0010376 | ParaView | Bug | public | 2010-03-05 15:20 | 2011-09-01 13:31 | ||||
Reporter | Eric Monson | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0010376: Files missing from install development tree | ||||||||
Description | When PARAVIEW_INSTALL_DEVELOPMENT is turned on, and you do a "make install", there are some files missing from the resulting development tree: 1. On both OS X and Ubuntu I've run into pq3DWidgetImplementation.cxx.in and pq3DWidgetImplementation.h.in both being missing from [installRoot]/include/paraview-3.7/Qt/Components/ 2. On Ubuntu where I had FFMPEG installed and VTK_USE_FFMPEG_ENCODER turned on, I got the error: CMake Error at VTK/IO/cmake_install.cmake:40 (FILE): file INSTALL cannot find file "/home/emonson/Programming/ParaView_cvs/ParaView3/VTK/IO/vtkFFMPEGConfig.h" to install. Call Stack (most recent call first): VTK/cmake_install.cmake:180 (INCLUDE) cmake_install.cmake:97 (INCLUDE) So, it was looking for this header file in the source tree rather than the build tree. | ||||||||
(0019903) David Partyka (developer) 2010-03-16 15:40 |
What uses pq3DWidgetImplementation.cxx.in? When I searched through the source to see if I needed an install rule for it I didn't find anything including it or building it. |
(0019904) David Partyka (developer) 2010-03-16 15:41 |
All I see is where it configured and the files themselves. PS C:\Kitware\ParaView3\src> findstr /SN pq3DWidgetImplementation * CMake\ParaViewPlugins.cmake:690: CONFIGURE_FILE(${ParaView_CMAKE_DIR}/pq3DWidgetImplementation.h.in CMake\ParaViewPlugins.cmake:692: CONFIGURE_FILE(${ParaView_CMAKE_DIR}/pq3DWidgetImplementation.cxx.in Qt\Components\pq3DWidgetImplementation.cxx.in:6: Module: $RCSfile: pq3DWidgetImplementation.cxx.in,v $ Qt\Components\pq3DWidgetImplementation.h.in:6: Module: $RCSfile: pq3DWidgetImplementation.h.in,v $ |
(0019905) David Partyka (developer) 2010-03-16 16:08 |
Never Mind about that, I found how it's being used. I'll add an install rule right now. |
(0019906) Eric Monson (reporter) 2010-03-16 16:13 |
I get an error while trying to configure (using cmake) the build of my branded app which includes a plugin that instantiates a new 3d widget CMake Error: File /usr/local/ParaView/include/paraview-3.7/Qt/Components/pq3DWidgetImplementation.h.in does not exist. CMake Error at /usr/local/ParaView/lib/paraview-3.7/CMake/ParaViewPlugins.cmake:690 (CONFIGURE_FILE): configure_file Problem configuring file Call Stack (most recent call first): ClipWSlabWidget4/CMakeLists.txt:30 (ADD_3DWIDGET) The part of the CMakeLists.txt file it's referring to is: ADD_3DWIDGET(IFACES IFACE_SRCS CLASS_NAME pqSlabWidget WIDGET_TYPE SlabWidget ) I can try to track it down deeper if this isn't very illuminating. |
(0019907) David Partyka (developer) 2010-03-16 16:18 |
Okay, I just checked in the install rule for Part 1 of your bug. Give it a shot and let me know. I will see what I can do about part 2 now. |
(0019908) David Partyka (developer) 2010-03-16 16:23 |
Okay both errors should be fixed with these commits: 1.cvs commit -m "BUG: move pq3DWidgetImplementation into the CMake dir and properly install it." /cvsroot/ParaView3/ParaView3/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.141; previous revision: 1.140 2. cvs commit -m "BUG: fix broken install rule for vtkFFMPEGConfig.h." Committer: Dave Partyka <dave.partyka@kitware.com> /cvsroot/ParaView3/ParaView3/VTK/IO/CMakeLists.txt,v <-- VTK/IO/CMakeLists.txt new revision: 1.193; previous revision: 1.192 |
(0019911) Alan Scott (manager) 2010-03-16 17:14 |
Assuming fixed. If it isn't, please re-open this bug. |
2010-03-05 15:20 | Eric Monson | New Issue | |
2010-03-05 15:22 | Utkarsh Ayachit | Status | backlog => tabled |
2010-03-05 15:22 | Utkarsh Ayachit | Assigned To | => David Partyka |
2010-03-16 15:40 | David Partyka | Note Added: 0019903 | |
2010-03-16 15:41 | David Partyka | Note Added: 0019904 | |
2010-03-16 16:08 | David Partyka | Note Added: 0019905 | |
2010-03-16 16:13 | Eric Monson | Note Added: 0019906 | |
2010-03-16 16:18 | David Partyka | Note Added: 0019907 | |
2010-03-16 16:23 | David Partyka | Note Added: 0019908 | |
2010-03-16 16:23 | David Partyka | Status | tabled => @80@ |
2010-03-16 16:23 | David Partyka | Fixed in Version | => Development |
2010-03-16 16:23 | David Partyka | Resolution | open => fixed |
2010-03-16 17:14 | Alan Scott | Note Added: 0019911 | |
2010-03-16 17:14 | Alan Scott | Status | @80@ => closed |
2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
