0010434 | ParaView | Feature | public | 2010-03-17 21:57 | 2016-07-13 15:29 | ||||
Assigned To | Alan Scott | ||||||||
Summary | 0010434: Integrate variables by volume filter | ||||||||
Description | We need to create a filter that integrates variables by volume of cells, not just adding up the cells. For instance, with AMR data, the integrateVariables filter is useless. Also, we need to document the integrateVariables filter to clarify whether it does so by volume (which I believe it doesn't, or just by adding up each cell (which I believe it does). | ||||||||
(0036406) Alan Scott (manager) 2016-07-13 15:29 |
This bug is a mess. The Integrate variables filter does integrate by cell volume. If you want to not use cell volume, you use the Descriptive Statistics filter. If I have a new user with a problem, I will write up a new bug. |
2010-03-17 21:57 | Alan Scott | New Issue | |
2010-03-17 21:57 | Alan Scott | Target Version | => 4.0 |
2010-09-01 11:31 | Utkarsh Ayachit | Target Version | 4.0 => 3.10.shortlist |
2016-07-13 15:29 | Alan Scott | Note Added: 0036406 | |
2016-07-13 15:29 | Alan Scott | Status | expired => closed |
2016-07-13 15:29 | Alan Scott | Assigned To | => Alan Scott |
2016-07-13 15:29 | Alan Scott | Resolution | open => fixed |
