0010576 | ParaView | Bug | public | 2010-04-19 13:29 | 2010-04-20 16:46 | ||||
Assigned To | Marcus D. Hanwell | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0010576: 2d plots Y axis data is bad | ||||||||
Description | I believe this is a show stopper for 3.8. * ParaView 3.8.0 (about a week old), Linux, local server. * Open Can.exo. All vars on, apply. * Select point - any point on the bottom of the bottom plate. * Plot selection over time. <Bug> The biggest selected value will be ACCL (by far). Notice the numbers on the Y axis. For me, they go (from the bottom) 0, 500000, 1e+06, 1.5e+06, 2e+06, 3e-06, 3.5e-06, 4e-04. First bug - exponents should all be positive. Second bug - the 4 of 4e-06 looks like a 1. | ||||||||
(0020262) Marcus D. Hanwell (developer) 2010-04-19 14:24 |
I cannot reproduce this issue here, but it may be related to another issue I fixed last week. I did quite a bit of work refactoring the axis label generation code. Here I selected global ID 7728 on bottom plate, followed your steps. I get 0, 1e+06, 2e+06 up to 6e+06 on the y axis. This is on Linux with a build from Friday I believe. I am currently rebuilding ParaView on my much slower Windows machine, and will double check there once it is done rebuilding. |
(0020287) Alan Scott (manager) 2010-04-20 16:46 |
Tested local server, Windows, trunk. |
2010-04-19 13:29 | Alan Scott | New Issue | |
2010-04-19 13:30 | Utkarsh Ayachit | Status | backlog => tabled |
2010-04-19 13:30 | Utkarsh Ayachit | Assigned To | => Marcus D. Hanwell |
2010-04-19 14:24 | Marcus D. Hanwell | Note Added: 0020262 | |
2010-04-19 14:27 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-04-19 14:27 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2010-04-20 16:46 | Alan Scott | Note Added: 0020287 | |
2010-04-20 16:46 | Alan Scott | Status | @80@ => closed |
