0010385 | ParaView | Bug | public | 2010-03-08 15:25 | 2011-01-13 17:00 | ||||
Assigned To | Marcus D. Hanwell | ||||||||
Target Version | WhenPossible | Fixed in Version | 3.8 | ||||||
Summary | 0010385: Marks: Top axis labels are incorrectly positioned. | ||||||||
Description | * Plot Over Line * New XY Plot * Open View Settings * Click "Show Axis" for Top Axis. Bugs: - Labels appear under the top axis instead of above it. (Same is true for right axes, labels should appear on the right of the axis). - Labels from bottom axis disappear (and don't reappear even if you turn off top axis). | ||||||||
Relationships | ||||||
(0019762) Utkarsh Ayachit (administrator) 2010-03-08 15:30 |
Looks like the label disappearing happened because of "Log scale for bottom" axes. However the weird behavior is this: * I opened a XY plot, check log scale for bottom axis. * I deleted that view. Created a new one--by default showed up without Log scale for x axis- which is good. But now when I go to view settings, the log-scale option of the bottom axis is already checked (guess it remembered) and hitting "Apply" resulted in changing to log scale without my explicit knowledge. |
(0019822) Marcus D. Hanwell (developer) 2010-03-10 17:48 |
Partial fix in Qt/Components/pqXYChartOptionsEditor.cxx 1.7, for the loading of the log scale property and the refresh of the axes pages. The label positions will be follow. |
(0019847) Marcus D. Hanwell (developer) 2010-03-11 16:52 |
Added some code to position the axis labels correctly, VTK/Charts/vtkAxis.cxx 1.19, I need to do some more work to request the entire chart is laid out again once font metrics determine the appropriate amount of space needed for each axis.. |
(0020697) Marcus D. Hanwell (developer) 2010-05-10 13:33 |
So the major issues here are resolved, with some related issues in the bug I marked this a duplicate of. |
(0020807) Alan Scott (manager) 2010-05-21 14:09 |
I believe that the labels are now correctly positioned, but they are not the same color as other axis. All axis labels should be the same color, unless the user specifically changes them. If you want to resolve this bug, and have me open another bug for color, let me know. Alan |
(0020809) Marcus D. Hanwell (developer) 2010-05-21 14:21 |
Ah, I think I copied the defaults from the old charts. It is a simple change in the XML...commit 45c78c2 contains the change. Please let me know if this is what you wanted. |
(0020888) Alan Scott (manager) 2010-06-01 21:16 |
Tested local server, Windows, trunk. |
2010-03-08 15:25 | Utkarsh Ayachit | New Issue | |
2010-03-08 15:25 | Utkarsh Ayachit | Status | backlog => tabled |
2010-03-08 15:25 | Utkarsh Ayachit | Assigned To | => Marcus D. Hanwell |
2010-03-08 15:30 | Utkarsh Ayachit | Note Added: 0019762 | |
2010-03-08 15:35 | Utkarsh Ayachit | Description Updated | |
2010-03-10 17:48 | Marcus D. Hanwell | Note Added: 0019822 | |
2010-03-11 16:52 | Marcus D. Hanwell | Note Added: 0019847 | |
2010-04-16 01:31 | Utkarsh Ayachit | Target Version | 3.8 => WhenPossible |
2010-05-10 13:32 | Marcus D. Hanwell | Relationship added | duplicate of 0010387 |
2010-05-10 13:33 | Marcus D. Hanwell | Note Added: 0020697 | |
2010-05-10 13:33 | Marcus D. Hanwell | Status | tabled => @80@ |
2010-05-10 13:33 | Marcus D. Hanwell | Fixed in Version | => 3.8 |
2010-05-10 13:33 | Marcus D. Hanwell | Resolution | open => fixed |
2010-05-21 14:09 | Alan Scott | Note Added: 0020807 | |
2010-05-21 14:09 | Alan Scott | Status | @80@ => @20@ |
2010-05-21 14:09 | Alan Scott | Resolution | fixed => reopened |
2010-05-21 14:21 | Marcus D. Hanwell | Note Added: 0020809 | |
2010-05-21 14:21 | Marcus D. Hanwell | Status | @20@ => @80@ |
2010-05-21 14:21 | Marcus D. Hanwell | Resolution | reopened => fixed |
2010-06-01 21:16 | Alan Scott | Note Added: 0020888 | |
2010-06-01 21:16 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
