0010274 | ParaView | Bug | public | 2010-02-10 15:55 | 2016-08-12 09:57 | ||||
Target Version | Someday | Fixed in Version | |||||||
Summary | 0010274: zlib compression in vtkMPIMoveData is slowing client-server rendering | ||||||||
Description | zlib compression in vtkMPIMoveData is slowing down data delivery considerably. Following is a timer log for can.ex2. Possible solution would be to compress only when data size is beyond a threshold. ===client==== Still Render, 1.21436 seconds Execute vtkMPIMoveData id: 674, 1.19688 seconds Zlib uncompress, 0.016727 seconds ===server==== Execute vtkMPIMoveData id: 674, 1.1723 seconds Dataserver sending to client, 1.17105 seconds Zlib compress, 1.16047 seconds | ||||||||
Attached Files | ![]() | ||||||||
Relationships | ||||||
(0019533) Burlen (developer) 2010-02-15 16:07 edited on: 2010-02-15 16:53 |
Just to clarify: The investigations (https://www.vtk.org/Bug/file/7866/geometry_compression.pdf [^]) showed at most a 2x speed up, and only for very large data and slower networks. If you are going to implement it then there are a couple of things to keep in mind: 1) geometry compression hurts performance on fast networks 2) only makes much of a difference (and at most 2x speedup) on slower networks for very large data 3) for binary floating point data, zlib compression level affects run time drastically, but higher levels don't increase the compression ratio. I noticed that in vtkMPIMoveData the compression level is set by the compile time variable Z_DEFAULT_COMPRESSION, which is typically 6, that will kill any hopes of a speedup. You should always use zlib compression level of 1 on the binary floating point data. Also, if you're going to compress geometry or other binary floating point data during communication you might look at LZO, it's suposed to be faster than zlib. http://www.oberhumer.com/opensource/lzo/ [^] I didn't do any benchmarks with LZO. summary of benchmarks. On this data compression ratios are consistently between 1.5 and 2. localhost connection saw a slow down across the board. The 100MB network saw a speedup between 1.4 and 1.7 across the board. The broadband network saw a speed up which gradually approached 2 starting as geometry size increased passed 10kB. For both slower networks speedup increases with geometry size up to about 10MB where a plateau seems to be reached. |
(0037786) Kitware Robot (administrator) 2016-08-12 09:57 |
2010-02-10 15:55 | Utkarsh Ayachit | New Issue | |
2010-02-10 15:56 | Utkarsh Ayachit | Relationship added | related to 0009409 |
2010-02-10 15:56 | Utkarsh Ayachit | Description Updated | |
2010-02-15 16:07 | Burlen | Note Added: 0019533 | |
2010-02-15 16:07 | Burlen | File Added: geometry_compression.pdf | |
2010-02-15 16:11 | Burlen | Note Edited: 0019533 | |
2010-02-15 16:40 | Burlen | Note Edited: 0019533 | |
2010-02-15 16:46 | Burlen | Note Edited: 0019533 | |
2010-02-15 16:53 | Burlen | Note Edited: 0019533 | |
2010-04-16 01:37 | Utkarsh Ayachit | Priority | immediate => normal |
2010-04-16 01:37 | Utkarsh Ayachit | Target Version | 3.8 => Someday |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037786 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
