0010522 | ParaView | Bug | public | 2010-04-08 09:57 | 2010-04-15 18:06 | ||||
Priority | urgent | Severity | major | Reproducibility | have not tried | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0010522: Existing netCDF reader being overridden by vtkNetCDFPOPReader | ||||||||
Description | I was just alerted to a problem encountered by a user with a recent ParaView CVS build. I discovered that you recently added a new netCDF reader (vtkNetCDFPOPReader) that is overriding the existing netCDF reader that has been around circa PV version 3.4. I’m not sure what the NetCDFPOP reader is supposed to provide that the existing one does. I assume POP stands for some kind of convention, but I cannot figure out which one it is. It also claims to be able to load in any netCDF data, but it does not do a particularly good job on the netCDF files I have. For example, if you try to load the VTKData/Data/tos_O1_2001-2002.nc, it gives nonsensical values for the bounds and misinterprets time as a z dimension. | ||||||||
(0020154) David Partyka (developer) 2010-04-13 11:39 |
I changed the offending readers extension on the Branch and on HEAD. Let me know if that does not solve the issue! |
2010-04-08 09:57 | Ken Moreland | New Issue | |
2010-04-08 09:58 | Ken Moreland | Status | backlog => tabled |
2010-04-08 09:58 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2010-04-08 12:57 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => David Partyka |
2010-04-13 11:39 | David Partyka | Note Added: 0020154 | |
2010-04-13 11:39 | David Partyka | Status | tabled => @80@ |
2010-04-13 11:39 | David Partyka | Fixed in Version | => 3.8 |
2010-04-13 11:39 | David Partyka | Resolution | open => fixed |
2010-04-15 18:06 | Ken Moreland | Status | @80@ => closed |
