0010317 | ParaView | Bug | public | 2010-02-22 15:13 | 2011-01-13 17:00 | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0010317: Cannot save VTK hierarchical box file when running in parallel | ||||||||
Description | When you have an AMR data set loaded in parallel (from, for example, a spyplot file), there does not seem to be a way to save it. The file browser claims that you can save it out in the VTK hierarchical box format, but when you try to do that you get a bunch of errors and nothing is written out. | ||||||||
Additional Information | Note that if all of the data happens to be on node 0 and all other nodes are empty, then the file write works. This, of course, is no use in general. | ||||||||
(0019753) Utkarsh Ayachit (administrator) 2010-03-07 13:57 |
The datastructures were not synced correctly across processes when writing AMR. Fixed that. /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.cxx,v <-- VTK/IO/vtkXMLCompositeDataWriter.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.h,v <-- VTK/IO/vtkXMLCompositeDataWriter.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLHierarchicalBoxDataWriter.cxx,v <-- VTK/IO/vtkXMLHierarchicalBoxDataWriter.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLHierarchicalBoxDataWriter.h,v <-- VTK/IO/vtkXMLHierarchicalBoxDataWriter.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkXMLPHierarchicalBoxDataWriter.cxx,v <-- VTK/Parallel/vtkXMLPHierarchicalBoxDataWriter.cxx new revision: 1.5; previous revision: 1.4 |
(0019824) Alan Scott (manager) 2010-03-10 21:36 |
Tested remote servers, XP, trunk. Used Dave's medium dataset, wrote out vtk format, then read it back in. |
2010-02-22 15:13 | Ken Moreland | New Issue | |
2010-02-22 15:13 | Ken Moreland | Target Version | => 3.8 |
2010-03-04 16:45 | Utkarsh Ayachit | Status | backlog => tabled |
2010-03-04 16:45 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-03-07 13:57 | Utkarsh Ayachit | Note Added: 0019753 | |
2010-03-07 13:57 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-03-07 13:57 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-03-07 13:57 | Utkarsh Ayachit | Resolution | open => fixed |
2010-03-10 21:36 | Alan Scott | Note Added: 0019824 | |
2010-03-10 21:36 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
