0010479 | ParaView | Bug | public | 2010-03-29 14:08 | 2011-09-01 13:31 | ||||
Target Version | 3.8.1 | Fixed in Version | 3.12 | ||||||
Summary | 0010479: Spreadsheet view: Show selected only doesn't work correctly when selection is changed. | ||||||||
Description | * Create selection in 3D view. * Split - create spreadsheet view * Enable "show selected only" * Change selection in 3D view * The spreadsheet now shows incorrect values. Toggle the "show selected only" option off and and on again and you see the correct values. | ||||||||
(0021341) Utkarsh Ayachit (administrator) 2010-07-09 14:44 |
commit 48dd15ae491e9a8e7ebbdfa781b7696744cb0ec9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Jul 9 14:38:03 2010 -0400 Fixed BUG 0010479. The vtkSMSpreadSheetRepresentationProxy was not firing UpdateDataEvent when selection was changed which was resulting in the pqSpreadSheetViewModel not realizing that the number of rows may have changed. That was causing the issue. This patch also cleans up the code in vtkAttributeDataToTableFilter and vtkTableStreamer by moving the addition of indices to the vtkAttributeDataToTableFilter. This makes it easier to handle the case when the input has cells but no cell data, for example. Needs to move to release branch |
(0021359) Utkarsh Ayachit (administrator) 2010-07-12 13:18 |
commit b9535eaa95b569372786d1ff3ec45ac2d3bb6345 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Jul 12 13:16:46 2010 -0400 Hide vtkOriginalIndices. Fixes dashboard issues following commit: 9afb2ead3e8026be4005e887aecb20c72166a200. |
(0021365) Alan Scott (manager) 2010-07-12 19:37 |
Tested local server, trunk, Windows. |
2010-03-29 14:08 | Utkarsh Ayachit | New Issue | |
2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
2010-07-09 12:54 | Utkarsh Ayachit | Status | backlog => tabled |
2010-07-09 12:54 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-07-09 14:44 | Utkarsh Ayachit | Note Added: 0021341 | |
2010-07-09 14:44 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-07-09 14:44 | Utkarsh Ayachit | Fixed in Version | => Development |
2010-07-09 14:44 | Utkarsh Ayachit | Resolution | open => fixed |
2010-07-12 13:18 | Utkarsh Ayachit | Note Added: 0021359 | |
2010-07-12 19:37 | Alan Scott | Note Added: 0021365 | |
2010-07-12 19:37 | Alan Scott | Status | @80@ => closed |
2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
