0010557 | ParaView | Bug | public | 2010-04-15 14:31 | 2016-08-12 09:58 | ||||
Assigned To | Robert Maynard | ||||||||
Summary | 0010557: Structured volume rendering broken on tiled displays | ||||||||
Description | (From Liu Ning on the ParaView mailing list.) There seems to be a problem with the volume rendering of image data on tiled displays. When rendering on two nodes and two tiles, each tile has half the data (presumably the local half). | ||||||||
Attached Files | ![]() ![]() ![]() ![]() ![]() ![]() | ||||||||
(0020194) Ken Moreland (manager) 2010-04-15 14:33 |
My guess is that the problem is with the representation proxy responsible for volume rendering image data. The problem appears to be independent of the image data volume renderer (see the attached images of the Wavelet rendering with two different mappers, both of which are broken). When you render, for example, an unstructured grid (such as in the attached image of box.ex2), it renders fine. |
(0020482) Utkarsh Ayachit (administrator) 2010-04-29 15:45 |
The problem is because the by default paraview does not use compositing on tile-displays for small data. We support movement of polydata/unstructured grid, so they are happily cloned on all tile machines and hence volume rendering works. But with image data, we don't move the data around and hence the volume rendering looks broken. Setting "Compositing Threshold" to 0 under the Tile Display Parameters does the trick. However this is a nuisance. As a fix, the tile display view should automatically detect if volume rendering is being used and force a compositing mode. |
(0037810) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-04-15 14:31 | Ken Moreland | New Issue | |
2010-04-15 14:31 | Ken Moreland | File Added: Wavelet-FixedPointMapper.jpg | |
2010-04-15 14:31 | Ken Moreland | File Added: Wavelet-GPUMapper.jpg | |
2010-04-15 14:31 | Ken Moreland | File Added: box_ex2.jpg | |
2010-04-15 14:33 | Ken Moreland | Note Added: 0020194 | |
2010-04-29 15:45 | Utkarsh Ayachit | Note Added: 0020482 | |
2010-04-30 14:30 | Utkarsh Ayachit | Status | backlog => tabled |
2010-04-30 14:30 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
2010-04-30 14:30 | Utkarsh Ayachit | Target Version | => 3.10 |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037810 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
