0010642 | ParaView | Feature | public | 2010-04-29 11:41 | 2016-08-12 09:58 | ||||
Reporter | Paul Edwards | ||||||||
Summary | 0010642: Enumeration values in lists for Python | ||||||||
Description | Example XML: <IntVectorProperty name="Items" command="AddItems" clean_command="RemoveAllItems" repeat_command="1" number_of_elements_per_command="1"> <EnumerationDomain name="array_list"> <Entry value="1" text="item 1"/> <Entry value="2" text="item 2"/> <Entry value="3" text="item 3"/> </EnumerationDomain> </IntVectorProperty> It would be desirable to set the items in python by their name - currently it is necessary to call: filter.Items = [1,2] rather than: filter.items = ['item 1', 'item 2'] | ||||||||
(0037818) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-04-29 11:41 | Paul Edwards | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037818 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
