0010118 | ParaView | Bug | public | 2010-01-11 15:12 | 2016-08-12 09:57 | ||||
Reporter | boroli | ||||||||
Product Version | 3.6 | ||||||||
Summary | 0010118: Periodic End Correction Option failed in TemporalShiftScale Filter | ||||||||
Description | The Periodic End Correction Option in Temporal Shift Scale Filter doesn't seem to have any influence to the rendering. According to the vtk documentation ( http://www.vtk.org/doc/nightly/html/classvtkTemporalShiftScale.html#a6841f89f32bb3393bcaf14eae7c197ca [^] ) one could choose between a 0,1,2,3...N,0,1,2,3... series and a 0,1,2,3...N,1,2,3...N,1,2,3 series. But regardless of the option in paraview, every time the latter series is applied. I've attached an example, in order to demonstrate the problem: - open the *.pvd file - apply a TemporalShiftScale Filter: PreShift 0 PostShift 0 Scale 1 Periodic On Periodic End Correction Off (as the time steps 0 and 11 are not the same) Maximum Number of Periods >=2 As the time steps 0 and 11 are not the same, normally one would expect to turn Off the PeriodicEndCorrection. But even it is Off, there is a jump from timestep 11 to time step 12 (which is equal to timestep 1). | ||||||||
Attached Files | phaselag_rotor1.tar.gz [^] (16,392 bytes) 2010-01-11 15:12 | ||||||||
(0037762) Kitware Robot (administrator) 2016-08-12 09:57 |
2010-01-11 15:12 | boroli | New Issue | |
2010-01-11 15:12 | boroli | File Added: phaselag_rotor1.tar.gz | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037762 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
