0010146 | ParaView | Feature | public | 2010-01-15 05:50 | 2010-12-01 21:22 | ||||
Reporter | Christophe Peyret | ||||||||
Priority | normal | Severity | tweak | Reproducibility | always | ||||
Summary | 0010146: Difficulties to build paraview under OS X | ||||||||
Description | I try to build paraview development version under OSX and I face difficulties santafe:ParaView3-Build peyret$ ccmake ../ParaView3 Qt QTUITOOLS library not found. Qt QTUITOOLS library not found. | ||||||||
(0023619) David Partyka (developer) 2010-11-30 22:20 |
You need to tell ParaView/CMake where your Qt is installed. Specifically this is accomplished by setting QT_QMAKE_EXECUTABLE to the location of qmake on your system. Once qmake is located CMake can query the location of the rest of the components of Qt. If you're still having issues please reopen. |
(0023658) Alan Scott (manager) 2010-12-01 21:22 |
As stated, user needs to tell CMake where to find Qt. See the ParaView Wiki for more information on how to do builds. |
2010-01-15 05:50 | Christophe Peyret | New Issue | |
2010-11-30 22:19 | David Partyka | Assigned To | => David Partyka |
2010-11-30 22:19 | David Partyka | Status | backlog => tabled |
2010-11-30 22:20 | David Partyka | Note Added: 0023619 | |
2010-11-30 22:20 | David Partyka | Status | tabled => @80@ |
2010-11-30 22:20 | David Partyka | Resolution | open => no change required |
2010-12-01 21:22 | Alan Scott | Note Added: 0023658 | |
2010-12-01 21:22 | Alan Scott | Status | @80@ => closed |
