0010528 | VTK | (No Category) | public | 2010-04-09 10:11 | 2016-07-07 09:23 | ||||
Reporter | Paul Melis | ||||||||
Assigned To | Andy Bauer | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Target Version | Fixed in Version | 7.1.0 | |||||||
Summary | 0010528: vtkXMLUnstructuredGridWriter segfault | ||||||||
Description | See the attached Python script which loads a polydata .vtp file containing only points and associated scalar arrays. The polydata gets clipped and then saved to a .vtu file, but a segfault occurs. | ||||||||
Steps To Reproduce | Save both files in the sample place, run bug.py | ||||||||
Additional Information | vtk 5.4.2 (gdb) bt #0 0xb6785567 in vtkXMLUnstructuredDataWriter::ConvertCells () from /home/paulm/vtk/lib/vtk-5.4/libvtkIO.so.5.4 #1 0xb6786d56 in vtkXMLUnstructuredDataWriter::WriteCellsInline () from /home/paulm/vtk/lib/vtk-5.4/libvtkIO.so.5.4 #2 0xb678a0e8 in vtkXMLUnstructuredGridWriter::WriteInlinePiece () from /home/paulm/vtk/lib/vtk-5.4/libvtkIO.so.5.4 #3 0xb678710d in vtkXMLUnstructuredDataWriter::WriteInlineMode () from /home/paulm/vtk/lib/vtk-5.4/libvtkIO.so.5.4 #4 0xb678523a in vtkXMLUnstructuredDataWriter::WriteAPiece () from /home/paulm/vtk/lib/vtk-5.4/libvtkIO.so.5.4 #5 0xb6786286 in vtkXMLUnstructuredDataWriter::ProcessRequest () from /home/paulm/vtk/lib/vtk-5.4/libvtkIO.so.5.4 #6 0xb6b51512 in vtkExecutive::CallAlgorithm () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #7 0xb6b48e4d in vtkDemandDrivenPipeline::ExecuteData () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #8 0xb6b4c56b in vtkDemandDrivenPipeline::ProcessRequest () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 0000009 0xb6c5d7ed in vtkStreamingDemandDrivenPipeline::ProcessRequest () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #10 0xb6b4ae3e in vtkDemandDrivenPipeline::UpdateData () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 0000011 0xb6c5d56b in vtkStreamingDemandDrivenPipeline::Update () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #12 0xb6b50b33 in vtkExecutive::Update () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #13 0xb6b496ad in vtkDemandDrivenPipeline::Update () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #14 0xb6c5729d in vtkStreamingDemandDrivenPipeline::Update () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #15 0xb6af0435 in vtkAlgorithm::Update () from /home/paulm/vtk/lib/vtk-5.4/libvtkFiltering.so.5.4 #16 0xb678e9d4 in vtkXMLWriter::Write () from /home/paulm/vtk/lib/vtk-5.4/libvtkIO.so.5.4 #17 0xb69305be in PyvtkXMLWriter_Write () from /home/paulm/vtk/lib/vtk-5.4/libvtkIOPythonD.so.5.4 #18 0x080c9ab3 in PyEval_EvalFrameEx (f=0x817747c, throwflag=0) at ../Python/ceval.c:3573 #19 0x080cb1f7 in PyEval_EvalCodeEx (co=0xb75449f8, globals=0xb7593acc, locals=0xb7593acc, args=0x0, argcount=0, kws=0x0, kwcount=0, defs=0x0, defcount=0, closure=0x0) at ../Python/ceval.c:2836 #20 0x080cb347 in PyEval_EvalCode (co=0xb75449f8, globals=0xb7593acc, locals=0xb7593acc) at ../Python/ceval.c:494 #21 0x080ea818 in PyRun_FileExFlags (fp=0x816b008, filename=0xbfcac33f "./bug.py", start=257, globals=0xb7593acc, locals=0xb7593acc, closeit=1, flags=0xbfcaaa98) at ../Python/pythonrun.c:1273 #22 0x080eaab9 in PyRun_SimpleFileExFlags (fp=0x816b008, filename=0xbfcac33f "./bug.py", closeit=1, flags=0xbfcaaa98) at ../Python/pythonrun.c:879 #23 0x08059335 in Py_Main (argc=1, argv=0xbfcaab64) at ../Modules/main.c:523 #24 0x080587f2 in main (argc=-1232770872, argv=0x2) at ../Modules/python.c:23 | ||||||||
Attached Files | ![]() ![]() | ||||||||
(0020302) David Doria (reporter) 2010-04-20 17:17 |
I tried it in c++ and got the same segfault. Here is the code to reproduce in c++: #include <vtkSmartPointer.h> #include <vtkClipDataSet.h> #include <vtkBox.h> #include <vtkPolyData.h> #include <vtkXMLPolyDataReader.h> #include <vtkXMLUnstructuredGridWriter.h> #include <vtkUnstructuredGrid.h> int main (int argc, char *argv[]) { vtkSmartPointer<vtkXMLPolyDataReader> dr = vtkSmartPointer<vtkXMLPolyDataReader>::New(); dr->SetFileName("doh.vtp"); dr->Update(); vtkSmartPointer<vtkBox> box = vtkSmartPointer<vtkBox>::New(); box->SetBounds(0, 0.65, -0.982, 0.984, -1.03, -0.302); vtkSmartPointer<vtkClipDataSet> clip = vtkSmartPointer<vtkClipDataSet>::New(); clip->SetInputConnection(dr->GetOutputPort()); clip->SetClipFunction(box); clip->Update(); vtkUnstructuredGrid* ug = clip->GetOutput(); cout << ug->GetNumberOfPoints() << endl; vtkSmartPointer<vtkXMLUnstructuredGridWriter> dw = vtkSmartPointer<vtkXMLUnstructuredGridWriter>::New(); dw->SetInputConnection(clip->GetOutputPort()); dw->SetDataModeToAscii(); dw->SetFileName("doh.vtu"); dw->Write(); return EXIT_SUCCESS; } If you comment dw->SetDataModeToAscii(); it does not segfault. |
(0027742) Paul Melis (reporter) 2011-11-29 04:44 |
Still crashes with VTK 5.8.0 |
(0036326) Andy Bauer (developer) 2016-07-07 09:22 |
Fixed in https://gitlab.kitware.com/vtk/vtk/merge_requests/1648#note_135580 [^] |
2010-04-09 10:11 | Paul Melis | New Issue | |
2010-04-09 10:11 | Paul Melis | File Added: bug.py | |
2010-04-09 10:11 | Paul Melis | File Added: doh.vtp | |
2010-04-20 17:17 | David Doria | Note Added: 0020302 | |
2011-11-29 04:44 | Paul Melis | Note Added: 0027742 | |
2016-07-06 17:13 | Andy Bauer | Assigned To | => Andy Bauer |
2016-07-06 17:13 | Andy Bauer | Status | expired => backlog |
2016-07-07 09:22 | Andy Bauer | Note Added: 0036326 | |
2016-07-07 09:22 | Andy Bauer | Status | backlog => closed |
2016-07-07 09:23 | Andy Bauer | Resolution | open => fixed |
2016-07-07 09:23 | Andy Bauer | Fixed in Version | => 7.1.0 |
