For another project, please consult its home page to locate the current issue tracker.
0010643 | ParaView | Feature | public | 2010-04-29 11:43 | 2014-09-24 10:13 | ||||
Reporter | Paul Edwards | ||||||||
Summary | 0010643: Change font in chart legend | ||||||||
Description | This is not possible - only the title font and axes. | ||||||||
Project | TBD | ||||||||
Topic Name | 10643_chart_legend_properties | ||||||||
Attached Files | ![]() diff --git a/ParaViewCore/ClientServerCore/vtkPVXYChartView.cxx b/ParaViewCore/ClientServerCore/vtkPVXYChartView.cxx index e929a7b..6c8fd42 100644 --- a/ParaViewCore/ClientServerCore/vtkPVXYChartView.cxx +++ b/ParaViewCore/ClientServerCore/vtkPVXYChartView.cxx @@ -165,6 +165,19 @@ void vtkPVXYChartView::SetTitleAlignment(int alignment) } //---------------------------------------------------------------------------- +void vtkPVXYChartView::SetLegendFont(const char* family, int pointSize, + bool bold, bool italic) +{ + if (this->Chart && this->Chart->GetLegend()) + { + this->Chart->GetLegend()->GetLabelProperties()->SetFontFamilyAsString(family); + this->Chart->GetLegend()->GetLabelProperties()->SetFontSize(pointSize); + this->Chart->GetLegend()->GetLabelProperties()->SetBold(static_cast<int>(bold)); + this->Chart->GetLegend()->GetLabelProperties()->SetItalic(static_cast<int>(italic)); + } +} + +//---------------------------------------------------------------------------- void vtkPVXYChartView::SetLegendVisibility(int visible) { if (this->Chart) diff --git a/ParaViewCore/ClientServerCore/vtkPVXYChartView.h b/ParaViewCore/ClientServerCore/vtkPVXYChartView.h index c43d8b8..0121b4f 100644 --- a/ParaViewCore/ClientServerCore/vtkPVXYChartView.h +++ b/ParaViewCore/ClientServerCore/vtkPVXYChartView.h @@ -66,6 +66,13 @@ public: void SetTitleAlignment(int alignment); // Description: + // Set the chart legend font. + // These methods should not be called directly. They are made public only so + // that the client-server-stream-interpreter can invoke them. Use the + // corresponding properties to change these values. + void SetLegendFont(const char* family, int pointSize, bool bold, bool italic); + + // Description: // Set the legend visibility. // These methods should not be called directly. They are made public only so // that the client-server-stream-interpreter can invoke them. Use the diff --git a/ParaViewCore/ServerImplementation/Resources/views_and_representations.xml b/ParaViewCore/ServerImplementation/Resources/views_and_representations.xml index a32bb0e..5c3297b 100644 --- a/ParaViewCore/ServerImplementation/Resources/views_and_representations.xml +++ b/ParaViewCore/ServerImplementation/Resources/views_and_representations.xml @@ -671,6 +671,18 @@ <BooleanDomain name="bool" /> </IntVectorProperty> + <StringVectorProperty + name="LegendFont" + command="SetLegendFont" + number_of_elements="4" + element_types="2 0 0 0" + default_values_delimiter=";" + default_values="Arial;14;0;0" > + <Documentation> + Set the chart title font (familyname, size, bold, italics). + </Documentation> + </StringVectorProperty> + <IntVectorProperty name="LegendLocation" command="SetLegendLocation" diff --git a/Qt/Components/Resources/UI/pqChartOptionsWidget.ui b/Qt/Components/Resources/UI/pqChartOptionsWidget.ui index 9e72f5c..d4f6268 100644 --- a/Qt/Components/Resources/UI/pqChartOptionsWidget.ui +++ b/Qt/Components/Resources/UI/pqChartOptionsWidget.ui @@ -1,93 +1,54 @@ -<ui version="4.0" > +<?xml version="1.0" encoding="UTF-8"?> +<ui version="4.0"> <class>pqChartOptionsWidget</class> - <widget class="QWidget" name="pqChartOptionsWidget" > - <property name="geometry" > + <widget class="QWidget" name="pqChartOptionsWidget"> + <property name="geometry"> <rect> <x>0</x> <y>0</y> - <width>346</width> - <height>323</height> + <width>345</width> + <height>369</height> </rect> </property> - <property name="windowTitle" > + <property name="windowTitle"> <string>Chart Options</string> </property> - <layout class="QVBoxLayout" > - <property name="spacing" > - <number>6</number> - </property> - <property name="leftMargin" > - <number>9</number> - </property> - <property name="topMargin" > - <number>9</number> - </property> - <property name="rightMargin" > - <number>9</number> - </property> - <property name="bottomMargin" > - <number>9</number> - </property> - <item> - <widget class="QStackedWidget" name="ChartPages" > - <property name="currentIndex" > + <layout class="QGridLayout" name="gridLayout"> + <item row="0" column="0"> + <widget class="QStackedWidget" name="ChartPages"> + <property name="currentIndex"> <number>0</number> </property> - <widget class="QWidget" name="General" > - <layout class="QGridLayout" > - <property name="leftMargin" > + <widget class="QWidget" name="General"> + <layout class="QGridLayout"> + <property name="margin"> <number>0</number> </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > - <number>0</number> - </property> - <property name="horizontalSpacing" > - <number>6</number> - </property> - <property name="verticalSpacing" > + <property name="spacing"> <number>6</number> </property> - <item row="9" column="3" > - <spacer> - <property name="orientation" > - <enum>Qt::Horizontal</enum> - </property> - <property name="sizeHint" > - <size> - <width>0</width> - <height>20</height> - </size> - </property> - </spacer> - </item> - <item row="10" column="0" colspan="4" > - <spacer> - <property name="orientation" > - <enum>Qt::Vertical</enum> + <item row="0" column="0" colspan="4"> + <widget class="QLabel" name="label"> + <property name="font"> + <font> + <weight>75</weight> + <bold>true</bold> + </font> </property> - <property name="sizeHint" > - <size> - <width>20</width> - <height>0</height> - </size> + <property name="text"> + <string>Chart Title</string> </property> - </spacer> + </widget> </item> - <item rowspan="3" row="7" column="0" > + <item row="1" column="0" rowspan="4"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeType" > + <property name="sizeType"> <enum>QSizePolicy::Fixed</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>16</width> <height>20</height> @@ -95,233 +56,237 @@ </property> </spacer> </item> - <item rowspan="4" row="1" column="0" > - <spacer> - <property name="orientation" > - <enum>Qt::Horizontal</enum> - </property> - <property name="sizeType" > - <enum>QSizePolicy::Fixed</enum> + <item row="1" column="1"> + <widget class="QLabel" name="label_2"> + <property name="text"> + <string>Text</string> </property> - <property name="sizeHint" > - <size> - <width>16</width> - <height>20</height> - </size> + </widget> + </item> + <item row="1" column="2" colspan="2"> + <widget class="QLineEdit" name="ChartTitle"/> + </item> + <item row="2" column="2"> + <widget class="QLabel" name="label_17"> + <property name="text"> + <string><html><head><meta name="qrichtext" content="1" /><style type="text/css"> +p, li { white-space: pre-wrap; } +</style></head><body style=" font-family:'Helvetica'; font-size:9pt; font-weight:400; font-style:normal;"> +<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;">Use <span style=" font-weight:600;">${TIME}</span> to display current time.</p></body></html></string> </property> - </spacer> + </widget> </item> - <item row="3" column="1" > - <widget class="QLabel" name="label_3" > - <property name="text" > + <item row="3" column="1"> + <widget class="QLabel" name="label_3"> + <property name="text"> <string>Font</string> </property> </widget> </item> - <item row="3" column="2" colspan="2" > - <layout class="QHBoxLayout" > - <property name="spacing" > + <item row="3" column="2" colspan="2"> + <layout class="QHBoxLayout"> + <property name="spacing"> <number>6</number> </property> - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > + <property name="margin"> <number>0</number> </property> <item> - <widget class="QLabel" name="ChartTitleFont" > - <property name="sizePolicy" > - <sizepolicy vsizetype="Preferred" hsizetype="Expanding" > + <widget class="QLabel" name="ChartTitleFont"> + <property name="sizePolicy"> + <sizepolicy hsizetype="Expanding" vsizetype="Preferred"> <horstretch>0</horstretch> <verstretch>0</verstretch> </sizepolicy> </property> - <property name="text" > + <property name="text"> <string>Description</string> </property> </widget> </item> <item> - <widget class="QPushButton" name="ChartTitleFontButton" > - <property name="text" > + <widget class="QPushButton" name="ChartTitleFontButton"> + <property name="text"> <string>Set &Font</string> </property> </widget> </item> </layout> </item> - <item row="1" column="2" colspan="2" > - <widget class="QLineEdit" name="ChartTitle" /> - </item> - <item row="1" column="1" > - <widget class="QLabel" name="label_2" > - <property name="text" > - <string>Text</string> + <item row="4" column="1"> + <widget class="QLabel" name="label_4"> + <property name="text"> + <string>Alignment</string> </property> </widget> </item> - <item row="0" column="0" colspan="4" > - <widget class="QLabel" name="label" > - <property name="font" > - <font> - <weight>75</weight> - <bold>true</bold> - </font> + <item row="4" column="2"> + <widget class="QComboBox" name="ChartTitleAlignment"> + <item> + <property name="text"> + <string>Left</string> + </property> + </item> + <item> + <property name="text"> + <string>Center</string> + </property> + </item> + <item> + <property name="text"> + <string>Right</string> + </property> + </item> + </widget> + </item> + <item row="4" column="3"> + <spacer> + <property name="orientation"> + <enum>Qt::Horizontal</enum> </property> - <property name="text" > - <string>Chart Title</string> + <property name="sizeHint" stdset="0"> + <size> + <width>0</width> + <height>20</height> + </size> + </property> + </spacer> + </item> + <item row="5" column="1"> + <widget class="QLabel" name="label_8"> + <property name="text"> + <string>Color</string> </property> </widget> </item> - <item row="6" column="0" colspan="4" > - <widget class="QLabel" name="label_5" > - <property name="font" > + <item row="5" column="2" colspan="2"> + <layout class="QHBoxLayout"> + <property name="spacing"> + <number>0</number> + </property> + <property name="margin"> + <number>0</number> + </property> + <item> + <widget class="pqColorChooserButton" name="ChartTitleColor"> + <property name="text"> + <string>Set Co&lor</string> + </property> + </widget> + </item> + <item> + <spacer> + <property name="orientation"> + <enum>Qt::Horizontal</enum> + </property> + <property name="sizeHint" stdset="0"> + <size> + <width>0</width> + <height>20</height> + </size> + </property> + </spacer> + </item> + </layout> + </item> + <item row="6" column="0" colspan="4"> + <widget class="QLabel" name="label_5"> + <property name="font"> <font> <weight>75</weight> <bold>true</bold> </font> </property> - <property name="text" > + <property name="text"> <string>Chart Legend</string> </property> </widget> </item> - <item row="7" column="1" colspan="3" > - <widget class="QCheckBox" name="ShowLegend" > - <property name="text" > - <string>Show the Chart Legend When Available</string> + <item row="7" column="0" rowspan="5"> + <spacer> + <property name="orientation"> + <enum>Qt::Horizontal</enum> </property> - </widget> + <property name="sizeType"> + <enum>QSizePolicy::Fixed</enum> + </property> + <property name="sizeHint" stdset="0"> + <size> + <width>16</width> + <height>20</height> + </size> + </property> + </spacer> </item> - <item row="8" column="1" > - <widget class="QLabel" name="label_6" > - <property name="text" > - <string>Location</string> + <item row="7" column="1" colspan="3"> + <widget class="QCheckBox" name="ShowLegend"> + <property name="text"> + <string>Show the Chart Legend When Available</string> </property> </widget> </item> - <item row="9" column="1" > - <widget class="QLabel" name="label_7" > - <property name="text" > - <string>Flow</string> + <item row="10" column="1"> + <widget class="QLabel" name="label_6"> + <property name="text"> + <string>Location</string> </property> </widget> </item> - <item row="8" column="2" > - <widget class="QComboBox" name="LegendLocation" > + <item row="10" column="2"> + <widget class="QComboBox" name="LegendLocation"> <item> - <property name="text" > + <property name="text"> <string>Top-left (inline)</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Top-right (inline)</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Bottom-right (inline)</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Bottom-left (inline)</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Left</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Top</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Right</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Bottom</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Custom</string> </property> </item> </widget> </item> - <item row="9" column="2" > - <widget class="QComboBox" name="LegendFlow" > - <item> - <property name="text" > - <string>Left to Right</string> - </property> - </item> - <item> - <property name="text" > - <string>Top to Bottom</string> - </property> - </item> - </widget> - </item> - <item row="5" column="2" colspan="2" > - <layout class="QHBoxLayout" > - <property name="spacing" > - <number>0</number> - </property> - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > - <number>0</number> - </property> - <item> - <widget class="pqColorChooserButton" name="ChartTitleColor" > - <property name="text" > - <string>Set Co&lor</string> - </property> - </widget> - </item> - <item> - <spacer> - <property name="orientation" > - <enum>Qt::Horizontal</enum> - </property> - <property name="sizeHint" > - <size> - <width>0</width> - <height>20</height> - </size> - </property> - </spacer> - </item> - </layout> - </item> - <item row="8" column="3" > + <item row="10" column="3"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -329,45 +294,33 @@ </property> </spacer> </item> - <item row="5" column="1" > - <widget class="QLabel" name="label_8" > - <property name="text" > - <string>Color</string> - </property> - </widget> - </item> - <item row="4" column="1" > - <widget class="QLabel" name="label_4" > - <property name="text" > - <string>Alignment</string> + <item row="11" column="1"> + <widget class="QLabel" name="label_7"> + <property name="text"> + <string>Flow</string> </property> </widget> </item> - <item row="4" column="2" > - <widget class="QComboBox" name="ChartTitleAlignment" > - <item> - <property name="text" > - <string>Left</string> - </property> - </item> + <item row="11" column="2"> + <widget class="QComboBox" name="LegendFlow"> <item> - <property name="text" > - <string>Center</string> + <property name="text"> + <string>Left to Right</string> </property> </item> <item> - <property name="text" > - <string>Right</string> + <property name="text"> + <string>Top to Bottom</string> </property> </item> </widget> </item> - <item row="4" column="3" > + <item row="11" column="3"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -375,44 +328,72 @@ </property> </spacer> </item> - <item row="2" column="2" > - <widget class="QLabel" name="label_17" > - <property name="text" > - <string><html><head><meta name="qrichtext" content="1" /><style type="text/css"> -p, li { white-space: pre-wrap; } -</style></head><body style=" font-family:'Helvetica'; font-size:9pt; font-weight:400; font-style:normal;"> -<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;">Use <span style=" font-weight:600;">${TIME}</span> to display current time.</p></body></html></string> + <item row="12" column="0" colspan="4"> + <spacer> + <property name="orientation"> + <enum>Qt::Vertical</enum> + </property> + <property name="sizeHint" stdset="0"> + <size> + <width>20</width> + <height>0</height> + </size> + </property> + </spacer> + </item> + <item row="8" column="1"> + <widget class="QLabel" name="label_27"> + <property name="text"> + <string>Font</string> </property> </widget> </item> + <item row="8" column="2" colspan="2"> + <layout class="QHBoxLayout" name="_2"> + <property name="spacing"> + <number>6</number> + </property> + <property name="margin"> + <number>0</number> + </property> + <item> + <widget class="QLabel" name="ChartLegendFont"> + <property name="sizePolicy"> + <sizepolicy hsizetype="Expanding" vsizetype="Preferred"> + <horstretch>0</horstretch> + <verstretch>0</verstretch> + </sizepolicy> + </property> + <property name="text"> + <string>Description</string> + </property> + </widget> + </item> + <item> + <widget class="QPushButton" name="ChartLegendFontButton"> + <property name="text"> + <string>Set &Font</string> + </property> + </widget> + </item> + </layout> + </item> </layout> </widget> - <widget class="QWidget" name="Axis" > - <layout class="QGridLayout" > - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > + <widget class="QWidget" name="Axis"> + <layout class="QGridLayout"> + <property name="margin"> <number>0</number> </property> - <property name="horizontalSpacing" > + <property name="spacing"> <number>6</number> </property> - <property name="verticalSpacing" > - <number>6</number> - </property> - <item row="10" column="3" > + <item row="10" column="3"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -420,12 +401,12 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="9" column="3" > + <item row="9" column="3"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -433,12 +414,12 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="3" column="3" > + <item row="3" column="3"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -446,12 +427,12 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="11" column="0" colspan="4" > + <item row="11" column="0" colspan="4"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Vertical</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>20</width> <height>0</height> @@ -459,15 +440,15 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item rowspan="5" row="6" column="0" > + <item row="6" column="0" rowspan="5"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeType" > + <property name="sizeType"> <enum>QSizePolicy::Fixed</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>16</width> <height>20</height> @@ -475,15 +456,15 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item rowspan="4" row="1" column="0" > + <item row="1" column="0" rowspan="4"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeType" > + <property name="sizeType"> <enum>QSizePolicy::Fixed</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>16</width> <height>20</height> @@ -491,81 +472,72 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="9" column="2" > - <widget class="QComboBox" name="LabelNotation" > + <item row="9" column="2"> + <widget class="QComboBox" name="LabelNotation"> <item> - <property name="text" > + <property name="text"> <string>Standard</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Exponential</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Engineering</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Mixed</string> </property> </item> </widget> </item> - <item row="10" column="2" > - <widget class="QSpinBox" name="LabelPrecision" > - <property name="maximum" > + <item row="10" column="2"> + <widget class="QSpinBox" name="LabelPrecision"> + <property name="maximum"> <number>6</number> </property> </widget> </item> - <item row="10" column="1" > - <widget class="QLabel" name="label_24" > - <property name="text" > + <item row="10" column="1"> + <widget class="QLabel" name="label_24"> + <property name="text"> <string>Precision</string> </property> </widget> </item> - <item row="9" column="1" > - <widget class="QLabel" name="label_23" > - <property name="text" > + <item row="9" column="1"> + <widget class="QLabel" name="label_23"> + <property name="text"> <string>Notation</string> </property> </widget> </item> - <item row="8" column="2" colspan="2" > - <layout class="QHBoxLayout" > - <property name="spacing" > - <number>0</number> - </property> - <property name="leftMargin" > + <item row="8" column="2" colspan="2"> + <layout class="QHBoxLayout"> + <property name="spacing"> <number>0</number> </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > + <property name="margin"> <number>0</number> </property> <item> - <widget class="pqColorChooserButton" name="LabelColor" > - <property name="text" > + <widget class="pqColorChooserButton" name="LabelColor"> + <property name="text"> <string>&Label Color</string> </property> </widget> </item> <item> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -575,130 +547,112 @@ p, li { white-space: pre-wrap; } </item> </layout> </item> - <item row="8" column="1" > - <widget class="QLabel" name="label_22" > - <property name="text" > + <item row="8" column="1"> + <widget class="QLabel" name="label_22"> + <property name="text"> <string>Color</string> </property> </widget> </item> - <item row="7" column="1" > - <widget class="QLabel" name="label_21" > - <property name="text" > + <item row="7" column="1"> + <widget class="QLabel" name="label_21"> + <property name="text"> <string>Font</string> </property> </widget> </item> - <item row="6" column="1" colspan="3" > - <widget class="QCheckBox" name="ShowAxisLabels" > - <property name="text" > + <item row="6" column="1" colspan="3"> + <widget class="QCheckBox" name="ShowAxisLabels"> + <property name="text"> <string>Show Axis Labels When Space is Available</string> </property> </widget> </item> - <item row="7" column="2" colspan="2" > - <layout class="QHBoxLayout" > - <property name="spacing" > + <item row="7" column="2" colspan="2"> + <layout class="QHBoxLayout"> + <property name="spacing"> <number>6</number> </property> - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > + <property name="margin"> <number>0</number> </property> <item> - <widget class="QLabel" name="AxisLabelFont" > - <property name="sizePolicy" > - <sizepolicy vsizetype="Preferred" hsizetype="Expanding" > + <widget class="QLabel" name="AxisLabelFont"> + <property name="sizePolicy"> + <sizepolicy hsizetype="Expanding" vsizetype="Preferred"> <horstretch>0</horstretch> <verstretch>0</verstretch> </sizepolicy> </property> - <property name="text" > + <property name="text"> <string>Description</string> </property> </widget> </item> <item> - <widget class="QPushButton" name="AxisLabelFontButton" > - <property name="text" > + <widget class="QPushButton" name="AxisLabelFontButton"> + <property name="text"> <string>Set &Font</string> </property> </widget> </item> </layout> </item> - <item row="5" column="0" colspan="4" > - <widget class="QLabel" name="label_20" > - <property name="font" > + <item row="5" column="0" colspan="4"> + <widget class="QLabel" name="label_20"> + <property name="font"> <font> <weight>75</weight> <bold>true</bold> </font> </property> - <property name="text" > + <property name="text"> <string>Axis Labels</string> </property> </widget> </item> - <item row="1" column="1" colspan="3" > - <widget class="QCheckBox" name="ShowAxis" > - <property name="text" > + <item row="1" column="1" colspan="3"> + <widget class="QCheckBox" name="ShowAxis"> + <property name="text"> <string>Show Axis</string> </property> </widget> </item> - <item row="4" column="1" > - <widget class="QLabel" name="label_19" > - <property name="text" > + <item row="4" column="1"> + <widget class="QLabel" name="label_19"> + <property name="text"> <string>Colors</string> </property> </widget> </item> - <item row="4" column="2" colspan="2" > - <layout class="QHBoxLayout" > - <property name="spacing" > + <item row="4" column="2" colspan="2"> + <layout class="QHBoxLayout"> + <property name="spacing"> <number>6</number> </property> - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > + <property name="margin"> <number>0</number> </property> <item> - <widget class="pqColorChooserButton" name="AxisColor" > - <property name="text" > + <widget class="pqColorChooserButton" name="AxisColor"> + <property name="text"> <string>A&xis Color</string> </property> </widget> </item> <item> - <widget class="pqColorChooserButton" name="GridColor" > - <property name="text" > + <widget class="pqColorChooserButton" name="GridColor"> + <property name="text"> <string>&Grid Color</string> </property> </widget> </item> <item> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -708,78 +662,66 @@ p, li { white-space: pre-wrap; } </item> </layout> </item> - <item row="3" column="1" > - <widget class="QLabel" name="label_18" > - <property name="text" > + <item row="3" column="1"> + <widget class="QLabel" name="label_18"> + <property name="text"> <string>Grid Color</string> </property> </widget> </item> - <item row="3" column="2" > - <widget class="QComboBox" name="GridType" > + <item row="3" column="2"> + <widget class="QComboBox" name="GridType"> <item> - <property name="text" > + <property name="text"> <string>Lighter</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Specified</string> </property> </item> </widget> </item> - <item row="2" column="1" colspan="3" > - <widget class="QCheckBox" name="ShowAxisGrid" > - <property name="text" > + <item row="2" column="1" colspan="3"> + <widget class="QCheckBox" name="ShowAxisGrid"> + <property name="text"> <string>Show Axis Grid</string> </property> </widget> </item> - <item row="0" column="0" colspan="4" > - <widget class="QLabel" name="AxisGeneralLabel" > - <property name="font" > + <item row="0" column="0" colspan="4"> + <widget class="QLabel" name="AxisGeneralLabel"> + <property name="font"> <font> <weight>75</weight> <bold>true</bold> </font> </property> - <property name="text" > + <property name="text"> <string>General</string> </property> </widget> </item> </layout> </widget> - <widget class="QWidget" name="AxisLayout" > - <layout class="QGridLayout" > - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > + <widget class="QWidget" name="AxisLayout"> + <layout class="QGridLayout"> + <property name="margin"> <number>0</number> </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > - <number>0</number> - </property> - <property name="horizontalSpacing" > + <property name="spacing"> <number>6</number> </property> - <property name="verticalSpacing" > - <number>6</number> - </property> - <item rowspan="5" row="1" column="0" > + <item row="1" column="0" rowspan="5"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeType" > + <property name="sizeType"> <enum>QSizePolicy::Fixed</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>16</width> <height>20</height> @@ -787,51 +729,39 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="5" column="1" > - <widget class="QStackedWidget" name="AxisLayoutPages" > - <property name="sizePolicy" > - <sizepolicy vsizetype="Expanding" hsizetype="Expanding" > + <item row="5" column="1"> + <widget class="QStackedWidget" name="AxisLayoutPages"> + <property name="sizePolicy"> + <sizepolicy hsizetype="Expanding" vsizetype="Expanding"> <horstretch>0</horstretch> <verstretch>0</verstretch> </sizepolicy> </property> - <property name="currentIndex" > + <property name="currentIndex"> <number>2</number> </property> - <widget class="QWidget" name="BlankPage" > - <property name="sizePolicy" > - <sizepolicy vsizetype="Expanding" hsizetype="Expanding" > + <widget class="QWidget" name="BlankPage"> + <property name="sizePolicy"> + <sizepolicy hsizetype="Expanding" vsizetype="Expanding"> <horstretch>0</horstretch> <verstretch>0</verstretch> </sizepolicy> </property> </widget> - <widget class="QWidget" name="RangePage" > - <layout class="QGridLayout" > - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > + <widget class="QWidget" name="RangePage"> + <layout class="QGridLayout"> + <property name="margin"> <number>0</number> </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > - <number>0</number> - </property> - <property name="horizontalSpacing" > + <property name="spacing"> <number>6</number> </property> - <property name="verticalSpacing" > - <number>6</number> - </property> - <item row="2" column="0" colspan="2" > + <item row="2" column="0" colspan="2"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Vertical</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>20</width> <height>0</height> @@ -839,54 +769,42 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="1" column="1" > - <widget class="QLineEdit" name="AxisMaximum" /> + <item row="1" column="1"> + <widget class="QLineEdit" name="AxisMaximum"/> </item> - <item row="0" column="1" > - <widget class="QLineEdit" name="AxisMinimum" /> + <item row="0" column="1"> + <widget class="QLineEdit" name="AxisMinimum"/> </item> - <item row="1" column="0" > - <widget class="QLabel" name="label_16" > - <property name="text" > + <item row="1" column="0"> + <widget class="QLabel" name="label_16"> + <property name="text"> <string>Maximum</string> </property> </widget> </item> - <item row="0" column="0" > - <widget class="QLabel" name="label_15" > - <property name="text" > + <item row="0" column="0"> + <widget class="QLabel" name="label_15"> + <property name="text"> <string>Minimum</string> </property> </widget> </item> </layout> </widget> - <widget class="QWidget" name="ListPage" > - <layout class="QGridLayout" > - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > + <widget class="QWidget" name="ListPage"> + <layout class="QGridLayout"> + <property name="margin"> <number>0</number> </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > - <number>0</number> - </property> - <property name="horizontalSpacing" > - <number>6</number> - </property> - <property name="verticalSpacing" > + <property name="spacing"> <number>6</number> </property> - <item row="3" column="1" > + <item row="3" column="1"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Vertical</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>20</width> <height>0</height> @@ -894,33 +812,33 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="2" column="1" > - <widget class="QPushButton" name="GenerateButton" > - <property name="text" > + <item row="2" column="1"> + <widget class="QPushButton" name="GenerateButton"> + <property name="text"> <string>&Generate</string> </property> </widget> </item> - <item row="1" column="1" > - <widget class="QPushButton" name="RemoveButton" > - <property name="text" > + <item row="1" column="1"> + <widget class="QPushButton" name="RemoveButton"> + <property name="text"> <string>&Delete</string> </property> </widget> </item> - <item row="0" column="1" > - <widget class="QPushButton" name="AddButton" > - <property name="text" > + <item row="0" column="1"> + <widget class="QPushButton" name="AddButton"> + <property name="text"> <string>&New Label</string> </property> </widget> </item> - <item rowspan="4" row="0" column="0" > - <widget class="QListView" name="LabelList" > - <property name="editTriggers" > - <set>QAbstractItemView::EditKeyPressed|QAbstractItemView::NoEditTriggers|QAbstractItemView::SelectedClicked</set> + <item row="0" column="0" rowspan="4"> + <widget class="QListView" name="LabelList"> + <property name="editTriggers"> + <set>QAbstractItemView::EditKeyPressed|QAbstractItemView::SelectedClicked</set> </property> - <property name="selectionMode" > + <property name="selectionMode"> <enum>QAbstractItemView::ExtendedSelection</enum> </property> </widget> @@ -929,87 +847,75 @@ p, li { white-space: pre-wrap; } </widget> </widget> </item> - <item row="2" column="1" > - <widget class="QRadioButton" name="UseChartSelect" > - <property name="whatsThis" > + <item row="2" column="1"> + <widget class="QRadioButton" name="UseChartSelect"> + <property name="whatsThis"> <string>Check this option to let the chart choose the best axis layout.</string> </property> - <property name="text" > + <property name="text"> <string>Let the Chart Determine the Axis Layout</string> </property> - <property name="checked" > + <property name="checked"> <bool>true</bool> </property> </widget> </item> - <item row="4" column="1" > - <widget class="QRadioButton" name="UseFixedInterval" > - <property name="whatsThis" > + <item row="4" column="1"> + <widget class="QRadioButton" name="UseFixedInterval"> + <property name="whatsThis"> <string>Check this option to specify each of the axis labels. This option gives you the most control.</string> </property> - <property name="text" > + <property name="text"> <string>Specify Each of the Axis Labels.</string> </property> </widget> </item> - <item row="3" column="1" > - <widget class="QRadioButton" name="UseBestFit" > - <property name="whatsThis" > + <item row="3" column="1"> + <widget class="QRadioButton" name="UseBestFit"> + <property name="whatsThis"> <string>Check this option to specify the range and let the chart choose suitable intervals.</string> </property> - <property name="text" > + <property name="text"> <string>Specify the Axis Range</string> </property> </widget> </item> - <item row="1" column="1" > - <widget class="QCheckBox" name="UseLogScale" > - <property name="text" > + <item row="1" column="1"> + <widget class="QCheckBox" name="UseLogScale"> + <property name="text"> <string>Use Logarithmic Scale When Available</string> </property> </widget> </item> - <item row="0" column="0" colspan="2" > - <widget class="QLabel" name="label_14" > - <property name="font" > + <item row="0" column="0" colspan="2"> + <widget class="QLabel" name="label_14"> + <property name="font"> <font> <weight>75</weight> <bold>true</bold> </font> </property> - <property name="text" > + <property name="text"> <string>Axis Layout</string> </property> </widget> </item> </layout> </widget> - <widget class="QWidget" name="AxisTitle" > - <layout class="QGridLayout" > - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > + <widget class="QWidget" name="AxisTitle"> + <layout class="QGridLayout"> + <property name="margin"> <number>0</number> </property> - <property name="horizontalSpacing" > - <number>6</number> - </property> - <property name="verticalSpacing" > + <property name="spacing"> <number>6</number> </property> - <item row="6" column="0" colspan="4" > + <item row="6" column="0" colspan="4"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Vertical</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>20</width> <height>0</height> @@ -1017,12 +923,12 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="4" column="3" > + <item row="4" column="3"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -1030,138 +936,120 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="4" column="2" > - <widget class="QComboBox" name="AxisTitleAlignment" > + <item row="4" column="2"> + <widget class="QComboBox" name="AxisTitleAlignment"> <item> - <property name="text" > + <property name="text"> <string>Left</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Center</string> </property> </item> <item> - <property name="text" > + <property name="text"> <string>Right</string> </property> </item> </widget> </item> - <item row="0" column="0" colspan="4" > - <widget class="QLabel" name="label_9" > - <property name="font" > + <item row="0" column="0" colspan="4"> + <widget class="QLabel" name="label_9"> + <property name="font"> <font> <weight>75</weight> <bold>true</bold> </font> </property> - <property name="text" > + <property name="text"> <string>Axis Title</string> </property> </widget> </item> - <item row="3" column="1" > - <widget class="QLabel" name="label_11" > - <property name="text" > + <item row="3" column="1"> + <widget class="QLabel" name="label_11"> + <property name="text"> <string>Font</string> </property> </widget> </item> - <item row="1" column="1" > - <widget class="QLabel" name="label_10" > - <property name="text" > + <item row="1" column="1"> + <widget class="QLabel" name="label_10"> + <property name="text"> <string>Text</string> </property> </widget> </item> - <item row="4" column="1" > - <widget class="QLabel" name="label_12" > - <property name="text" > + <item row="4" column="1"> + <widget class="QLabel" name="label_12"> + <property name="text"> <string>Alignment</string> </property> </widget> </item> - <item row="5" column="1" > - <widget class="QLabel" name="label_13" > - <property name="text" > + <item row="5" column="1"> + <widget class="QLabel" name="label_13"> + <property name="text"> <string>Color</string> </property> </widget> </item> - <item row="1" column="2" colspan="2" > - <widget class="QLineEdit" name="AxisTitleText" /> + <item row="1" column="2" colspan="2"> + <widget class="QLineEdit" name="AxisTitleText"/> </item> - <item row="3" column="2" colspan="2" > - <layout class="QHBoxLayout" > - <property name="spacing" > + <item row="3" column="2" colspan="2"> + <layout class="QHBoxLayout"> + <property name="spacing"> <number>6</number> </property> - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > - <number>0</number> - </property> - <property name="bottomMargin" > + <property name="margin"> <number>0</number> </property> <item> - <widget class="QLabel" name="AxisTitleFont" > - <property name="sizePolicy" > - <sizepolicy vsizetype="Preferred" hsizetype="Expanding" > + <widget class="QLabel" name="AxisTitleFont"> + <property name="sizePolicy"> + <sizepolicy hsizetype="Expanding" vsizetype="Preferred"> <horstretch>0</horstretch> <verstretch>0</verstretch> </sizepolicy> </property> - <property name="text" > + <property name="text"> <string>Description</string> </property> </widget> </item> <item> - <widget class="QPushButton" name="AxisTitleFontButton" > - <property name="text" > + <widget class="QPushButton" name="AxisTitleFontButton"> + <property name="text"> <string>Set &Font</string> </property> </widget> </item> </layout> </item> - <item row="5" column="2" colspan="2" > - <layout class="QHBoxLayout" > - <property name="spacing" > - <number>0</number> - </property> - <property name="leftMargin" > - <number>0</number> - </property> - <property name="topMargin" > - <number>0</number> - </property> - <property name="rightMargin" > + <item row="5" column="2" colspan="2"> + <layout class="QHBoxLayout"> + <property name="spacing"> <number>0</number> </property> - <property name="bottomMargin" > + <property name="margin"> <number>0</number> </property> <item> - <widget class="pqColorChooserButton" name="AxisTitleColor" > - <property name="text" > + <widget class="pqColorChooserButton" name="AxisTitleColor"> + <property name="text"> <string>Set Co&lor</string> </property> </widget> </item> <item> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>0</width> <height>20</height> @@ -1171,15 +1059,15 @@ p, li { white-space: pre-wrap; } </item> </layout> </item> - <item rowspan="4" row="1" column="0" > + <item row="1" column="0" rowspan="4"> <spacer> - <property name="orientation" > + <property name="orientation"> <enum>Qt::Horizontal</enum> </property> - <property name="sizeType" > + <property name="sizeType"> <enum>QSizePolicy::Fixed</enum> </property> - <property name="sizeHint" > + <property name="sizeHint" stdset="0"> <size> <width>16</width> <height>20</height> @@ -1187,13 +1075,13 @@ p, li { white-space: pre-wrap; } </property> </spacer> </item> - <item row="2" column="2" > - <widget class="QLabel" name="label_25" > - <property name="text" > - <string><html><head><meta name="qrichtext" content="1" /><style type="text/css"> + <item row="2" column="2"> + <widget class="QLabel" name="label_25"> + <property name="text"> + <string><html><head><meta name="qrichtext" content="1" /><style type="text/css"> p, li { white-space: pre-wrap; } -</style></head><body style=" font-family:'Helvetica'; font-size:9pt; font-weight:400; font-style:normal;"> -<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;">Use <span style=" font-weight:600;">${TIME}</span> to display current time.</p></body></html></string> +</style></head><body style=" font-family:'Helvetica'; font-size:9pt; font-weight:400; font-style:normal;"> +<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;">Use <span style=" font-weight:600;">${TIME}</span> to display current time.</p></body></html></string> </property> </widget> </item> diff --git a/Qt/Components/pqXYChartOptionsEditor.cxx b/Qt/Components/pqXYChartOptionsEditor.cxx index 80ecfb7..8ad5277 100644 --- a/Qt/Components/pqXYChartOptionsEditor.cxx +++ b/Qt/Components/pqXYChartOptionsEditor.cxx @@ -117,6 +117,7 @@ public: QString CurrentPage; QFont TitleFont; + QFont LegendFont; pqXYChartOptionsEditorAxis *AxisData[4]; int CurrentAxis; int AxisIndex; @@ -142,7 +143,7 @@ pqXYChartOptionsEditorAxis::pqXYChartOptionsEditorAxis() //---------------------------------------------------------------------------- pqXYChartOptionsEditorForm::pqXYChartOptionsEditorForm() - : Ui::pqChartOptionsWidget(), CurrentPage(), TitleFont() + : Ui::pqChartOptionsWidget(), CurrentPage(), TitleFont(), LegendFont() { this->CurrentAxis = vtkAxis::LEFT; this->AxisIndex = -1; @@ -275,6 +276,8 @@ pqXYChartOptionsEditor::pqXYChartOptionsEditor(QWidget *widgetParent) QObject::connect(this->Internal->Form->LabelPrecision, SIGNAL(valueChanged(int)), this, SLOT(setLabelPrecision(int))); + QObject::connect(this->Internal->Form->ChartLegendFontButton, + SIGNAL(clicked()), this, SLOT(pickLegendFont())); QObject::connect(this->Internal->Form->AxisMinimum, SIGNAL(textEdited(QString)), this, SLOT(setAxisMinimum())); @@ -606,6 +609,12 @@ void pqXYChartOptionsEditor::pickTitleFont() this->Internal->Form->TitleFont); } +void pqXYChartOptionsEditor::pickLegendFont() +{ + this->pickFont(this->Internal->Form->ChartLegendFont, + this->Internal->Form->LegendFont); +} + void pqXYChartOptionsEditor::pickAxisTitleFont() { if(this->Internal->Form->AxisIndex != -1) @@ -812,6 +821,17 @@ void pqXYChartOptionsEditor::updateOptions() proxy->GetProperty("ShowLegend")).toInt() != 0); values = pqSMAdaptor::getMultipleElementProperty( + proxy->GetProperty("LegendFont")); + if(values.size() == 4) + { + this->Internal->Form->LegendFont = QFont(values[0].toString(), values[1].toInt(), + values[2].toInt() != 0 ? QFont::Bold : -1, + values[3].toInt() != 0); + this->updateDescription(this->Internal->Form->ChartLegendFont, + this->Internal->Form->LegendFont); + } + + values = pqSMAdaptor::getMultipleElementProperty( proxy->GetProperty("ChartTitleFont")); if(values.size() == 4) { @@ -1001,6 +1021,15 @@ void pqXYChartOptionsEditor::applyAxisOptions() pqSMAdaptor::setMultipleElementProperty( proxy->GetProperty("ChartTitleColor"), values); + // Apply the font type info for the legend + values.clear(); + values.append(QVariant(this->Internal->Form->LegendFont.family())); + values.append(QVariant(this->Internal->Form->LegendFont.pointSize())); + values.append(QVariant(this->Internal->Form->LegendFont.bold() ? 1 : 0)); + values.append(QVariant(this->Internal->Form->LegendFont.italic() ? 1 : 0)); + pqSMAdaptor::setMultipleElementProperty( + proxy->GetProperty("LegendFont"), values); + // Axis visibility values.clear(); for(int i = 0; i < 4; ++i) diff --git a/Qt/Components/pqXYChartOptionsEditor.h b/Qt/Components/pqXYChartOptionsEditor.h index fa14f86..b512db7 100644 --- a/Qt/Components/pqXYChartOptionsEditor.h +++ b/Qt/Components/pqXYChartOptionsEditor.h @@ -108,6 +108,7 @@ protected slots: void generateAxisLabels(); void pickTitleFont(); + void pickLegendFont(); private: void updateOptions(); | ||||||||
(0026734) Paul Edwards (reporter) 2011-06-07 05:38 |
Uploaded a patch to add the functionality. |
(0026739) Marcus D. Hanwell (developer) 2011-06-07 10:06 |
I don't see a patch. |
(0026740) Paul Edwards (reporter) 2011-06-07 10:42 |
Patch uploaded! |
(0027665) Arno Mayrhofer (reporter) 2011-11-07 05:33 |
Can this please be included in PV12? I'm surprised that this has not been requested earlier, as this is a major issue for me that forces me to use another program for my 2-D plots. |
(0033326) Utkarsh Ayachit (administrator) 2014-09-11 16:23 |
commit 21808c43e47aa087c65b0d5f0908b0141d9c27ed Author: Sven Buijssen <sven.buijssen@tu-dortmund.de> Date: Thu Sep 4 18:00:57 2014 +0200 Implemented feature request 0010643 (allow legend font editing) Change-Id: I41a599644f086332e5369dae3bd5281458fc8fad commit 0e6d8f5f69876442b491d2fe5337546d6976249c Author: Sven Buijssen <sven.buijssen@tu-dortmund.de> Date: Thu Sep 4 17:02:07 2014 +0200 Fixed copy/paste errors in API documentation |
(0033334) Utkarsh Ayachit (administrator) 2014-09-14 11:30 |
Topics merged into master: 10643_chart_legend_properties (VTK) 13139-plot-small-geometry 14931-cluttered-histogram 14983_catalyst_programmablefilter 14990_finalize_catalyst_pipelines add-flexibility-to-catalyst-exporter catalyst_fix_plugins fix_text_source pvweb-docs-further-reorganization pvweb-move-firefox-test-to-port-8080 |
(0033350) Alan Scott (manager) 2014-09-16 17:16 |
Tested remote server, Linux, master. |
2010-04-29 11:43 | Paul Edwards | New Issue | |
2011-06-07 05:38 | Paul Edwards | Note Added: 0026734 | |
2011-06-07 10:06 | Marcus D. Hanwell | Note Added: 0026739 | |
2011-06-07 10:06 | Marcus D. Hanwell | Assigned To | => Marcus D. Hanwell |
2011-06-07 10:06 | Marcus D. Hanwell | Status | backlog => tabled |
2011-06-07 10:41 | Paul Edwards | File Added: FEATURE_change_legend_font.patch | |
2011-06-07 10:42 | Paul Edwards | Note Added: 0026740 | |
2011-11-07 05:33 | Arno Mayrhofer | Note Added: 0027665 | |
2014-09-11 01:23 | Utkarsh Ayachit | Assigned To | Marcus D. Hanwell => Utkarsh Ayachit |
2014-09-11 01:23 | Utkarsh Ayachit | Project | => TBD |
2014-09-11 01:23 | Utkarsh Ayachit | Type | => incorrect functionality |
2014-09-11 01:23 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-09-11 16:23 | Utkarsh Ayachit | Topic Name | => 10643_chart_legend_properties |
2014-09-11 16:23 | Utkarsh Ayachit | Note Added: 0033326 | |
2014-09-11 16:23 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-09-11 16:23 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-09-11 16:23 | Utkarsh Ayachit | Resolution | open => fixed |
2014-09-14 11:30 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-09-14 11:30 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-09-14 11:30 | Utkarsh Ayachit | Note Added: 0033334 | |
2014-09-16 17:16 | Alan Scott | Note Added: 0033350 | |
2014-09-16 17:16 | Alan Scott | Status | customer review => closed |
2014-09-24 10:13 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
