0010078 | ParaView | Bug | public | 2009-12-23 20:42 | 2016-08-12 09:57 | ||||
Reporter | mavridi mike | ||||||||
Product Version | 3.6 | ||||||||
Summary | 0010078: color failure | ||||||||
Description | when i plot surfaces solid color is set to white but it comes out blue. if i set it to yellow then this adds to the blue and the object is green. i don 't know if it is my lap top. this only happens in surfaces. all the other choices work good. i use ubuntu linux and the paraview is 3.4.2 | ||||||||
(0037761) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-12-23 20:42 | mavridi mike | New Issue | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037761 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
