0010433 | ParaView | Feature | public | 2010-03-17 20:58 | 2016-08-12 09:58 | ||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0010433: Generate cell volume filter | ||||||||
Description | Users have requested the ability to get at the volume of cells. One of the primary uses of this is to calculate density - density = mass (an input var) / cell volume. This needs to work correctly for strange size cells, such as cells around a cylinder. Please create a filter that generates and returns cell volume. | ||||||||
Project | Sandia | ||||||||
Attached Files | ![]() ![]() | ||||||||
Relationships | ||||||
(0023818) Alan Scott (manager) 2010-12-08 15:49 |
Ask me for volume formulas if desired. We have a group that works on these formulas. |
(0025315) Alan Scott (manager) 2011-02-07 12:42 |
From an e-mail from Berk: (This sounds like a very good way to go.) What about this: We add a filter calculate "Calculate Derived Quantities". This can be a replacement for calculator in the long term. On the GUI of this filter, there is a drop-down menu with all of the functions it supports. So if you want to calculate the volume, you do - apply "Calculate Derived Quantities" - choose volume from the drop-down menu * this would add "volume()" in the entry box - apply The only reason I am trying to steer us this way is that it would make everyone's life easier to be able to calculate derived quantities in the same filter. So if you need density, you can: - apply "Calculate Derived Quantities" - choose volume from the drop-down menu * this would add "volume()" in the entry box - edit the entry box to say mass / volume() (assuming that there is an array called mass) - apply We can also do a drop-down that has all the array names if needed. If we had a separate filter for volume, to calculate mass, you'd have to create an additional calculator filter. I am trying to minimize the number of filters people have to create to do something very common. What do you think? |
(0025316) Alan Scott (manager) 2011-02-07 12:44 |
Changing to high priority, since this functionality that is really needed. |
(0025613) Utkarsh Ayachit (administrator) 2011-03-01 11:26 |
Added a panel mockup. If that looks good, we can go ahead with this one. |
(0026455) Alan Scott (manager) 2011-05-06 22:00 |
panel looks ok. I would rather have specific variable names, but this should be used rarely enough that this is OK. |
(0034084) Alan Scott (manager) 2015-01-15 11:13 edited on: 2015-01-15 11:59 |
Lets implement this functionality in the normal GUI calculator. Although this can be done in the Python Calculator, the commands are not trivial or intuitive, and many users don't know Python or use the Python Calculator. This can be done in the Python Calculator, as follows: Python Calculator. Array Association: Cell Data Expression: volume(inputs[0]) Array Name: Cell Volume Apply |
(0034640) Utkarsh Ayachit (administrator) 2015-07-01 08:42 |
Alan, I am not sure how this could be implemented in the normal GUI calculator. How does the user identify which array is the "mass" array. Or do you want to add "cell-volume" as a available operations? Another options, we simply add a new filter named "Cell Volume" that computes cell volume. Then one can apply the calculator to pick the mass and volume arrays to perform the operation? Internally, the "Cell Volume" filter can use Python Calculator. |
(0034641) Utkarsh Ayachit (administrator) 2015-07-01 08:44 edited on: 2015-07-01 08:44 |
Moved to customer review to get feedback. Alan, move back to backlog/todo with your comments please. Thanks! |
(0035147) Alan Scott (manager) 2015-09-02 21:23 |
I changed my mind. Lets do this as presented by Utkarsh. Basically, do it as easily as possible, lets get users using it. If they then want to copy this functionality to an easier tool, we will deal with it then. |
(0035148) Alan Scott (manager) 2015-09-02 21:23 |
Moving to 4.5.. 4.4 is already out of the barn, and I don't want it messed up. |
(0035304) Alan Scott (manager) 2015-10-16 15:05 |
With help from Cory and Utkarsh, here are my notes on python ways to get volume: Python Calculator: Expression: volume(inputs[0]) Array Association: Cell Data Result: cellVolume Programmable filter: Output Data Set Type: Same as Input (default) In the Script entry block, type in the following: from vtk.numpy_interface import algorithms as algs volume = algs.volume(inputs[0]) output.CellData.append(cellVolume, volume) |
(0035820) David C. Lonie (developer) 2016-03-03 11:16 |
Removed my assignment, as this is not an issue I'm currently funded to work on. |
(0037796) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-03-17 20:58 | Alan Scott | New Issue | |
2010-09-01 11:31 | Utkarsh Ayachit | Target Version | 4.0 => 3.10.shortlist |
2010-12-08 15:49 | Alan Scott | Note Added: 0023818 | |
2010-12-08 15:54 | Alan Scott | Relationship added | child of 0011586 |
2011-02-07 12:42 | Alan Scott | Note Added: 0025315 | |
2011-02-07 12:44 | Alan Scott | Note Added: 0025316 | |
2011-02-07 12:44 | Alan Scott | Priority | normal => high |
2011-03-01 11:25 | Utkarsh Ayachit | Target Version | 3.10.shortlist => 3.10.1 |
2011-03-01 11:25 | Utkarsh Ayachit | File Added: DerivedQuantitiesPanel.png | |
2011-03-01 11:26 | Utkarsh Ayachit | Note Added: 0025613 | |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2011-05-06 22:00 | Alan Scott | Note Added: 0026455 | |
2011-09-01 10:56 | Utkarsh Ayachit | Project | => Sandia |
2011-09-02 12:31 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
2011-09-02 12:35 | Utkarsh Ayachit | Status | backlog => todo |
2012-05-31 10:23 | Utkarsh Ayachit | Status | todo => backlog |
2015-01-15 11:13 | Alan Scott | Note Added: 0034084 | |
2015-01-15 11:59 | Alan Scott | Note Edited: 0034084 | |
2015-01-15 12:00 | Alan Scott | Type | => incorrect functionality |
2015-01-15 12:00 | Alan Scott | Target Version | => 4.4 |
2015-07-01 08:42 | Utkarsh Ayachit | Note Added: 0034640 | |
2015-07-01 08:44 | Utkarsh Ayachit | Note Added: 0034641 | |
2015-07-01 08:44 | Utkarsh Ayachit | Status | backlog => customer review |
2015-07-01 08:44 | Utkarsh Ayachit | Resolution | open => suspended |
2015-07-01 08:44 | Utkarsh Ayachit | Assigned To | Sankhesh Jhaveri => David C. Lonie |
2015-07-01 08:44 | Utkarsh Ayachit | Note Edited: 0034641 | |
2015-09-02 21:23 | Alan Scott | Note Added: 0035147 | |
2015-09-02 21:23 | Alan Scott | Note Added: 0035148 | |
2015-09-02 21:24 | Alan Scott | Status | customer review => todo |
2015-09-02 21:24 | Alan Scott | Target Version | 4.4 => 4.5 |
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
2015-10-16 15:05 | Alan Scott | Note Added: 0035304 | |
2016-03-03 11:13 | Utkarsh Ayachit | Status | todo => backlog |
2016-03-03 11:15 | David C. Lonie | Assigned To | David C. Lonie => |
2016-03-03 11:16 | David C. Lonie | Note Added: 0035820 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037796 | |
2016-08-12 09:58 | Kitware Robot | Resolution | suspended => moved |
