0010117 | ParaView | Bug | public | 2010-01-11 13:40 | 2011-01-13 17:00 | ||||
Reporter | Zhanping Liu | ||||||||
Assigned To | Zhanping Liu | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Product Version | 3.6 | ||||||||
Summary | 0010117: EnSight Reader crashes when animating time steps in ParaView 3.6.2 | ||||||||
Description | When animating time steps of a time-varying EnSight dataset in ParaView 3.6.2, the EnSight Reader crashes. This problem does not occur with ParaView 3.6.1. This problem was reported by Christophe Peyret and Ricardo Reis. | ||||||||
Attached Files | EnSightData_Christophe.zip [^] (495,940 bytes) 2010-01-11 13:40 | ||||||||
(0019089) Zhanping Liu (developer) 2010-01-11 14:09 |
This bug was introduced when adding support for accelerated loading of a time-varying geometry, of which multiple time steps are stored in a disk file (see bug 0009289). The addition of this support affected the animation of time steps for a time-varying EnSight dataset, of which the geometry is either fixed (but with variables such as pressure / temperature varying with time) or stored in separate disk files (each time step of the time-varying geometry is stored in a single disk file). Now this bug (0010117) has been fixed. Changes were made to VTK/IO/vtkEnSightReader.cxx (new revision: 1.88; previous revision: 1.87). Thank Christophe and Ricardo for providing the datasets used for debugging. |
(0019259) Alan Scott (manager) 2010-01-21 19:50 |
Tested with attached data, XP, local server, trunk. |
2010-01-11 13:40 | Zhanping Liu | New Issue | |
2010-01-11 13:40 | Zhanping Liu | File Added: EnSightData_Christophe.zip | |
2010-01-11 13:41 | Zhanping Liu | Assigned To | => Zhanping Liu |
2010-01-11 13:41 | Zhanping Liu | Status | backlog => tabled |
2010-01-11 14:09 | Zhanping Liu | Note Added: 0019089 | |
2010-01-11 14:10 | Zhanping Liu | Status | tabled => @80@ |
2010-01-21 19:50 | Alan Scott | Note Added: 0019259 | |
2010-01-21 19:50 | Alan Scott | Status | @80@ => closed |
2010-01-21 19:50 | Alan Scott | Resolution | open => fixed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
