxx,v <-- vtkSMXYPlotActorProxy.cxx
/cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotActorProxy.h,v <-- vtkSMXYPlotActorProxy.h
/cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotDisplayProxy.cxx,v <-- vtkSMXYPlotDisplayProxy.cxx
new revision: 1.19; previous revision: 1.18
/cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotDisplayProxy.h,v <-- vtkSMXYPlotDisplayProxy.h
new revision: 1.13; previous revision: 1.12
/cvsroot/ParaView/ParaView/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml
new revision: 1.105; previous revision: 1.104
/cvsroot/ParaView/ParaView/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml
new revision: 1.70; previous revision: 1.69
/cvsroot/ParaView/ParaView/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml
new revision: 1.46; previous revision: 1.45
