| 0010462 | ParaView | Bug | public | 2010-03-26 00:28 | 2016-08-12 09:58 | ||||
| Reporter | Takuya OSHIMA | ||||||||
| Assigned To | Kitware Robot | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | Development | ||||||||
| Summary | 0010462: populating/repopulating array selection should not turn the Apply button to green | ||||||||
| Description | The Apply button of the reader panel that has a corresponding info property of a vtkDataArraySelection lights up green when the vtkDataArraySelection is populated/repopulated despite that the modified state of the vtkDataArraySelection remains unchanged, exactly as the comment in vtkDataArraySelection::AddArray() states: // This function is called only by the filter owning the selection. // It should not call Modified() because array settings are not // changed. | ||||||||
| Additional Information | I attach a patch that worked by somewhat emulating the modification state of vtkDataArraySelection in client side. What is unsure to me is if the patch may cause unintended side effects. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0020012) Takuya OSHIMA (reporter) 2010-03-26 00:36 |
Also attached is a test case (cavity.tar.gz). Unpack cavity.tar.gz, open cavity/cavity.foam, step to time 0.2. The one will see Apply lights up green whereas it will not with the attached patch. Disclaimer: The test case is a modified tutorial case that comes with OpenFOAM, which is covered by the GPL. |
(0037799) Kitware Robot (administrator) 2016-08-12 09:58 |
| Notes |
| Issue History | |||
| 2010-03-26 00:28 | Takuya OSHIMA | New Issue | |
| 2010-03-26 00:28 | Takuya OSHIMA | File Added: pqSignalAdaptorSelectionTreeWidget.cxx.diff | |
| 2010-03-26 00:36 | Takuya OSHIMA | File Added: cavity.tar.gz | |
| 2010-03-26 00:36 | Takuya OSHIMA | Note Added: 0020012 | |
| 2016-08-12 09:58 | Kitware Robot | Note Added: 0037799 | |
| 2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:58 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:58 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
