0010394 | ParaView | Bug | public | 2010-03-09 09:15 | 2010-03-23 21:42 | ||||
Reporter | olesen | ||||||||
Summary | 0010394: Development install tree cannot be used to build plugin. | ||||||||
Description | For the "hard-test" with PARAVIEW_INSTALL_DEVELOPMENT turned on. - make && make install - relocate the built tree somewhere else - rename the source tree to another name (to check if the source tree really isn't needed). After doing this, and setting ParaView_DIR to point to the new location, building a separate plugin still fails, due to the following bits from the plug CMakeLists.txt: FIND_PACKAGE(ParaView REQUIRED) INCLUDE(${PARAVIEW_USE_FILE}) The $ParaView_DIR/ParaViewConfig.cmake is found and it contains references to the now non-existent paraview source directory. If I move $ParaView_DIR/ParaViewConfig.cmake out of the way, the $ParaView_DIR/lib/paraview-3.7/ParaViewConfig.cmake file is correctly found and the build succeeds. | ||||||||
(0019916) David Partyka (developer) 2010-03-16 18:17 |
Can you try this now with a CPack generated install and let me know if there are issues? |
(0019920) olesen (reporter) 2010-03-17 04:51 |
This seems to be solved now - with "make install" and CPack. You can close the issue. |
(0019923) David Partyka (developer) 2010-03-17 08:47 |
As per Mark, it appears that enough fixes have been made that this is no longer an issue. |
(0019992) Alan Scott (manager) 2010-03-23 21:41 |
Closing as per reporter. |
2010-03-09 09:15 | olesen | New Issue | |
2010-03-09 09:18 | David Partyka | Status | backlog => tabled |
2010-03-09 09:18 | David Partyka | Assigned To | => David Partyka |
2010-03-16 18:17 | David Partyka | Note Added: 0019916 | |
2010-03-17 04:51 | olesen | Note Added: 0019920 | |
2010-03-17 08:47 | David Partyka | Note Added: 0019923 | |
2010-03-17 08:47 | David Partyka | Status | tabled => @80@ |
2010-03-17 08:47 | David Partyka | Resolution | open => fixed |
2010-03-23 21:41 | Alan Scott | Note Added: 0019992 | |
2010-03-23 21:41 | Alan Scott | Status | @80@ => closed |
