0007799 | ParaView | (No Category) | public | 2008-10-10 09:58 | 2009-05-13 13:46 | ||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0007799: Snap to timesteps should only snap to timesteps of visibile objects | ||||||||
Description | An annoying "feature" of snap to timesteps animation is that it will snap to timesteps of objects that no one is looking at. This is problematic when, say, someone loads in data and then uses the temporal shift scale filter to change the time range. You really only want to snap to the timesteps after the temporal shift scale, but ParaView also snaps to timesteps of the original data, which may even be outside the range of the desired time. To observe, load the blow file series (found FileSeries directory of the ParaView data), warp by vector, and add a temporal shift scale with shift and scale both 10. Play the animation. You will see that the first part of the animation does nothing because it is playing timesteps from the original data set that are outside of the range of the desired time. | ||||||||
Relationships | |||||||||||
(0013838) Ken Moreland (manager) 2008-10-10 10:00 |
One complication to implementing this is dealing with the situation where all objects with time steps become invisible. In this case, the animation mode has to switch from snap to timesteps back to something like sequence. This situation is common when, for example, loading a time series and then adding the temporal interpolator. |
(0015433) Utkarsh Ayachit (administrator) 2009-02-26 15:14 |
Now the context menu on the pipeline browser has a new checkbox "Ignore Time". If checked, the source will no longer be considered when determining the timesteps or timeranges for the animation. Whenever a temporal filter i.e. a filter with "TimestepValues" property is created, its input is automatically updated to "ignore time" so that the inputs time will not be considered in the animation (unless of course the user forces it). This may be a more acceptable solution than creating a new play mode (as suggedsted by BUG 0007362) or using timesteps from visible objects (as suggested by BUG 0007799). /cvsroot/ParaView3/ParaView3/Applications/OverView/Core/MainWindow.cxx,v <-- Applications/OverView/Core/MainWindow.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqClientMainWindow.cxx,v <-- Qt/Components/pqClientMainWindow.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- Qt/Components/pqMainWindowCore.cxx new revision: 1.307; previous revision: 1.306 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- Qt/Components/pqMainWindowCore.h new revision: 1.101; previous revision: 1.100 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.cxx,v <-- Qt/Components/pqPipelineBrowserContextMenu.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.h,v <-- Qt/Components/pqPipelineBrowserContextMenu.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineMenu.cxx,v <-- Qt/Components/pqPipelineMenu.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineMenu.h,v <-- Qt/Components/pqPipelineMenu.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqClientMainWindow.ui,v <-- Qt/Components/Resources/UI/pqClientMainWindow.ui new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPendingDisplayManager.cxx,v <-- Qt/Core/pqPendingDisplayManager.cxx new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineFilter.cxx,v <-- Qt/Core/pqPipelineFilter.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineFilter.h,v <-- Qt/Core/pqPipelineFilter.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTimeKeeper.cxx,v <-- Qt/Core/pqTimeKeeper.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTimeKeeper.h,v <-- Qt/Core/pqTimeKeeper.h new revision: 1.11; previous revision: 1.10 |
(0015441) Ken Moreland (manager) 2009-02-26 19:24 |
What happens when the said temporal filter gets deleted? Does the input have its Ignore Time set to 1 or does it stay at 0? Either answer seems wrong. |
(0015450) Utkarsh Ayachit (administrator) 2009-02-27 08:08 |
When the temporal filter gets deleted, it's input's "Ignore Time" gets set back to 0 -- kind of analogous to what happens with visibility. If we changed the timekeeper to use timesteps from "visible" sources, that's exactly what will happen as well. Any alternatives? |
(0015626) Alan Scott (manager) 2009-03-10 17:59 |
Tested client/remote server using test described above. |
2008-10-10 09:58 | Ken Moreland | New Issue | |
2008-10-10 10:00 | Ken Moreland | Note Added: 0013838 | |
2008-10-14 02:24 | John Biddiscombe | Relationship added | child of 0007362 |
2008-10-14 02:25 | John Biddiscombe | Relationship added | parent of 0007361 |
2009-02-17 14:18 | Utkarsh Ayachit | Category | 3.6 => Pending |
2009-02-20 13:01 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-20 13:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-20 13:01 | Utkarsh Ayachit | Priority | normal => low |
2009-02-20 13:01 | Utkarsh Ayachit | Category | Pending => 3.6 |
2009-02-26 15:14 | Utkarsh Ayachit | Note Added: 0015433 | |
2009-02-26 15:14 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-02-26 15:14 | Utkarsh Ayachit | Resolution | open => fixed |
2009-02-26 19:24 | Ken Moreland | Note Added: 0015441 | |
2009-02-27 08:08 | Utkarsh Ayachit | Note Added: 0015450 | |
2009-03-10 16:24 | Alan Scott | Status | @80@ => closed |
2009-03-10 17:59 | Alan Scott | Status | closed => @80@ |
2009-03-10 17:59 | Alan Scott | Note Added: 0015626 | |
2009-03-10 17:59 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
