(0013838)
Ken Moreland
2008-10-10 10:00
One complication to implementing this is dealing with the situation where all objects with time steps become invisible. In this case, the animation mode has to switch from snap to timesteps back to something like sequence. This situation is common when, for example, loading a time series and then adding the temporal interpolator. |
(0015433)
Utkarsh Ayachit
2009-02-26 15:14
Now the context menu on the pipeline browser
has a new checkbox "Ignore Time". If checked, the source will no longer be
considered when determining the timesteps or timeranges for the animation.
Whenever a temporal filter i.e. a filter with "TimestepValues" property is
created, its input is automatically updated to "ignore time" so that the inputs
time will not be considered in the animation (unless of course the user forces
it). This may be a more acceptable solution than creating a new play mode (as
suggedsted by BUG 0007362) or using timesteps from visible objects (as suggested
by BUG 0007799).
/cvsroot/ParaView3/ParaView3/Applications/OverView/Core/MainWindow.cxx,v <-- Applications/OverView/Core/MainWindow.cxx
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Components/pqClientMainWindow.cxx,v <-- Qt/Components/pqClientMainWindow.cxx
new revision: 1.5; previous revision: 1.4
/cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- Qt/Components/pqMainWindowCore.cxx
new revision: 1.307; previous revision: 1.306
/cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- Qt/Components/pqMainWindowCore.h
new revision: 1.101; previous revision: 1.100
/cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.cxx,v <-- Qt/Components/pqPipelineBrowserContextMenu.cxx
new revision: 1.20; previous revision: 1.19
/cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.h,v <-- Qt/Components/pqPipelineBrowserContextMenu.h
new revision: 1.8; previous revision: 1.7
/cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineMenu.cxx,v <-- Qt/Components/pqPipelineMenu.cxx
/cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineMenu.h,v <-- Qt/Components/pqPipelineMenu.h
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqClientMainWindow.ui,v <-- Qt/Components/Resources/UI/pqClientMainWindow.ui
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPendingDisplayManager.cxx,v <-- Qt/Core/pqPendingDisplayManager.cxx
new revision: 1.28; previous revision: 1.27
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineFilter.cxx,v <-- Qt/Core/pqPipelineFilter.cxx
new revision: 1.10; previous revision: 1.9
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineFilter.h,v <-- Qt/Core/pqPipelineFilter.h
/cvsroot/ParaView3/ParaView3/Qt/Core/pqTimeKeeper.cxx,v <-- Qt/Core/pqTimeKeeper.cxx
new revision: 1.18; previous revision: 1.17
/cvsroot/ParaView3/ParaView3/Qt/Core/pqTimeKeeper.h,v <-- Qt/Core/pqTimeKeeper.h
new revision: 1.11; previous revision: 1.10 |
(0015441)
Ken Moreland
2009-02-26 19:24
What happens when the said temporal filter gets deleted? Does the input have its Ignore Time set to 1 or does it stay at 0? Either answer seems wrong. |
(0015450)
Utkarsh Ayachit
2009-02-27 08:08
When the temporal filter gets deleted, it's input's "Ignore Time" gets set back to 0 -- kind of analogous to what happens with visibility. If we changed the timekeeper to use timesteps from "visible" sources, that's exactly what will happen as well. Any alternatives? |
(0015626)
Alan Scott
2009-03-10 17:59
Tested client/remote server using test described above. |
